Hi everyone,
I’m trying to run YOLOv8 on my Jetson Orin NX with JetPack 5.1.2 and Python 3.8. After extensive searching, I installed torch 2.1.0a0+41361538.nv23.06
, which is the compatible version for JetPack. However, when I attempted to run a script using YOLO, I encountered issues with the version of torchvision
Through my research, I found that the appropriate version for torchvision
is 0.16.0. I installed it using the following commands:
git clone --branch v0.16.0 https://github.com/pytorch/vision torchvision
cd torchvision
export BUILD_VERSION=0.16.0
python3 setup.py install
The installation completed successfully, but when I try to execute a file that uses YOLO, I get the following warning:
UserWarning: Failed to load image Python extension: '/home/laura/deteccion_piezas/lib/python3.8/site-packages/torchvision/image.so: undefined symbol: _ZN5torch3jit17parseSchemaOrNameERKSs'
If you don't plan on using image functionality from `torchvision.io`, you can ignore this warning. Otherwise, there might be something wrong with your environment. Did you have `libjpeg` or `libpng` installed before building `torchvision` from source?
warn(
Additionally, I receive a traceback error:
RuntimeError: Couldn't load custom C++ ops. This can happen if your PyTorch and torchvision versions are incompatible, or if you had errors while compiling torchvision from source. For further information on the compatible versions, check https://github.com/pytorch/vision#installation for the compatibility matrix. Please check your PyTorch version with torch.__version__ and your torchvision version with torchvision.__version__ and verify if they are compatible, and if not please reinstall torchvision so that it matches your PyTorch install.
I would appreciate any guidance on how to resolve these compatibility issues between PyTorch and torchvision. Thank you!
