• Hardware Platform ( GPU)
Sun Oct 8 22:20:12 2023
| NVIDIA-SMI 525.125.06 Driver Version: 525.125.06 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:01:00.0 Off | N/A |
| N/A 40C P0 N/A / 80W | 6MiB / 6144MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2774 G /usr/lib/xorg/Xorg 4MiB |
• DeepStream Version : 6.3 (nvcr.io/nvidia/deepstream:6.3-samples)
Pulled the docker image:docker pull nvcr.io/nvidia/deepstream:6.3-samples
I am trying to run the test5 application, but I am facing the following issue.
When I try to check the the nvcc cuda compiler --version , I am facing the below issue
root@sowmiya-masterworks:/opt/nvidia/deepstream/deepstream-6.3/sources/apps/sample_apps/deepstream-test5# nvcc --version
bash: nvcc: command not found
As well I am not able to compile the test5 application using the export CUDA_VER =12.1 as mentioned in the README I am facing the below Error
Step1:
root@sowmiya-masterworks:/opt/nvidia/deepstream/deepstream-6.3/sources/apps/sample_apps/deepstream-test5# export CUDA_VER=12.1
Step2:
root@sowmiya-masterworks:/opt/nvidia/deepstream/deepstream-6.3/sources/apps/sample_apps/deepstream-test5# make
I am facing the below error
fatal error: cuda_runtime_api.h: No such file or directory
32 | include <cuda_runtime_api.h>
compilation terminated.
make: *** [Makefile:71: …/…/apps-common/src/deepstream_source_bin.o] Error 1
As well I am not able to compile the test5 application using the export CUDA_VER =11.1
step1:
root@sowmiya-masterworks:/opt/nvidia/deepstream/deepstream-6.3/sources/apps/sample_apps/deepstream-test5# export CUDA_VER=11.1
step2:
Step3:
root@sowmiya-masterworks:/opt/nvidia/deepstream/deepstream-6.3/sources/apps/sample_apps/deepstream-test5# ./deepstream-test5-app -c configs/test5_config_file_src_infer.txt -p 1
** ERROR: <create_multi_source_bin:1494>: Failed to create element ‘src_bin_muxer’
** ERROR: <create_multi_source_bin:1582>: create_multi_source_bin failed
** ERROR: <create_pipeline:1576>: create_pipeline failed
** ERROR: main:1472: Failed to create pipeline
Quitting
App run failed
I am also uploading
test5_config_file_src_infer.txt (6.3 KB)
the config file
Kindly need your assistance in resolving the issue and running the test application.
