Jetson Orin Nano Developer Kit
• DeepStream Version
6.4
6.0 DP
• TensorRT Version
8.6
I am running the deepstream:6.4-samples-multiarch container and trying to compile the deepstream_test1 app.
docker run -it --net=host --runtime nvidia --privileged --device /dev/video -p 10101:10101 -w /opt/nvidia/deepstream/deepstream-6.4 nvcr.io/nvidia/deepstream:6.4-samples-multiarch
Install the packages mentioned in deepstream-6.4/README
apt update
apt-get install \
libssl3 \
libssl-dev \
libgstreamer1.0-0 \
gstreamer1.0-tools \
gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad \
gstreamer1.0-plugins-ugly \
gstreamer1.0-libav \
gstreamer1.0-alsa \
libgstrtspserver-1.0-0 \
libjansson4 \
libyaml-cpp-dev
Install user additional items
./user_additional_install.sh
go to the deepstream_test1 directory
cd /opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/deepstream-test1
Install items in the README
apt-get install libgstreamer-plugins-base1.0-dev libgstreamer1.0-dev \
libgstrtspserver-1.0-dev libx11-dev
Set CUDA_VER in the Makefile to 12.2
apt-get install vim
vim Makefile
Run make
And then I get these errors
root@ubuntu:/opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/deepstream-test1# make
cc -c -o deepstream_test1_app.o -DPLATFORM_TEGRA -I../../../includes -I /usr/local/cuda-12.2/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/aarch64-linux-gnu -I/usr/include/glib-2.0 -I/usr/lib/aarch64-linux-gnu/glib-2.0/include deepstream_test1_app.c
deepstream_test1_app.c:27:10: fatal error: cuda_runtime_api.h: No such file or directory
27 | #include <cuda_runtime_api.h>
compilation terminated.
make: *** [Makefile:64: deepstream_test1_app.o] Error 1
Which makes sense because my CUDA directory does not have that file
root@ubuntu:/usr/local/cuda-12.2/include# ls
nvToolsExt.h nvToolsExtCuda.h nvToolsExtCudaRt.h nvToolsExtOpenCL.h nvToolsExtSync.h nvtx3
Am I supposed to be able to compile the apps myself? How do I get all the cude include files?
When I look on my Orin host, I see I have all the files
beauceron@ubuntu:/usr/local/cuda-12.2/include$ ls
builtin_types.h cudaVDPAU.h cusolverSp_LOWLEVEL_PREVIEW.h npps_support_functions.h
channel_descriptor.h cuda_vdpau_interop.h cusparse.h nv
common_functions.h cudaVDPAUTypedefs.h cusparse_v2.h nvblas.h
cooperative_groups cudlaExternalEtbl.hpp device_atomic_functions.h nv_decode.h
cooperative_groups.h cudla.h device_atomic_functions.hpp nvfunctional
crt cufft.h device_double_functions.h nvJitLink.h
cub cufftw.h device_functions.h nvml.h
cublas_api.h cufftXt.h device_launch_parameters.h nvperf_common.h
cublas.h cufile.h device_types.h nvperf_cuda_host.h
cublasLt.h cupti_activity.h driver_functions.h nvperf_host.h
cublas_v2.h cupti_callbacks.h driver_types.h nvperf_target.h
cublasXt.h cupti_checkpoint.h fatbinary_section.h nvPTXCompiler.h
cuComplex.h cupti_driver_cbid.h generated_cuda_gl_interop_meta.h nvrtc.h
cuda cupti_events.h generated_cudaGL_meta.h nvToolsExtCuda.h
cuda_awbarrier.h cupti.h generated_cuda_meta.h nvToolsExtCudaRt.h
cuda_awbarrier_helpers.h cupti_metrics.h generated_cudart_removed_meta.h nvToolsExt.h
cuda_awbarrier_primitives.h cupti_nvtx_cbid.h generated_cuda_runtime_api_meta.h nvToolsExtOpenCL.h
cuda_bf16.h cupti_pcsampling.h generated_cuda_vdpau_interop_meta.h nvToolsExtSync.h
cuda_bf16.hpp cupti_pcsampling_util.h generated_cudaVDPAU_meta.h nvtx3
cuda_device_runtime_api.h cupti_profiler_target.h generated_nvtx_meta.h sm_20_atomic_functions.h
cudaEGL.h cupti_result.h host_config.h sm_20_atomic_functions.hpp
cuda_egl_interop.h cupti_runtime_cbid.h host_defines.h sm_20_intrinsics.h
cudaEGLTypedefs.h cupti_sass_metrics.h library_types.h sm_20_intrinsics.hpp
cuda_fp16.h cupti_target.h math_constants.h sm_30_intrinsics.h
cuda_fp16.hpp cupti_version.h math_functions.h sm_30_intrinsics.hpp
cuda_fp8.h curand_discrete2.h mma.h sm_32_atomic_functions.h
cuda_fp8.hpp curand_discrete.h nppcore.h sm_32_atomic_functions.hpp
cudaGL.h curand_globals.h nppdefs.h sm_32_intrinsics.h
cuda_gl_interop.h curand.h npp.h sm_32_intrinsics.hpp
cudaGLTypedefs.h curand_kernel.h nppi_arithmetic_and_logical_operations.h sm_35_atomic_functions.h
cuda.h curand_lognormal.h nppi_color_conversion.h sm_35_intrinsics.h
cudalibxt.h curand_mrg32k3a.h nppi_data_exchange_and_initialization.h sm_60_atomic_functions.h
cuda_occupancy.h curand_mtgp32dc_p_11213.h nppi_filtering_functions.h sm_60_atomic_functions.hpp
cuda_pipeline.h curand_mtgp32.h nppi_geometry_transforms.h sm_61_intrinsics.h
cuda_pipeline_helpers.h curand_mtgp32_host.h nppi.h sm_61_intrinsics.hpp
cuda_pipeline_primitives.h curand_mtgp32_kernel.h nppi_linear_transforms.h surface_functions.h
cuda_profiler_api.h curand_normal.h nppi_morphological_operations.h surface_indirect_functions.h
cudaProfiler.h curand_normal_static.h nppi_statistics_functions.h surface_types.h
cudaProfilerTypedefs.h curand_philox4x32_x.h nppi_support_functions.h texture_fetch_functions.h
cudart_platform.h curand_poisson.h nppi_threshold_and_compare_operations.h texture_indirect_functions.h
cuda_runtime_api.h curand_precalc.h npps_arithmetic_and_logical_operations.h texture_types.h
cuda_runtime.h curand_uniform.h npps_conversion_functions.h thrust
cuda_stdint.h cusolver_common.h npps_filtering_functions.h vector_functions.h
cuda_surface_types.h cusolverDn.h npps.h vector_functions.hpp
cuda_texture_types.h cusolverRf.h npps_initialization.h vector_types.h
cudaTypedefs.h cusolverSp.h npps_statistics_functions.h
