how can i get it work? pls help an advice.
thanks
• DeepStream Version
• TensorRT Version
i am using jetson nx wiht jetpack 4.5.1 and deepstream 5.1.
thanks
Do you install DeepStream SDK through SDKMAnager or apt get install command? Looks like certain packages are missing in your environment.
i installed deepstream SDK by apt-get.
thanks,
You may check if you can build/run other samples:
NVIDIA AI IOT · GitHub
And also can try samples in
/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps
Somehow I don’t see deepstream_centerface_app on our github. Probably it is from other contributors. Other users may be able to share experience.
i can build and run samples-apps of deepstream which inside.
Please check the path:
/usr/local/cuda-10.2/targets/aarch64-linux/include/cuda_runtime_api.h
If you have the header file, please include it in build command for a try.
yes have cuda_runtime_api.h file.
could you give me a full command to make again?
thank you very much!
Please try to add this in build command:
-I/usr/local/cuda-10.2/targets/aarch64-linux/include
this command seems helpful and i try again.
i would llike to ask another questions,
if i run test4 & test5 samples apps, if i must make /sources/libs/kafka_protocal_adaptor fistly?
now i can not make successfully test4 and test5.
thanks,
pls give also to me a full command to run test4&test5 after make them,
this is urgent for me and i am a new deepstream developer… but my project is less time…
thank you very much
For running test4 or test5, you would need to set up a server. Here are reference steps of settign up kafka server:
Is it possible to use a Dahua IP camera with nvidia Deepstream? - #23 by DaneLLL
For more detail, please check document:
DeepStream Reference Application - deepstream-test5 app — DeepStream 5.1 Release documentation
thanks and i am building kafka at jetson NX sucessfully and trying test5-app.
and i would like to ask one question again,
if i use Azure cloud, it will be easier for deepstream? do you have some instructions for how to match Azure?
Please check
What is the current status on Deepstream- Azure integration support? - #5 by mchi
There are some implementations from community. You may search online to get mode information.
