I’m trying to make run the DeepStream SDK 6.1 sample deep-stream_app_source1_dashcamnet_vehiclemakenet_vehicletypenet.txt but without success yet.
The hardware platform is an Azure Standard_NV6 virtual machine with 1x NVidia Tesla M60 GPU, VMware Photon OS 3 as guest os with installed NVidia-Container-Toolkit and pulled Deepstream:6.1-Triton docker container. Photon OS runs with no X window (headless).
• DeepStream Version 6.1
• JetPack Version (valid for Jetson only) -
• TensorRT Version
root@NVidia01 [ ~ ]# nvidia-smi
Fri Aug 26 09:00:16 2022
| NVIDIA-SMI 515.65.01 Driver Version: 515.65.01 CUDA Version: 11.7 |
| | | MIG M. |
| 0 Tesla M60 Off | 00003130:00:00.0 Off | Off |
| N/A 32C P0 35W / 150W | 0MiB / 8192MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Starting deepstream-app -c deepstream_app_source1_dashcamnet_vehiclemakenet_vehicletypenet.txt ends with
**** INFO: <bus_callback:194>: Pipeline ready**
**Error String : Feature not supported on this GPUError Code : 801**
**ERROR from nvv4l2decoder0: Failed to process frame.**
Debug info: gstv4l2videodec.c(1747): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder0:
**Maybe be due to not enough memory or failing driver**
**ERROR from qtdemux0: Internal data stream error.**
Debug info: qtdemux.c(6605): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0:
**streaming stopped, reason error (-5)**
Quitting
[NvMultiObjectTracker] De-initialized
App run failed
The following steps were made after Azure virtual machine start.
Step1:
# docker container start
`docker run --gpus all -it --rm --net=host nvcr.io/nvidia/deepstream:6.1-triton -p 8000:8000/tcp -p 8001:8001/tcp -p 8002:8002/tcp -p 5400:5400/udp`
# Download configuration files
git clone https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps.git
cd /opt/nvidia/deepstream/deepstream-6.1/deepstream_reference_apps/deepstream_app_tao_configs
cp -a * /opt/nvidia/deepstream/deepstream-6.1/samples/configs/tao_pretrained_models/
# Download models
apt-get install -y wget zip
cd /opt/nvidia/deepstream/deepstream-6.1/samples/configs/tao_pretrained_models/
./download_models.sh
Step2:
In deep-stream_app_source1_dashcamnet_vehiclemakenet_vehicletypenet.txt the group [sink0] has been deactivated (enable=0), and [sink2] has been activated (enable=2). Additionally in [sink2], codec=2 #2=h265 has been set because of [source0] uri=file://../../streams/sample_1080p_h265.mp4.
Step3:
Protocol.txt (66.0 KB)
How can I fix the errors “Error String : Feature not supported on this GPUError Code : 801” and “ERROR from nvv4l2decoder0: Failed to process frame.”.
As it is a headless installation with rtsp output, are there prerequisites ?
