Description
I’ve been trying to compile the deepstream-test1 app inside a docker container nvcr.io/nvidia/deepstream:6.3-samples
and ran into missing dependencies and linking errors.
I followed the compilation instructions in the README starting by setting the CUDA_VER=12.1 in the Makefile and than running make
. This resulted in the following error
Package gstreamer-1.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `gstreamer-1.0.pc'
to the PKG_CONFIG_PATH environment variable
No package 'gstreamer-1.0' found
cc -c -o deepstream_test1_app.o -I../../../includes -I /usr/local/cuda-12.1/include deepstream_test1_app.c
deepstream_test1_app.c:24:10: fatal error: gst/gst.h: No such file or directory
24 | #include <gst/gst.h>
compilation terminated.
make: *** [Makefile:64: deepstream_test1_app.o] Error 1
Inspecting the installed packages in the container reviled that some of the dependencies are in installed in the container, more specifically libgstreamer1.0-0 gstreamer1.0-libav libgstreamer-plugins-base1.0-dev.
Once installed manually the error dissapeared. However, another similar error appears:
cc -c -o deepstream_test1_app.o -I../../../includes -I /usr/local/cuda-12.1/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include deepstream_test1_app.c
deepstream_test1_app.c:27:10: fatal error: cuda_runtime_api.h: No such file or directory
27 | #include <cuda_runtime_api.h>
Is there another docker container suitable for deepstream development that has already all the required dependencies?
Environment
TensorRT Version: NA
GPU Type: GeForce RTX 3050 Ti Mobile
Nvidia Driver Version: 525.147.05
CUDA Version: 12.1
CUDNN Version: 8
Operating System + Version: ubuntu 22.04
Python Version (if applicable): NA
TensorFlow Version (if applicable): NA
PyTorch Version (if applicable): NA
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
start container using the command
docker run -it --rm --net=host --gpus all -e DISPLAY=$DISPLAY --device /dev/snd -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream:6.3-samples
cd sources/apps/sample_apps/deepstream-test1/
edit CUDA_VER in make file to 12.1
make
