• Personal Computer (GEFORCE RTX)
• DeepStream 5.1
• TensorRT 7.0
• NVIDIA GPU Driver: CUDA 11.2
• question
• How to reproduce the issue ?:
Pull Deepstream 5.1 images
docker pull nvcr.io/nvidia/deepstream:5.1-21.02-devel
docker pull nvcr.io/nvidia/deepstream:5.1-21.02-samples
Run docker container
docker run -it --rm -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-5.1 nvcr.io/nvidia/deepstream:5.1-21.02-devel
Go to Mask RCNN sample directory
cd /opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-mrcnn-app/
The sample build instructions are in the README
Please follow instructions in the apps/sample_apps/deepstream-app/README
on how
to install the prerequisites for Deepstream SDK, the DeepStream SDK itself and
the apps. It says
You must have the following development packages installed
GStreamer-1.0
GStreamer-1.0 Base Plugins
GStreamer-1.0 gstrtspserver
X11 client-side library
To install these packages, execute the following command:
sudo apt-get install libgstreamer-plugins-base1.0-dev libgstreamer1.0-dev \
libgstrtspserver-1.0-dev libx11-dev
The complete README can be found here
README.md (11.8 KB)
Specify CUDA version
I have CUDA 11.2 installed. I checked this outside the docker container using nvidia-smi
. Within the container,
export CUDA_VER=11.2
Install dependencies. (No need for sudo here)
Build the application
I modified the given makefile as
diff --git a/Makefile b/backupMakefile
index e6abba3..1ffadc0 100644
--- a/Makefile
+++ b/backupMakefile
@@ -51,14 +51,14 @@ PKGS+= gstreamer-1.0 gstreamer-video-1.0
OBJS:= $(SRCS:.cpp=.o)
CFLAGS+= -I../../../includes -std=c++11 \
- -I /usr/local/cuda/include
+ -I /usr/local/cuda-$(CUDA_VER)/include
CFLAGS+= $(shell pkg-config --cflags $(PKGS))
LIBS:= $(shell pkg-config --libs $(PKGS))
LIBS+= -L$(LIB_INSTALL_DIR) -lnvdsgst_meta -lnvds_meta -lrt \
- -L/usr/local/cuda/lib64/ -lcudart \
+ -L/usr/local/cuda-$(CUDA_VER)/lib64/ -lcudart \
-lcuda -Wl,-rpath,$(LIB_INSTALL_DIR)
all: $(APP)
I got the application file built with the name deepstream-mrcnn-app
. On running it as
$deepstream-mrcnn-app
I am prompted with an error
Error
(gst-plugin-scanner:99): GStreamer-WARNING **: 12:03:29.655: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:99): GStreamer-WARNING **: 12:03:29.656: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:99): GStreamer-WARNING **: 12:03:29.676: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:99): GStreamer-WARNING **: 12:03:29.677: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:99): GStreamer-WARNING **: 12:03:29.678: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_eglglessink.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:99): GStreamer-WARNING **: 12:03:29.679: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:99): GStreamer-WARNING **: 12:03:29.679: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:99): GStreamer-WARNING **: 12:03:29.683: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so': libcuda.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:99): GStreamer-WARNING **: 12:03:29.692: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so': libcuda.so.1: cannot open shared object file: No such file or directory
missing arguments
Usage: deepstream-mrcnn-app -i <H264 filename> -p <Proto adaptor library> --conn-str=<Connection string>
On focusing on the last line, Usage: deepstream-mrcnn-app -i <H264 filename> -p <Proto adaptor library> --conn-str=<Connection string>
, I want to know what protocol should I use among the 3 explained in the README, just so that I can get a mask on the sample video file (I don’t find it anywhere). I don’t see the need for the protocol for the sample to infer on a sample image/video and display a mask.
Am I understanding it correctly ?
