Issues on trying to compile TensorFlow C API for JETSON AGX Xavier using Bazel
On my JETSON AGX Xavier, with:
cuda: 11.4.315
cuDNN: 8.6.0
tensorrt: 8.5.2.2
jetpack: 5.1.3
python3 -c “import tensorflow as tf; print(‘TensorFlow version:’, tf.version)”
TensorFlow version: 2.11.0
I can’t compile tf with bazel ( bazel --version: bazel 5.3.0 ) , error:
~/tensorflow$ bazel build --config=opt --config=cuda //tensorflow:libtensorflow.so
Starting local Bazel server and connecting to it…
WARNING: The following configs were expanded more than once: [cuda]. For repeatable flags, repeats are counted twice and may lead to unexpected behavior.
INFO: Reading ‘startup’ options from /home/redans/tensorflow/.bazelrc: --windows_enable_symlinks
INFO: Options provided by the client:
Inherited ‘common’ options: --isatty=1 --terminal_columns=237
INFO: Reading rc options for ‘build’ from /home/redans/tensorflow/.bazelrc:
Inherited ‘common’ options: --experimental_repo_remote_exec
‘build’ options: --define framework_shared_object=true --define tsl_protobuf_header_only=true --define=use_fast_cpp_protos=true --define=allow_oversize_protos=true --spawn_strategy=standalone -c opt --announce_rc --define=grpc_no_ares=true --noincompatible_remove_legacy_whole_archive --features=-force_no_whole_archive --enable_platform_specific_config --define=with_xla_support=true --config=short_logs --config=v2 --experimental_cc_shared_library --experimental_link_static_libraries_once=false --incompatible_enforce_config_setting_visibility
INFO: Reading rc options for ‘build’ from /home/redans/tensorflow/.tf_configure.bazelrc:
‘build’ options: --action_env PYTHON_BIN_PATH=/usr/bin/python3.9 --action_env PYTHON_LIB_PATH=/usr/local/lib/python3.9/dist-packages --python_path=/usr/bin/python3.9 --action_env PYTHONPATH=/usr/local/lib/python3.9/dist-packages:/usr/local/lib/python3.9/dist-packages:/home/redans/ros2_ws/install/yolov8_ros/lib/python3.9/site-packages:/home/redans/ros2_ws/install/yolov8_msgs/lib/python3.9/site-packages:/home/redans/ros2_ws/install/realsense2_camera_msgs/lib/python3.9/site-packages:/opt/ros/humble/lib/python3.9/site-packages --action_env LD_LIBRARY_PATH=/usr/local/cuda-11.4/lib64:/home/redans/local/lib/python3.8/dist-packages/tensorflow:/home/redans/ros2_ws/install/yolov8_msgs/lib:/home/redans/ros2_ws/install/realsense2_camera/lib:/home/redans/ros2_ws/install/realsense2_camera_msgs/lib:/opt/ros/humble/opt/rviz_ogre_vendor/lib:/opt/ros/humble/lib/aarch64-linux-gnu:/opt/ros/humble/lib:/usr/local/cuda-11.4/lib64: --action_env GCC_HOST_COMPILER_PATH=/usr/bin/aarch64-linux-gnu-gcc-9 --config=cuda
INFO: Found applicable config definition build:short_logs in file /home/redans/tensorflow/.bazelrc: --output_filter=DONT_MATCH_ANYTHING
INFO: Found applicable config definition build:v2 in file /home/redans/tensorflow/.bazelrc: --define=tf_api_version=2 --action_env=TF2_BEHAVIOR=1
INFO: Found applicable config definition build:cuda in file /home/redans/tensorflow/.bazelrc: --repo_env TF_NEED_CUDA=1 --crosstool_top=@local_config_cuda//crosstool:toolchain --@local_config_cuda//:enable_cuda --repo_env=HERMETIC_CUDA_VERSION=12.5.1 --repo_env=HERMETIC_CUDNN_VERSION=9.3.0 --@local_config_cuda//cuda:include_cuda_libs=true
INFO: Found applicable config definition build:cuda in file /home/redans/tensorflow/.tf_configure.bazelrc: --repo_env HERMETIC_CUDA_COMPUTE_CAPABILITIES=7.2
INFO: Found applicable config definition build:opt in file /home/redans/tensorflow/.tf_configure.bazelrc: --copt=-Wno-sign-compare --host_copt=-Wno-sign-compare
INFO: Found applicable config definition build:linux in file /home/redans/tensorflow/.bazelrc: --host_copt=-w --copt=-Wno-all --copt=-Wno-extra --copt=-Wno-deprecated --copt=-Wno-deprecated-declarations --copt=-Wno-ignored-attributes --copt=-Wno-array-bounds --copt=-Wunused-result --copt=-Werror=unused-result --copt=-Wswitch --copt=-Werror=switch --define=PREFIX=/usr --define=LIBDIR=$(PREFIX)/lib --define=INCLUDEDIR=$(PREFIX)/include --define=PROTOBUF_INCLUDE_PATH=$(PREFIX)/include --cxxopt=-std=c++17 --host_cxxopt=-std=c++17 --config=dynamic_kernels --experimental_guard_against_concurrent_changes
INFO: Found applicable config definition build:dynamic_kernels in file /home/redans/tensorflow/.bazelrc: --define=dynamic_loaded_kernels=true --copt=-DAUTOLOAD_DYNAMIC_KERNELS
ERROR: Traceback (most recent call last):
File “/home/redans/.cache/bazel/_bazel_redans/e3bb405f92452fe8b27464d0b3fdd1a7/external/rules_python/python/versions.bzl”, line 734, column 32, in
PLATFORMS = _generate_platforms()
File “/home/redans/.cache/bazel/_bazel_redans/e3bb405f92452fe8b27464d0b3fdd1a7/external/rules_python/python/versions.bzl”, line 723, column 15, in _generate_platforms
} | v.flag_values,
Error: unsupported binary operation: dict | dict
ERROR: @local_config_cuda//:enable_cuda :: Error loading option @local_config_cuda//:enable_cuda: error loading package ‘’: at /home/redans/.cache/bazel/_bazel_redans/e3bb405f92452fe8b27464d0b3fdd1a7/external/local_tsl/third_party/py/python_init_repositories.bzl:3:6: at /home/redans/.cache/bazel/_bazel_redans/e3bb405f92452fe8b27464d0b3fdd1a7/external/rules_python/python/repositories.bzl:24:6: at /home/redans/.cache/bazel/_bazel_redans/e3bb405f92452fe8b27464d0b3fdd1a7/external/rules_python/python/private/python_register_multi_toolchains.bzl:22:6: initialization of module ‘python/versions.bzl’ failed
Do you have any suggestions?
Based on the log, it looks like TensorFlow is looking for CUDA 12.5 and cuDNN 9.3.
These are not compatible with your environment and are not available for the Xavier device.
Thanks for your replay!
So I can’t compile tensorflow c++ api on my jetson setup…what do you suggest I do? I really need to compile on jetson
It should work as some users have setup the TensorFlow C++ library for Jetson.
Please find below topic for some related discussion:
