Issues Setting Up CUDA for PyTorch on Windows Using Anaconda
Hello!
I am experiencing issues while trying to set up CUDA to use my GPU for training a neural network in a PyTorch project. I am using Anaconda on Windows, and I need to leverage the GPU for my project. Please help me understand what might be going wrong.
System Information:
  • OS: Windows 10
  • Anaconda: version 2023.03
  • CUDA Toolkit: version 12.4
  • PyTorch: latest version installed via conda
  • Visual Studio: 2022 version 17.10.3
Description of the Problem:
After installing all the necessary components and attempting to build the project using CMake, I encounter the following error:
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.4\include\crt/host_config.h(153): fatal error C1189:
#error: -- unsupported Microsoft Visual Studio version! Only the versions between 2017 and 2022 (inclusive) are supported!
The nvcc flag '-allow-unsupported-compiler' can be used to override this version check;
however, using an unsupported host compiler may cause compilation failure or incorrect run time execution.  Use at your own risk.
# --error 0x2 --
Call Stack (most recent call first):
  C:/Users/alexb/anaconda3/Library/share/cmake-3.26/Modules/CMakeDetermineCompilerId.cmake:8 (CMAKE_DETERMINE_COMPILER_ID_BUILD)
  C:/Users/alexb/anaconda3/Library/share/cmake-3.26/Modules/CMakeDetermineCompilerId.cmake:53 (__determine_compiler_id_test)
  C:/Users/alexb/anaconda3/Library/share/cmake-3.26/Modules/CMakeDetermineCUDACompiler.cmake:307 (CMAKE_DETERMINE_COMPILER_ID)
  cmake/public/cuda.cmake:47 (enable_language)
  cmake/Dependencies.cmake:43 (include)
  CMakeLists.txt:853 (include)
-- Configuring incomplete, errors occurred!
Additionally, when I run the command nvcc --version, I get the following output:
(base) C:\Users\alexb\pytorch>nvcc --version
Copyright (c) 2005-2024 NVIDIA Corporation
Built on Tue_Feb_27_16:28:36_Pacific_Standard_Time_2024
Cuda compilation tools, release 12.4, V12.4.99
Build cuda_12.4.r12.4/compiler.33961263_0
I have checked the versions of all installed components, and they should be compatible. And I verified the paths and settings in the Anaconda environment, and everything seems correct.
How can I correctly configure my environment to properly use CUDA with PyTorch on Windows via Anaconda?
