So a quick question, Can I use "HTTP " streams rather than rtsp streams with the esp32 cam on Nvidia deeps stream especially with “RTSP input/output application” python binding
Yes, you can. We suggest you try to find a pipeline that can be used by gst-launch-1.0
cli. You should know the stream format from your camera and the format of the codec after the http source. Then you can find the right pipeline easily.
