Description
I trying to deal with dynamic shapes and create small net (lenet5 like) to understand how it works
Environment
TensorRT Version: 7.1.3
GPU Type: GeForce RTX 2080 Ti
Nvidia Driver Version: 470.103.01
CUDA Version: 10.2
CUDNN Version: 8.0.5
Operating System + Version: Ubuntu 18.04
Python Version (if applicable): 3.6.9
TensorFlow Version (if applicable):
PyTorch Version (if applicable): 1.8.1
Baremetal or Container (if container which image + tag):
Steps To Reproduce
Here is code to reproduce:
import torch
import torch.nn as nn
import common
import numpy as np
import time
import tensorrt as trt
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
global BATCH_SIZE
BATCH_SIZE = 8
class LeNet5(nn.Module):
def __init__(self):
super().__init__()
self._body = nn.Sequential(
nn.Conv2d(in_channels=1, out_channels=6, kernel_size=5),
nn.ReLU(inplace=True),
nn.MaxPool2d(kernel_size=2),
nn.Conv2d(in_channels=6, out_channels=16, kernel_size=5),
self._head = nn.Sequential(
nn.Linear(in_features=16 * 5 * 5, out_features=120),
nn.Linear(in_features=120, out_features=84),
nn.Linear(in_features=84, out_features=10)
def forward(self, x):
x = self._body(x)
x = x.view(x.size()[0], -1)
x = self._head(x)
return x
# initialize the model
lenet5_model = LeNet5()
class ModelData(object):
INPUT_NAME = "data"
MODEL_PATH = 'models/lenet5_mnist.pt'
INPUT_SHAPE = (-1, 1, -1, -1)
OUTPUT_NAME = "prob"
DTYPE = trt.float32
class LeNet5TRT(object):
def __init__(self, weights) -> None:
super().__init__()
self.weights = weights
self.engine = self.build_engine()
def populate_network(self):
# Configure the network layers based on the self.weights provided.
input_tensor = self.network.add_input(name=ModelData.INPUT_NAME, dtype=ModelData.DTYPE, shape=ModelData.INPUT_SHAPE)
# body
_body_conv1_w = self.weights['_body.0.weight'].numpy()
_body_conv1_b = self.weights['_body.0.bias'].numpy()
_body_conv1 = self.network.add_convolution(input=input_tensor,
num_output_maps=6,
kernel_shape=(5, 5),
kernel=_body_conv1_w ,
bias=_body_conv1_b)
_body_conv1.stride = (1, 1)
_body_conv1.padding = (0, 0)
_body_relu1 = self.network.add_activation(
input=_body_conv1.get_output(0),
type=trt.ActivationType.RELU)
_body_maxpool1 = self.network.add_pooling(input=_body_relu1.get_output(0),
type=trt.PoolingType.MAX,
window_size=(2, 2))
_body_conv2_w = self.weights['_body.3.weight'].numpy()
_body_conv2_b = self.weights['_body.3.bias'].numpy()
_body_conv2 = self.network.add_convolution(input=_body_maxpool1.get_output(0),
num_output_maps=16,
kernel=_body_conv2_w,
bias=_body_conv2_b)
_body_conv2.stride = (1, 1)
_body_conv2.padding = (0, 0)
_body_relu2 = self.network.add_activation(
input=_body_conv2.get_output(0),
_body_maxpool2 = self.network.add_pooling(input=_body_relu2.get_output(0),
window_size=(2, 2))
# head
_head_linear1_w = self.weights['_head.0.weight'].numpy()
_head_linear1_b = self.weights['_head.0.bias'].numpy()
_head_linear1 = self.network.add_fully_connected(
input=_body_maxpool2.get_output(0),
num_outputs=120,
kernel=_head_linear1_w,
bias=_head_linear1_b)
_head_relu1 = self.network.add_activation(
input=_head_linear1 .get_output(0),
_head_linear2_w = self.weights['_head.2.weight'].numpy()
_head_linear2_b = self.weights['_head.2.bias'].numpy()
_head_linear2 = self.network.add_fully_connected(
input=_head_relu1.get_output(0),
num_outputs=84,
kernel=_head_linear2_w,
bias=_head_linear2_b)
_head_relu2 = self.network.add_activation(
input=_head_linear2 .get_output(0),
_head_linear3_w = self.weights['_head.4.weight'].numpy()
_head_linear3_b = self.weights['_head.4.bias'].numpy()
_head_linear3 = self.network.add_fully_connected(
input=_head_relu2.get_output(0),
num_outputs=10,
kernel=_head_linear3_w,
bias=_head_linear3_b)
_head_linear3.get_output(0).name = "prob"
self.network.mark_output(tensor=_head_linear3 .get_output(0))
def GiB(self, val):
return val * 1 << 30
def build_engine(self):
logger= trt.Logger(trt.Logger.INFO)
with trt.Builder(logger) as builder:
builder.max_batch_size = BATCH_SIZE
network_flag = 1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
with builder.create_network(network_flag) as net:
self.network = net
self.populate_network()
self.network.get_input(0).dtype=trt.DataType.HALF
self.network.get_output(0).dtype=trt.DataType.HALF
# we set the inputs and outputs to be float16 type to enable
# maximum fp16 acceleration. Also helps for int8
config=builder.create_builder_config()
# we specify all the important parameters like precision,
# device type, fallback in config object
config.max_workspace_size = 1 << 30 # 10 * (2 ** 30) # 1 gb
config.set_flag(trt.BuilderFlag.GPU_FALLBACK)
config.set_flag(trt.BuilderFlag.FP16)
config.profiling_verbosity = trt.ProfilingVerbosity.VERBOSE
#building with verbose profiling helps debug the engine if there are
#errors in inference output. Does not impact throughput.
profile = builder.create_optimization_profile();
profile.set_shape(ModelData.INPUT_NAME,
(BATCH_SIZE, 1, 16, 16),
(BATCH_SIZE, 1, 32, 32),
(BATCH_SIZE, 1, 64, 64))
config.add_optimization_profile(profile)
return builder.build_engine(net, config)
def load_random_test_case(pagelocked_buffer):
# Select an image at random to be the test case.
img = np.random.rand(BATCH_SIZE,1,32,32).astype(np.float32)
# Copy to the pagelocked input buffer
np.copyto(pagelocked_buffer, img.ravel())
return img
def main():
common.add_help(description="Yeah!")
# Get the PyTorch weights
lenet5_model.eval()
lenet5_model.load_state_dict(torch.load(ModelData.MODEL_PATH))
weights = lenet5_model.state_dict()
# Do inference with TensorRT.
with LeNet5TRT(weights).engine as engine:
# Build an engine, allocate buffers and create a stream.
# For more information on buffer allocation, refer to the introductory samples.
with open('models/lenet5_mnist.trt', "wb") as f:
f.write(engine.serialize())
with open('models/lenet5_mnist.trt', "rb") as f, trt.Runtime(TRT_LOGGER) as runtime:
engine = runtime.deserialize_cuda_engine(f.read())
inputs, outputs, bindings, stream = common.allocate_buffers(engine, batch_size=1)
with engine.create_execution_context() as context:
t = 0
for _ in range(1):
img = load_random_test_case(pagelocked_buffer=inputs[0].host)
# For more information on performing inference, refer to the introductory samples.
# The common.do_inference function will return a list of outputs
a = time.time()
context.set_binding_shape(0, (BATCH_SIZE, 1, 32, 32))
context.active_optimization_profile = 0
pred_trt = common.do_inference_v2(context, bindings=bindings, inputs=inputs,
outputs=outputs, stream=stream)
t += time.time() - a
with torch.no_grad():
pred_torch = lenet5_model.cuda()(torch.from_numpy(img).cuda())
print('baseline: ', pred_torch.cpu().numpy())
print(np.asarray(pred_trt, dtype=np.float32).shape)
print('output: ', np.asarray(pred_trt, dtype=np.float32).reshape((BATCH_SIZE, 10)))
print('diff: ', torch.max(torch.abs(pred_torch.cpu() -
torch.as_tensor(np.asarray(pred_trt, dtype=np.float32).reshape((BATCH_SIZE, 10))))))
print('Time: ', t)
if __name__ == '__main__':
main()
When run get the next error:
[TensorRT] ERROR: Try increasing the workspace size with IBuilderConfig::setMaxWorkspaceSize() if using IBuilder::buildEngineWithConfig, or IBuilder::setMaxWorkspaceSize() if using IBuilder::buildCudaEngine.
[TensorRT] ERROR: ../builder/tacticOptimizer.cpp (1715) - TRTInternal Error in computeCosts: 0 (Could not find any implementation for node (Unnamed Layer* 6) [Fully Connected] + (Unnamed Layer* 7) [Activation].)
File "torch_inf.py", line 261, in <module>
main()
File "torch_inf.py", line 224, in main
AttributeError: __enter__
I’ve tried to increase max_workspace_size up to 11 gb (all my gpu memory) but got the same error.
config.max_workspace_size = 11
I tried different things and when I set
INPUT_SHAPE = (-1, 1, 32, 32)
and
It works properly.
I wonder what is the reason of that behavior?
