It is possible to replace device trees on a Jetson nano production module over wifi? Is there some file in the rootfs I can replace or do I need to use the ./flash.sh script to write to some hidden partition?
Best regards,
jb
Best regards,
jb
You can try to add a FDT field in /boot/extlinux/extlinux.conf and point it to your drb file.
Thanks for your fast response!
Looking at this thread:
What are the advantages or disadvantages of the FDT method compared to the other one?
Best regards,
Jb
FDT entry in extlinux.conf is just a file. You can name it with some alternate name and add a new entry in extlinux.conf, such that the original entry can still be picked via serial console should the new entry fail.
The non-FDT method signs the tree and puts it in a partition. If you’ve burned security fuses, then you must do this. Otherwise you are probably just doing extra work to flash a signed partition when all you need is a file in “/boot”, and there isn’t a fallback. The FDT entry is used if the tree is found via that, otherwise it reverts back to the signed partition (the FDT entry is ignored if security fuses are burned).
