Jaw mesh not transferring to CC4 character
I have a CC4 character. Skin mesh retargeted beautifully. Tongue is working also. However, the lower denture will not transfer to a new result mesh. Following the Nvidia tutorials exactly. I tried my own custom character as well as CC3+ stock character, Kevin. Same result on both.
Ideas?
Hi @gr8sctt ,
Can you check in A2F panel if the lower denture xform is attached?
Thanks! Before I was attaching Mark’s lower denture. I tried attaching the transfer_character’s lower denture this time. And it is at least moving now. However… now the lower jaw is dislocated from the mesh and moving all over the place. What now?
On Character transfer, you can click The Jaw Motion Prep before attaching in A2F
Yes, I did that. Still same result…
when I had this issue it was because I accidentally hit the jaw motion prep button twice.
