Hi Community member,
Now I would like to add the audio codec to JetsonTX2 Devkit with Jestpack 3.2.1. But it could not work well with following links.
https://devtalk.nvidia.com/default/topic/1027508/jetson-tx2/tlv320aic32x4-evaluation-board-with-tx2
https://devtalk.nvidia.com/default/topic/1036139/jetson-tx2/tx2-asoc-with-tlv320aic32x4
Here is the way to do it.
Get the kernel
git clone https://github.com/jetsonhacks/buildJetsonTX2Kernel.git
cd buildJetsonTX2Kernel
sudo ./getKernelSources.sh -
Edit the following C files.
usr/src/kernel/kernel-4.4/sound/soc/codecs/tlc320aic32x4.c
usr/src/kernel/t18x/sound/soc/tegra-alt/tegra_t186ref_mobile_rt565x.c
usr/src/kernel/kernel-4.4/sound/soc/tegra-alt/tegra_asoc_utils_alt.c -
Edit the tegra186-quill-common.dtsi like below.
i2c@3160000 {
status = “okay”;
aic32x4: tlv320aic32x4.1-0018@18 {
compatible = “ti,tlv320aic32x4”;
status = “okay”;
reg = <0x18>;
clocks = <&tegra_car TEGRA186_CLK_AUD_MCLK>;
clock-names = “mclk”;
tegra_sound: sound {
compatible = “nvidia,tegra-audio-t186ref-mobile-rt565x”;
nvidia,model = “tegra-snd-t186ref-mobile-rt565x”;
nvidia,num-codec-link = <13>;
nvidia,num-clk = <8>;
nvidia,clk-rates = < 270950400 /* PLLA_x11025_RATE /
11289600 / AUD_MCLK_x11025_RATE /
45158400 / PLLA_OUT0_x11025_RATE /
45158400 / AHUB_x11025_RATE /
245760000 / PLLA_x8000_RATE /
12288000 / AUD_MCLK_x8000_RATE /
49152000 / PLLA_OUT0_x8000_RATE /
49152000 >;/ AHUB_x8000_RATE */
clocks = <&tegra_car TEGRA186_CLK_PLLP_OUT0>,
<&tegra_car TEGRA186_CLK_PLLA>,
<&tegra_car TEGRA186_CLK_PLL_A_OUT0>,
<&tegra_car TEGRA186_CLK_AHUB>,
<&tegra_car TEGRA186_CLK_CLK_M>,
clock-names = “pll_p_out1”, “pll_a”, “pll_a_out0”, “ahub”,
“clk_m”, “extern1”;
resets = <&tegra_car TEGRA186_RESET_AUD_MCLK>;
reset-names = “extern1_rst”;status = "okay"; nvidia,audio-routing = "z IN1_L", "z IN", "z IN1_R", "z IN", "z OUT", "z LOL", "z OUT", "z LOR"; nvidia,xbar = <&tegra_axbar>; rt565x_dai_link: nvidia,dai-link-1 { link-name = "rt565x-playback"; cpu-dai = <&tegra_i2s2>; codec-dai = <&spdif_dit0>; cpu-dai-name = "I2S2"; codec-dai-name = "dit-hifi"; format = "i2s"; bitclock-slave; frame-slave; bitclock-noninversion; frame-noninversion; bit-format = "s16_le"; bclk_ratio = <0>; srate = <48000>; num-channel = <2>; ignore_suspend; name-prefix = "x"; status = "okay"; }; nvidia,dai-link-2 { link-name = "ti-capture"; cpu-dai = <&tegra_i2s1>; codec-dai = <&aic32x4>; cpu-dai-name = "I2S1"; codec-dai-name = "tlv320aic32x4-hifi"; format = "i2s"; bitclock-master; frame-master; bitclock-noninversion; frame-noninversion; bit-format = "s16_le"; bclk_ratio = <0>; srate = <48000>; num-channel = <2>; ignore_suspend; name-prefix = "z"; status = "okay"; }; nvidia,dai-link-3 { link-name = "spdif-dit-2"; cpu-dai = <&tegra_i2s3>; codec-dai = <&spdif_dit2>; cpu-dai-name = "I2S3"; codec-dai-name = "dit-hifi"; format = "i2s"; bitclock-slave; frame-slave; bitclock-noninversion; frame-noninversion; bit-format = "s16_le"; bclk_ratio = <1>; srate = <48000>; num-channel = <2>; ignore_suspend; name-prefix = "d3"; status = "okay"; }; nvidia,dai-link-4 { link-name = "spdif-dit-3"; ----------------
Build the kernel and copy the Image
sudo ./makeKernel.sh
sudo ./copyImage.sh -
Copy some the device tree files at “/usr/src/kernel/kernel-4.4/arch/arm64/boot/dts” directory to the “<JETPACK_DIR>/64_TX2/Linux_for_Tegra/kenel/dtb” at Host PC
DTB files- tegra186-quill-p3310-1000-c03-00-base.dtb
- tegra186-quill-p3310-1000-a00-00-base.dtb
- tegra186-quill-p3310-1000-c03-00-dsi-hdmi-dp.dtb
- tegra186-quill-p3489-1000-a00-00-ucm1.dtb
- tegra186-quill-p3489-1000-a00-00-ucm2.dtb
Enter the recovery mode
Flash the dtb files.
sudo ./flash.sh -r -k kernel-dtb jetson-tx2 mmcblk0p1
But the codecs is listed the I2C bit not list at “/sys/kernel/debug/asoc/codecs”.
So, would you please teach me your kind advice?
If you have any questions, please let me know.
Best regards.
Kaka
tegra_t186ref_mobile_rt565x.c (33.4 KB)
tlv320aic32x4.c (26 KB)
tegra_asoc_utils_alt.c (15.1 KB)
boot_log.txt (64.7 KB)
tegra186-quill-common.dtsi.txt (35.7 KB)
