Jeston Xavier NX boot time optimization
Hi, everyone,
I just upgraded R35.3.1 as part of Jetpack 5.1.1 on the NX, but i found the NX boot time was too much.
The first step, systemd-analyze
Startup finished in 8.841s (kernel) + 16.506s (userspace) = 25.348s
graphical.target reached after 16.432s in userspace
Second step, i found dmesg
[   16.496885] zram: Added device: zram0
[   16.497834] zram: Added device: zram1
[   16.502652] zram: Added device: zram2
[   16.507019] zram: Added device: zram3
[   16.628290] zram0: detected capacity change from 0 to 898744320
[   16.714184] Adding 877676k swap on /dev/zram0.  Priority:5 extents:1 across:8
77676k SS
[   16.718299] zram1: detected capacity change from 0 to 898744320
[   16.766179] Adding 877676k swap on /dev/zram1.  Priority:5 extents:1 across:8
77676k SS
[   16.768275] zram2: detected capacity change from 0 to 898744320
[   16.810178] Adding 877676k swap on /dev/zram2.  Priority:5 extents:1 across:8
77676k SS
77676k SS
77676k SS
77676k SS
[   16.812063] zram3: detected capacity change from 0 to 898744320
[   16.858266] Adding 877676k swap on /dev/zram3.  Priority:5 extents:1 across:8
77676k SS
[   25.045521] fuse: init (API version 7.32)
[   25.095205] tegradc 15200000.display: blank - powerdown
[   25.095224] tegradc 15210000.display: blank - powerdown
[   25.305029] nvidia: loading out-of-tree module taints kernel.
[   25.320396] NVRM: No NVIDIA GPU found.
[   39.906277] vdd-1v8-sd: disabling
[   39.906320] vdd-3v3-cvb: disabling
[   39.906333] vdd-1v8-cvb: disabling
[   39.906345] vdd-epb-1v0: disabling
[   39.906356] vdd-fan: disabling
[   39.906470] vdd_sys_en: disabling
Note:
77676k SS
I want to know what happened and how to reduce these 8s.
Thank you,
Best regards,
Ultwcz1997
Hi ultwcz1997,
Are you using the devkit or custom board for Xavier NX?
Could you verify with the latest JP5.1.2(R35.4.1)?
There should be 4s boot time improved in UEFI.
It seems there’s other module init during this time.
Could you share the full dmesg as file here for further check?
Hi @KevinFFF:
Thank you.
the devkit
Not yet, i will test for a later time. But now i want to know what happened at Userspace’s service
Full log
nx-log.txt (60.4 KB)
And plot service, it seems `nvphs.service costs about 7s
Hi @KevinFFF
Today i flashed r35.4.1 as part of Jetpack 5.1.2, but the problem still existed. the Userspace time is about 15s, i don’t know whether this value is correct, because i found the log time which in dmesg changed from [14.420112] to [27.430187] as the following
[   10.344538] systemd[1]: Finished Create System Users.
[   10.348439] systemd[1]: Finished Load Kernel Modules.
[   10.350062] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.355361] systemd[1]: Mounting Kernel Configuration File System...
[   10.360536] systemd[1]: Started OP-TEE Client Supplicant.
[   10.367590] systemd[1]: Starting Apply Kernel Variables...
[   10.372477] systemd[1]: Starting Create Static Device Nodes in /dev...
[   10.380248] systemd[1]: Mounted Kernel Configuration File System.
[   10.477007] random: crng init done
[   10.477389] random: 44 urandom warning(s) missed due to ratelimiting
[   12.210146] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[   12.230752] imx219 9-0010: board setup failed
[   12.230976] imx219: probe of 9-0010 failed with error -121
[   12.245123] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[   12.253276] imx219 10-0010: board setup failed
[   12.253501] imx219: probe of 10-0010 failed with error -121
[   12.502157] using random self ethernet address
[   12.502310] using random host ethernet address
[   14.419870] using random self ethernet address
*** [   14.420112] using random host ethernet address
*** [   27.430187] CPU4: shutdown
[   27.492779] CPU5: shutdown
[   30.027585] nvidia: loading out-of-tree module taints kernel.
Ubuntu 20.04.6 LTS ubuntu ttyTCU0
ubuntu login:
Full log
test-nx.txt (61.3 KB)
BTW, systemd-analyze
Startup finished in 8.839s (kernel) + 15.692s (userspace) = 24.531s
graphical.target reached after 14.965s in userspace
Thank you.
Hi, @KevinFFF
Is what I mentioned above a common phenomenon for Jetson Xavier NX, after I used the same version on the Jetson Orin NX 16GB, it didn’t take much time to boot the Userspace service.
I hope you can answer my question very much. I have tried to disable many services, such as nvpsh.service alsa*.service nv-l4t-bootloader-config.service kerneloop.service, and so on, but none of them solved where the extra 7~8 seconds was spent. Thank you very much.
For Jetson Orin NX
systemd-analyze
Startup finished in 10.048s (kernel) + 7.279s (userspace) = 17.328s
graphical.target reached after 7.207s in userspace
systemd-analyze blame
2.289s alsa-restore.service
1.216s dev-nvme0n1p1.device
1.019s nvpmodel.service
 998ms nv.service
 841ms accounts-daemon.service
 829ms nv-l4t-usb-device-mode.service
 817ms avahi-daemon.service
 739ms bluetooth.service
 675ms apport.service
 654ms NetworkManager.service
 542ms polkit.service
 515ms dev-hugepages.mount
 503ms dev-mqueue.mount
 495ms run-rpc_pipefs.mount
 487ms sys-kernel-debug.mount
 483ms sys-kernel-tracing.mount
 459ms keyboard-setup.service
 451ms kmod-static-nodes.service
 449ms systemd-logind.service
 439ms modprobe@chromeos_pstore.service
 431ms nv-l4t-bootloader-config.service
 418ms modprobe@efi_pstore.service
 415ms modprobe@pstore_blk.service
 411ms modprobe@pstore_zone.service
 407ms modprobe@ramoops.service
 404ms systemd-udev-trigger.service
 400ms binfmt-support.service
 399ms nvfb-udev.service
 396ms kerneloops.service
Compare for Jetson Xavier NX
systemd-analyze
Startup finished in 8.312s (kernel) + 15.393s (userspace) = 23.706s
graphical.target reached after 14.697s in userspace
7.685s nvphs.service
7.345s nv-l4t-bootloader-config.service
3.723s dev-mmcblk0p1.device
3.395s nv-l4t-usb-device-mode.service
1.847s systemd-udev-trigger.service
1.687s avahi-daemon.service
1.635s networkd-dispatcher.service
1.365s apport.service
1.305s snapd.service
1.300s NetworkManager.service
1.220s nvpower.service
1.209s udisks2.service
1.171s accounts-daemon.service
1.044s resolvconf-pull-resolved.service
1.027s nv.service
 953ms systemd-logind.service
 953ms polkit.service
 803ms e2scrub_reap.service
 790ms wpa_supplicant.service
 670ms nvpmodel.service
 636ms nv_nvsciipc_init.service
 604ms nvfb-early.service
 521ms snapd.seeded.service
 511ms systemd-resolved.service
 507ms user@124.service
 500ms user@1000.service
 498ms systemd-journald.service
 463ms pppd-dns.service
 438ms kerneloops.service
This service could not be disabled because it is used for marking the boot complete and interacting with the bootloader.
Yes, your current result seems expected as my setup.
You could also check the /var/log/syslog for more details during boot up.
It seems it’s doing several configurations for network and GDM.
Hi, @KevinFFF
Sorry, I can’t find the answer to my problem, so I decided to give up.
Thank you.
You could also update to the latest R35.4.1.
There should be 4s boot time improvement from bootloader (UEFI).
Hi @KevinFFF,
I am sorry to reply later, I will update it, but I still expect to reduce userspace time. Because I found the TX2 and the Orin NX’s userspace time is too short compared to Xavier NX.
TX2 uses R32 and Orin NX uses R35.
There are many differences from the design and architecture.
You could also configure the kernel config to remove the unused modules.
Hi, @KevinFFF
Thank you for your reply, I will close this topic.
