Dear experts,
We recently replaced a 500GB with a 1TB NVMe in our Nvidia Jetson Xavier NX + Jetpack-5.0.2 based system and observed an extreme longer boot time (reported doubled the boot time of the 500GB NVMe case).
Below is the systemd analysis of our system using 512GB-NVMe (after disabling the nvgetty.service and also removing the ttyTCU0,115200n8 boot option from /boot/extlinux/extlinux.conf) :
$ systemd-analyze
Startup finished in 5.151s (kernel) + 30.997s (userspace) = 36.148s
graphical.target reached after 30.937s in userspace
$ systemd-analyze blame
20.008s dev-nvme0n1p1.device
19.893s docker.service
15.272s rc-local.service
15.266s snap.lxd.activate.service
10.014s gdm.service
6.712s nv-l4t-usb-device-mode.service
5.791s snapd.service
3.781s dev-zram3.device
3.253s dev-zram0.device
2.988s dev-zram1.device
2.711s dev-zram2.device
2.470s dev-zram4.device
2.411s dev-zram5.device
1.720s udisks2.service
1.686s systemd-random-seed.service
1.601s upower.service
1.291s user@1000.service
1.233s systemd-udev-trigger.service
1.203s containerd.service
1.137s nvphs.service
1.004s accounts-daemon.service
902ms dev-loop0.device
850ms nv.service
850ms dev-loop1.device
807ms alsa-restore.service
771ms dev-loop4.device
766ms networkd-dispatcher.service
756ms snap-lxd-28475.mount
743ms snap-multipass-12830.mount
725ms snap-snapcraft-12030.mount
711ms nvpmodel.service
697ms dev-loop6.device
694ms dev-loop2.device
663ms snap-core-17201.mount
662ms dev-loop5.device
648ms dev-loop3.device
630ms nvpower.service
627ms dev-loop8.device
620ms dev-loop7.device
610ms snap-lxd-26202.mount
607ms snap-multipass-11106.mount
599ms snap-core22-1383.mount
596ms snap-ros2\x2dmulti-x1.mount
564ms snap-core-16204.mount
563ms systemd-logind.service
561ms dev-loop12.device
535ms snap-core22-1035.mount
535ms dev-loop9.device
507ms dev-loop10.device
494ms snap-core20-2321.mount
479ms snap-core20-2019.mount
478ms snapd.seeded.service
472ms systemd-journald.service
466ms ModemManager.service
454ms dev-loop11.device
449ms kerneloops.service
437ms snap-snapcraft-10086.mount
431ms systemd-resolved.service
395ms apport.service
324ms NetworkManager.service
323ms ssh.service
295ms e2scrub_reap.service
282ms avahi-daemon.service
278ms packagekit.service
266ms keyboard-setup.service
257ms binfmt-support.service
254ms systemd-timesyncd.service
233ms dundee.service
232ms switcheroo-control.service
228ms systemd-udevd.service
189ms systemd-user-sessions.service
179ms systemd-modules-load.service
168ms systemd-tmpfiles-setup.service
162ms resolvconf-pull-resolved.service
158ms proc-sys-fs-binfmt_misc.mount
158ms dev-hugepages.mount
153ms colord.service
152ms dev-mqueue.mount
148ms ofono.service
147ms run-rpc_pipefs.mount
141ms sys-kernel-debug.mount
139ms polkit.service
138ms sys-kernel-tracing.mount
136ms nv_nvsciipc_init.service
136ms nvfb-early.service
130ms openvpn.service
125ms kmod-static-nodes.service
123ms modprobe@ramoops.service
123ms modprobe@chromeos_pstore.service
122ms nvfb-udev.service
122ms modprobe@pstore_blk.service
122ms modprobe@pstore_zone.service
121ms modprobe@efi_pstore.service
112ms rsyslog.service
109ms systemd-remount-fs.service
107ms wpa_supplicant.service
98ms pppd-dns.service
96ms user-runtime-dir@1000.service
56ms systemd-sysusers.service
56ms console-setup.service
53ms nfs-config.service
50ms rtkit-daemon.service
47ms systemd-update-utmp.service
46ms systemd-sysctl.service
44ms systemd-tmpfiles-setup-dev.service
38ms rpcbind.service
36ms sys-fs-fuse-connections.mount
35ms systemd-update-utmp-runlevel.service
31ms sys-kernel-config.mount
26ms systemd-journal-flush.service
25ms plymouth-read-write.service
25ms nvfb.service
17ms plymouth-quit-wait.service
16ms docker.socket
14ms setvtrgb.service
7ms snapd.socket
I will provide the analysis of the 1TB-NVMe based system later when possible. But by looking at the critical services in analysis of the 500GB based system :
10.014s gdm.service
do you think that the degradation in boot time depends heavily on the NVMe size?
Thanks in advance for your opinion and advice if any.
Best Regards,
Khang
