I followed these instructions to flash L4T to a NVMe drive connected to my host, then installed the drive to my Xavier NX.
However, the board always boots to the SD card on power up. The U-Boot prompt doesn’t recognize commands like run bootcmd_nvme0 and saveenv. If I remove the SD card, the board fails to boot. It seems like the SSD is correctly identified, but the kernel has issues.
Here is the UART log:
[garble]
main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.367] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-938a8cd8)
[0000.368] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.368] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.369] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.375] W> device prod register failed
[0000.379] I> Boot-device: QSPI
[0000.382] I> Boot_device: QSPI_FLASH instance: 0
[0000.387] I> QSPI Flash Size = 32 MB
[0000.392] I> Qspi initialized successfully
[0000.393] I> qspi flash-0 params source = boot args
[0000.398] E> Failed: Unknown device 6
[0000.405] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.408] I> Active Boot chain : 1
[0000.411] I> parsing oem signed section of bpmp-fw header done
[0000.416] I> bpmp-fw binary init read from storage
[0000.421] I> oem authentication of bpmp-fw header done
[0000.435] I> bpmp-fw binary done read from storage
[0000.436] I> bpmp-fw: Authentication init Done
[0000.437] I> parsing oem signed section of cpubl header done
[0000.440] I> cpubl binary init read from storage
[0000.445] I> bpmp-fw: Authentication Finalize Done
[0000.449] I> oem authentication of cpubl header done
[0000.457] I> cpubl binary done read from storage
[0000.459] I> cpubl: Authentication init Done
[0000.463] I> parsing oem signed section of rce header done
[0000.468] I> rce binary init read from storage
[0000.473] I> Relocating BR-BCT
[0000.475] I> cpubl: Authentication Finalize Done
[0000.480] I> oem authentication of rce header done
[0000.485] I> rce binary done read from storage
[0000.489] I> rce: Authentication init Done
[0000.493] I> parsing oem signed section of ape header done
[0000.498] I> ape binary init read from storage
[0000.502] I> rce: Authentication Finalize Done
[0000.507] I> oem authentication of ape header done
[0000.511] I> ape binary done read from storage
[0000.515] I> ape: Authentication init Done
[0000.520] I> parsing oem signed section of tos header done
[0000.525] I> tos binary init read from storage
[0000.529] I> ape: Authentication Finalize Done
[0000.534] I> oem authentication of tos header done
[0000.540] I> tos binary done read from storage
[0000.542] I> tos: Authentication init Done
[0000.546] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.552] I> bpmp-fw-dtb binary init read from storage
[0000.557] I> tos: Authentication Finalize Done
[0000.563] I> oem authentication of bpmp-fw-dtb header done
[0000.567] I> bpmp-fw-dtb binary done read from storage
[0000.572] I> bpmp-fw-dtb: Authentication init Done
[0000.577] I> parsing oem signed section of cpubl-dtb header done
[0000.582] I> cpubl-dtb binary init read from storage
[0000.587] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.639] I> oem authentication of cpubl-dtb header done
[0000.639] I> cpubl-dtb binary done read from storage
[0000.640] I> cpubl-dtb: Authentication init Done
[0000.641] I> parsing oem signed section of eks header done
[0000.642] I> eks binary init read from storage
[0000.642] I> cpubl-dtb: Authentication Finalize Done
[0000.643] I> oem authentication of eks header done
[0000.647] I> eks binary done read from storage
[0000.652] I> eks: Authentication init Done
[0000.655] I> eks: Authentication Finalize Done
[0000.660] I> EKB detected (length: 0x410) @ VA:0x52700400
��NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:15:32, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing .......
hwkey-agent: 223: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0001.017] I> Welcome to Cboot
��WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
��[0001.017] I> Cboot Version: t194-cfa2bc91
[0001.019] I> CPU-BL Params @ 0xf2820000
[0001.023] I> 0) Base:0x00000000 Size:0x00000000
[0001.027] I> 1) Base:0xf1100000 Size:0x00100000
[0001.032] I> 2) Base:0xf2000000 Size:0x00200000
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.036] I> 3) Base:0xf1200000 Size:0x00200000
[0001.191] I> 4) Base:0xf1000000 Size:0x00100000
[0001.195] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.200] I> 6) Base:0xf3800000 Size:0x00400000
[0001.204] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.208] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.213] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.217] I> 10) Base:0xf3000000 Size:0x00800000
[0001.222] I> 11) Base:0x40000000 Size:0x00040000
[0001.226] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.231] I> 13) Base:0x40046000 Size:0x00002000
[0001.235] I> 14) Base:0x40048000 Size:0x00002000
[0001.240] I> 15) Base:0xac000000 Size:0x00004000
[0001.244] I> 16) Base:0x4004a000 Size:0x00002000
[0001.249] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.253] I> 18) Base:0x4004c000 Size:0x00002000
[0001.258] I> 19) Base:0xf2200000 Size:0x00600000
[0001.262] I> 20) Base:0x4004e000 Size:0x00002000
[0001.266] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.271] I> 22) Base:0x00000000 Size:0x00000000
[0001.275] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.280] I> 24) Base:0xf6000000 Size:0x02000000
[0001.284] I> 25) Base:0x40050000 Size:0x00002000
[0001.289] I> 26) Base:0x40040000 Size:0x00006000
[0001.293] I> 27) Base:0xf1800000 Size:0x00400000
[0001.298] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.302] I> 29) Base:0xf1400000 Size:0x00400000
[0001.307] I> 30) Base:0x00000000 Size:0x00000000
[0001.311] I> 31) Base:0x00000000 Size:0x00000000
[0001.316] I> 32) Base:0xf8000000 Size:0x08000000
[0001.320] I> 33) Base:0x00000000 Size:0x00000000
[0001.324] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.329] I> 35) Base:0xab000000 Size:0x01000000
[0001.333] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.338] I> 37) Base:0xf2800000 Size:0x00800000
[0001.342] I> 38) Base:0x80000000 Size:0x20000000
[0001.347] I> 39) Base:0xb0000000 Size:0x08000000
[0001.351] I> 40) Base:0x00000000 Size:0x00000000
[0001.356] I> 41) Base:0x00000000 Size:0x00000000
[0001.360] I> 42) Base:0x00000000 Size:0x00000000
[0001.365] I> 43) Base:0x00000000 Size:0x00000000
[0001.369] I> 44) Base:0x00000000 Size:0x00000000
[0001.374] I> 45) Base:0x00000000 Size:0x00000000
[0001.378] GIC-SPI Target CPU: 0
[0001.381] Interrupts Init done
[0001.384] calling constructors
[0001.387] initializing heap
[0001.389] I> Heap: [0xa0699b80 ... 0xab000000]
[0001.394] initializing threads
[0001.397] initializing timers
[0001.399] creating bootstrap completion thread
[0001.404] top of bootstrap2()
[0001.406] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.411] initializing platform
[0001.414] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.419] W> device prod register failed
[0001.423] I> Bl_dtb @0xaaf00000
[0001.428] W> "plugin-manager" doesn't exist, creating
[0001.431] W> "ids" doesn't exist, creating
[0001.435] W> "connection" doesn't exist, creating
[0001.440] W> "configs" doesn't exist, creating
[0001.450] E> failed to read label property for node 158736: 13
[0001.452] E> failed to read reg property for node 158800: 13
[0001.457] E> failed to read reg property for node 158852: 13
[0001.462] E> failed to read reg property for node 158936: 13
[0001.468] I> Find /i2c@3160000's alias i2c0
[0001.470] I> Reading eeprom i2c=0 address=0x50
[0001.500] I> Device at /i2c@3160000:0x50
[0001.500] I> Reading eeprom i2c=0 address=0x57
[0001.524] I> Device at /i2c@3160000:0x57
[0001.527] I> Find /i2c@c240000's alias i2c1
[0001.527] I> Reading eeprom i2c=1 address=0x50
[0001.529] E> I2C: slave not found in slaves.
[0001.529] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.530] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.531] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.539] E> eeprom: Retry to read I2C slave device.
[0001.544] E> I2C: slave not found in slaves.
[0001.548] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.555] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.561] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.570] E> eeprom: Failed to read I2C slave device
[0001.575] I> Eeprom read failed 0x3526070d
[0001.579] I> create_pm_ids: id: 3668-0000-200-G, len: 15
[0001.584] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.595] I> create_pm_ids: id: 3509-0000-100-F, len: 15
[0001.601] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.612] I> Adding plugin-manager/ids/3668-0000-200=/i2c@3160000:module@0x50
[0001.620] W> "i2c@3160000" doesn't exist, creating
[0001.623] W> "module@0x50" doesn't exist, creating
[0001.628] I> Adding plugin-manager/ids/3509-0000-100=/i2c@3160000:module@0x57
[0001.635] W> "module@0x57" doesn't exist, creating
[0001.641] I> Adding plugin-manager/cvm
[0001.643] W> "chip-id" doesn't exist, creating
[0001.647] I> Adding plugin-manager/chip-id/A02
[0001.652] I> Plugin-manager override starting
[0001.657] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.664] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.670] I> node /plugin-manager/fragement-tegra-sdhci-emmc-dis matches
[0001.676] I> Disable plugin-manager status in FDT
[0001.678] I> Plugin-manager override finished successfully
[0001.684] I> gpio framework initialized
[0001.688] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.696] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.702] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.709] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.717] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.724] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.730] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.737] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.745] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.752] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.759] I> fixed regulator driver initialized
[0001.767] I> register 'maxim' power off handle
[0001.768] I> virtual i2c enabled
[0001.770] I> registered 'maxim,max20024' pmic
[0001.774] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.781] I> Boot-device: QSPI
[0001.784] I> Boot_device: QSPI_FLASH instance: 0
[0001.789] I> QSPI source rate = 204000 Khz
[0001.792] I> Requested rate for QSPI clock = 34000 Khz
[0001.797] I> BPMP-set rate for QSPI clk = 34000 Khz
[0001.802] I> QSPI Flash Size = 32 MB
[0001.810] I> Qspi initialized successfully
[0001.810] I> qspi flash-0 params source = boot args
[0001.814] I> create_pm_ids: id: 3668-0000-200-G, len: 15
[0001.819] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.830] I> create_pm_ids: id: 3509-0000-100-F, len: 15
[0001.835] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.846] I> No sdcard
[0001.848] I> -0 params source =
[0001.852] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0001.863] I> regulator 'vdd-hdmi-5v0' already enabled
[0001.867] I> regulator 'vdd-hdmi-5v0' already enabled
[0001.867] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0001.873] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0001.882] E> invalid display type
[0001.883] E> cannot find any other nvdisp nodes
[0001.887] E> no valid display unit config found in dtb
[0001.893] W> display init failed
[0001.895] I> Load in CBoot Boot Options partition and parse it
[0001.901] E> Error -9 when finding node with path /boot-configuration
[0001.907] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0001.914] I> Using default boot order
[0001.918] I> boot-dev-order :-
[0001.921] I> 1.sd
[0001.922] I> 2.usb
[0001.924] I> 3.nvme
[0001.926] I> 4.emmc
[0001.928] I> 5.net
[0001.930] I> Hit any key to stop autoboot: 4 3 2 1
[0003.938] initializing target
[0003.938] calling apps_init()
[0003.939] starting app kernel_boot_app
[0003.945] I> found decompressor handler: lz4-legacy
[0003.945] I> decompressing BMP blob ...
[0003.949] I> Kernel type = Normal
[0003.949] I> ########## SD (0) boot ##########
[0003.949] I> No sdcard
[0003.950] I> -0 params source =
[0003.950] E> Blockdev open: exit error
[0003.950] E> SD boot failed, err: 724238353
[0003.951] I> ########## USB (0) boot ##########
[0003.972] I> Validate XUSB-FW ...
[0003.972] I> T19x: Authenticate XUSB-FW (bin_type: 11), max size 0x30000
[0003.974] I> Encryption fuse is not ON
[0003.974] I> USB Firmware Version: 60.09 release
[0004.029] I> regulator of usb2-0 already enabled
[0004.034] I> regulator of usb2-1 already enabled
[0004.039] I> regulator of usb2-2 already enabled
[0005.106] I> USB 2.0 port 2 new high-speed USB device detected
[0005.107] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa06a8c00, cmd_ring.dma = 0xa06a8cc0
[0005.208] I> Start to enumerate device
[0005.209] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa06a8c00, cmd_ring.dma = 0xa06a8cc0
[0005.219] I>
[0005.219] I> Enumerated USB Device 0bda:5489
[0005.220] I>
[0005.222] I> Hub:
[0005.222] I> Downstream ports : 4
[0005.222] I> Power switching : Ganged
[0005.223] I> Compound device : No
[0005.223] I> Over-current protection : Global
[0005.223] I> Hub avg delay : 4 ns
[0005.225] I> Set interface = 1 (alt setting)
[0005.230] I> Enable hub ports
[0006.257] E> No device found on any of the hub ports
[0006.257] E> failed to start xhci controller
[0006.258] E> Error in init of XUSB host driver, err: 7979000d
[0006.258] W> Failed to initialize device 5-0
[0006.258] E> USB boot failed, err: 2037973005
[0006.259] I> ########## NVME (0) boot ##########
[0006.259] I> Initializing nvme device instance 0
[0006.264] I> Initializing nvme controller
[0006.268] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0006.274] I> vpcie3v3-supply not found
[0006.277] I> vpcie12v-supply not found
[0006.281] W> Failed to get nvidia,plat-gpios
[0006.285] I> tegrabl_pcie_soc_preinit: (0):
[0006.289] I> Unpowergate
[0006.292] I> tegrabl_car_clk_disable(0) ...
[0006.296] I> tegrabl_car_rst_set(CORE, 0) ...
[0006.300] I> tegrabl_car_rst_set(APB, 0) ...
[0006.304] I> tegrabl_car_clk_enable(0) ...
[0006.308] I> tegrabl_car_rst_clear(APB, 0) ...
[0006.312] I> tegrabl_set_ctrl_state(0)
[0006.316] I> CLR PCIE_APB:6
[0006.318] I> tegrabl_pcie_soc_init: (0):
[0006.322] I> APPL initialization ...
[0006.325] I> poweron phys
[0006.328] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0006.334] I> tegrabl_power_on_phy: controller 0 not available
[0006.340] E> Failed to power on phy on controller-0
[0006.345] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0006.350] I> Failed to initialize SoC Host PCIe controller
[0006.355] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(0); error=0x1
[0006.361] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0006.368] W> Failed to open NVME-0, err = 80800601
[0006.372] W> Failed to initialize device 10-0
[0006.377] E> NVME (0) boot failed, err: 0x80800601
[0006.381] I> ########## NVME (1) boot ##########
[0006.386] I> Initializing nvme device instance 1
[0006.390] I> Initializing nvme controller
[0006.394] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0006.400] I> vpcie3v3-supply not found
[0006.404] I> vpcie12v-supply not found
[0006.408] W> Failed to get nvidia,plat-gpios
[0006.412] I> tegrabl_pcie_soc_preinit: (1):
[0006.416] I> Unpowergate
[0006.418] I> tegrabl_car_clk_disable(1) ...
[0006.422] I> tegrabl_car_rst_set(CORE, 1) ...
[0006.426] I> tegrabl_car_rst_set(APB, 1) ...
[0006.430] I> tegrabl_car_clk_enable(1) ...
[0006.434] I> tegrabl_car_rst_clear(APB, 1) ...
[0006.439] I> tegrabl_set_ctrl_state(1)
[0006.442] I> CLR PCIE_APB:6
[0006.445] I> tegrabl_pcie_soc_init: (1):
[0006.449] I> APPL initialization ...
[0006.452] I> poweron phys
[0006.455] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0006.461] I> tegrabl_power_on_phy: controller 1 not available
[0006.466] E> Failed to power on phy on controller-1
[0006.472] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0006.476] I> Failed to initialize SoC Host PCIe controller
[0006.482] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(1); error=0x1
[0006.488] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0006.494] W> Failed to open NVME-1, err = 80800601
[0006.499] W> Failed to initialize device 10-1
[0006.503] E> NVME (1) boot failed, err: 0x80800601
[0006.508] I> ########## NVME (2) boot ##########
[0006.512] I> Initializing nvme device instance 2
[0006.517] I> Initializing nvme controller
[0006.521] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0006.527] I> vpcie3v3-supply not found
[0006.531] I> vpcie12v-supply not found
[0006.534] W> Failed to get nvidia,plat-gpios
[0006.538] I> tegrabl_pcie_soc_preinit: (2):
[0006.542] I> Unpowergate
[0006.545] I> tegrabl_car_clk_disable(2) ...
[0006.549] I> tegrabl_car_rst_set(CORE, 2) ...
[0006.553] I> tegrabl_car_rst_set(APB, 2) ...
[0006.557] I> tegrabl_car_clk_enable(2) ...
[0006.561] I> tegrabl_car_rst_clear(APB, 2) ...
[0006.565] I> tegrabl_set_ctrl_state(2)
[0006.569] I> CLR PCIE_APB:6
[0006.572] I> tegrabl_pcie_soc_init: (2):
[0006.575] I> APPL initialization ...
[0006.579] I> poweron phys
[0006.581] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0006.587] I> tegrabl_power_on_phy: controller 2 not available
[0006.593] E> Failed to power on phy on controller-2
[0006.598] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0006.603] I> Failed to initialize SoC Host PCIe controller
[0006.608] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(2); error=0x1
[0006.615] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0006.621] W> Failed to open NVME-2, err = 80800601
[0006.626] W> Failed to initialize device 10-2
[0006.630] E> NVME (2) boot failed, err: 0x80800601
[0006.634] I> ########## NVME (3) boot ##########
[0006.639] I> Initializing nvme device instance 3
[0006.643] I> Initializing nvme controller
[0006.648] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0006.654] I> vpcie3v3-supply not found
[0006.657] I> vpcie12v-supply not found
[0006.661] W> Failed to get nvidia,plat-gpios
[0006.665] I> tegrabl_pcie_soc_preinit: (3):
[0006.669] I> Unpowergate
[0006.671] I> tegrabl_car_clk_disable(3) ...
[0006.675] I> tegrabl_car_rst_set(CORE, 3) ...
[0006.680] I> tegrabl_car_rst_set(APB, 3) ...
[0006.684] I> tegrabl_car_clk_enable(3) ...
[0006.688] I> tegrabl_car_rst_clear(APB, 3) ...
[0006.692] I> tegrabl_set_ctrl_state(3)
[0006.696] I> CLR PCIE_APB:6
[0006.698] I> tegrabl_pcie_soc_init: (3):
[0006.702] I> APPL initialization ...
[0006.705] I> poweron phys
[0006.708] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0006.714] I> tegrabl_power_on_phy: controller 3 not available
[0006.720] E> Failed to power on phy on controller-3
[0006.725] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0006.729] I> Failed to initialize SoC Host PCIe controller
[0006.735] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(3); error=0x1
[0006.741] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0006.748] W> Failed to open NVME-3, err = 80800601
[0006.752] W> Failed to initialize device 10-3
[0006.756] E> NVME (3) boot failed, err: 0x80800601
[0006.761] I> ########## NVME (4) boot ##########
[0006.766] I> Initializing nvme device instance 4
[0006.770] I> Initializing nvme controller
[0006.774] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0006.780] I> vpcie3v3-supply not found
[0006.784] I> vpcie12v-supply not found
[0006.787] W> Failed to get nvidia,plat-gpios
[0006.792] I> tegrabl_pcie_soc_preinit: (4):
[0006.796] I> Unpowergate
[0006.798] I> tegrabl_car_clk_disable(4) ...
[0006.802] I> tegrabl_car_rst_set(CORE, 4) ...
[0006.806] I> tegrabl_car_rst_set(APB, 4) ...
[0006.810] I> tegrabl_car_clk_enable(4) ...
[0006.814] I> tegrabl_car_rst_clear(APB, 4) ...
[0006.819] I> tegrabl_set_ctrl_state(4)
[0006.822] I> CLR PCIE_APB:6
[0006.825] I> tegrabl_pcie_soc_init: (4):
[0006.828] I> APPL initialization ...
[0006.832] I> poweron phys
[0006.835] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0006.841] I> tegrabl_power_on_phy: power on phy @0x3f40000
[0006.948] I> PCIe controller-4 link is up
[0006.948] I> tegra_pcie_info[4].cfg0_base = 0x36000000
[0006.949] I> tegra_pcie_info[4].cfg1_base = 0x36020000
[0006.949] I> tegra_pcie_info[4].atu_dma_base = 0x36040000
[0006.949] I> tegra_pcie_bus[4].mem = 0x36200000
[0006.950] I> Scanning busnr: 0 devfn: 0
[0006.950] I> PCIe IDs: 0x1ad110de
[0006.953] I> PCIe RID_CC: 0x60400a1
[0006.957] I> Scanning busnr: 1 devfn: 0
[0006.960] I> PCIe IDs: 0xc82210ec
[0006.963] I> PCIe RID_CC: 0x2800000
[0006.967] I> PCI Config: I/O=0x36100000, Memory=0x36200000
[0006.972] I> IO bar_num=0 bar=0x36100000
[0006.976] I> MEM64 bar_num=2 bar=0x36200000
[0006.980] I> Number of PCIe devices detected: 2
[0006.984] E> tegrabl_nvme_init: Failed tegrabl_pcie_get_dev(4); error=0x0
[0006.991] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0006.997] W> Failed to open NVME-4, err = 80800612
[0007.002] W> Failed to initialize device 10-4
[0007.006] E> NVME (4) boot failed, err: 0x80800612
[0007.011] I> ########## NVME (5) boot ##########
[0007.015] I> Initializing nvme device instance 5
[0007.020] I> Initializing nvme controller
[0007.024] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0007.030] I> vpcie3v3-supply not found
[0007.034] I> vpcie12v-supply not found
[0007.037] W> Failed to get nvidia,plat-gpios
[0007.041] I> tegrabl_pcie_soc_preinit: (5):
[0007.045] I> Unpowergate
[0007.048] I> tegrabl_car_clk_disable(5) ...
[0007.052] I> tegrabl_car_rst_set(CORE, 5) ...
[0007.056] I> tegrabl_car_rst_set(APB, 5) ...
[0007.060] I> tegrabl_car_clk_enable(5) ...
[0007.064] I> tegrabl_car_rst_clear(APB, 5) ...
[0007.068] I> tegrabl_set_ctrl_state(5)
[0007.072] I> CLR PCIE_APB:6
[0007.075] I> tegrabl_pcie_soc_init: (5):
[0007.078] I> APPL initialization ...
[0007.082] I> poweron phys
[0007.085] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0007.091] I> tegrabl_power_on_phy: power on phy @0x3eb0000
[0007.096] I> tegrabl_power_on_phy: power on phy @0x3ec0000
[0007.101] I> tegrabl_power_on_phy: power on phy @0x3ed0000
[0007.107] I> tegrabl_power_on_phy: power on phy @0x3ee0000
[0007.112] I> tegrabl_power_on_phy: power on phy @0x3ef0000
[0007.117] I> tegrabl_power_on_phy: power on phy @0x3f00000
[0007.123] I> tegrabl_power_on_phy: power on phy @0x3f10000
[0007.128] I> tegrabl_power_on_phy: power on phy @0x3f20000
[0007.268] I> PCIe controller-5 link is up
[0007.269] I> tegra_pcie_info[5].cfg0_base = 0x3a000000
[0007.269] I> tegra_pcie_info[5].cfg1_base = 0x3a020000
[0007.270] I> tegra_pcie_info[5].atu_dma_base = 0x3a040000
[0007.270] I> tegra_pcie_bus[5].mem = 0x3a200000
[0007.270] I> Scanning busnr: 0 devfn: 0
[0007.271] I> PCIe IDs: 0x1ad010de
[0007.274] I> PCIe RID_CC: 0x60400a1
[0007.277] I> Scanning busnr: 1 devfn: 0
[0007.281] I> PCIe IDs: 0x2263126f
[0007.284] I> PCIe RID_CC: 0x1080203
[0007.287] I> PCI Config: I/O=0x3a100000, Memory=0x3a200000
[0007.293] I> MEM64 bar_num=0 bar=0x3a200000
[0007.297] I> Number of PCIe devices detected: 2
[0007.301] I> NVME page size: 4096
[0007.381] I> NVMe serial number: 0000061009
[0007.382] I> NVMe model number: ORTIAL SSD
[0007.382] I> NVMe firmware revision: T1102A0L
[0007.514] I> block_count: 250069680
[0007.515] I> supported_lba: 0
[0007.515] I> block_size_log2: 0x9
[0007.527] I> tegrabl_create_io_queue_cmd: queue size: 2
[0007.528] I> tegrabl_create_io_queue_cmd: queue size: 2
[0007.529] I> nvme device id 000a0005
[0007.529] I> nvme-5 params source =
[0007.530] I> Found 1 partitions in NVME (instance 5)
[0007.530] I> Look for boot partition
[0007.530] I> Fallback: assuming 0th partition is boot partition
[0007.533] I> Detect filesystem
[0007.537] I> Loading kernel-bootctrl from partition
[0007.540] E> Cannot find partition kernel-bootctrl
[0007.545] E> Cannot open partition kernel-bootctrl
[0007.550] W> tegrabl_get_kernel_bootctrl: failed to read primary bootctrl data
[0007.557] I> Loading kernel-bootctrl_b from partition
[0007.562] E> Cannot find partition kernel-bootctrl_b
[0007.567] E> Cannot open partition kernel-bootctrl_b
[0007.571] W> tegrabl_get_kernel_bootctrl: failed to read recovery bootctrl data
[0007.579] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0007.586] I> Loading extlinux.conf ...
[0007.589] I> Loading extlinux.conf binary from rootfs ...
[0007.594] I> rootfs path: /nvme/boot/extlinux/extlinux.conf
[0007.600] I> Loading extlinux.conf sig file from rootfs ...
[0007.605] I> rootfs path: /nvme/boot/extlinux/extlinux.conf.sig
[0007.611] I> Validate extlinux.conf ...
[0007.615] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0007.622] I> Encryption fuse is not ON
[0007.625] I> L4T boot options
[0007.628] I> [1]: "primary kernel"
[0007.631] I> Enter choice:
[0010.635] I> Continuing with default option: 1
[0010.635] I> Loading kernel ...
[0010.635] I> Loading kernel binary from rootfs ...
[0010.635] I> rootfs path: /nvme/boot/Image
[0010.811] I> Loading kernel sig file from rootfs ...
[0010.812] I> rootfs path: /nvme/boot/Image.sig
[0010.812] I> overload load_size to 34484232 (from 34484240)
[0010.813] I> Validate kernel ...
[0010.813] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0011.127] I> Encryption fuse is not ON
[0011.156] I> Loading kernel-dtb ...
[0011.156] I> No kernel-dtb binary path
[0011.156] I> Continue to load from partition ...
[0011.157] I> A/B: bin_type (38) slot 1
[0011.157] I> Loading kernel-dtb_b from partition
[0011.157] E> Cannot find partition kernel-dtb_b
[0011.158] E> Cannot open partition kernel-dtb_b
[0011.159] E> A/B loader failure
[system reboots]
