Hi Team,
I am able to execute the complete exercise succesfully using the step by step approach.
The jupyter way is fine for learning the matter.
However I like to run the total code with a single command.
Logically I must copy all code cells into a .py-file.
Then I can issue the command like: sudo python3
What is the best way to proceed, having the .ipynb as souce? (===transform .ipynb into .py-file)
The nano-editor is not available in jupiter? can I install nano-editor without problems?
Thanks for help
Regards,
Fred
I am able to convert the .ipynb-file into .py-file using nbconvert
The sample that I ahve used is teleoperation.ipynb
However executing this file (sudo python3 teleoperation.py) I am stuck with errors:
- NameError: name 'display’is not defined
Commenting the display verbs, another error showed up
- IndexError: tuple index out of range
Related to line 52: left_link = traitlets.dlink…
How to proceed?
same here, most of time it shows IndexError: tuple index out of range error, I once success to get controller to make accelerating and steering.
