I downloaded the SD Card image for Jetpack 4.2.1 for Nano. Wrote to an SD Card using Etcher.
My Nano fails to boot. It hangs at:
A start job is running for End-user configuration after initial OEM installation (10min 25s / no limit)
Anyone else had this problem?
I had the same problem with Xavier. Then I pressed the reset button, and everything works fine now.
I tried cycling power with no effect. Leaving the Nano powered off for the weekend appears to have worked. It’s running now.
I was also facing similar issue on Jetson Tx2 for Jetpack 4.2.1. I tried pressing the reset button and it worked fine after that. Thanks!
JetPack 4.2.2 has the same problem and the remedy is also same. Press reset button once.
system
6
How long does it take on tx2? I am 9 minutes in.
It appears this happens when the usb is still connected to the programming port… Make sure you inplug the usb before booting.
I let it run. Mistake. After 7 hours I pressed ctrl+alt+del and it just booted in.
Genius, that works for me
