Hi @WayneWWW,
[b]Sorry for the delay. I got GtkTerm connecteds while I tried to boot my TX2 from a 1TB SATA SSD.
I flashed it as per Carolyuu’s instructions[/b]
1). Create GPT and partition using gdisk on the external device
2). Get the UUID for the partition on the external device. For example, if the device partition is /dev/sda1, then execute ...
$ sudo blkid /dev/sda1
/dev/sda1: UUID="93A6-26BA" TYPE="vfat" PARTLABEL="Linux filesystem" PARTUUID="018eff62-2d07-4ca5-8619-c30c18b0a181"
3). Write the PARTUUID shown from the previous command to the following file ...
echo '018eff62-2d07-4ca5-8619-c30c18b0a181' > bootloader/l4t-rootfs-uuid.txt
4). Copy the rootfs folder to your sdcard (/dev/sda1)
5). Flash the board: (external is for sdcard, usb and sata)
$ sudo ./flash.sh jetson-tx2 external
That didn’t work. I tried editing on the emmc /boot/extlinux/extlinux.conf. I edited a line to look like this:
APPEND ${cbootargs} root=UUID=bb1e0ba5-e3b6-46d3-b4ce-dd9c75632ba4 rootwait rootfstype=ext4
That has also failed. The TX2 starts to boot, I see the NVIDIA emblem then a few lines of text and it tries to reboot.
Please find below the output of GtkTerm when I try to boot. I really hope it helps!
[0003.396] I> decompressor handler not found
[0003.400] I> Copying kernel image (477882 bytes) from 0x80400800 to 0x80800000 … [0003.408] I> Done
[0003.409] I> Move ramdisk (len: 0) from 0x80475800 to 0x94830000
[0003.417] I> Updated bpmp info to DTB
[0003.422] I> Ramdisk: Base: 0x94830000; Size: 0x0
[0003.427] I> Updated initrd info to DTB
[0003.431] W> WARN: Fail to override “console=none” in commandline
[0003.437] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.444] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.451] I> disabled_core_mask: 0xffffff0c
[0003.455] W> No valid slot number is found in scratch register
[0003.461] W> Return default slot: _a
[0003.464] I> Active slot suffix:
[0003.467] I> add_boot_slot_suffix: slot_suffix =
[0003.472] I> Linux Cmdline: root=PARTUUID=bb1e0ba5-e3b6-46d3-b4ce-dd9c75632ba4 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x9607d000 lut_mem2=0x2008@0x9607a000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
[0003.516] I> Updated bootarg info to DTB
[0003.520] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:a8:39:fa
[0003.526] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:a8:39:fb
[0003.532] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:a8:39:fc
[0003.539] E> Found no plugin manager ids in source DT
[0003.544] W> Add plugin manager ids from board info
[0003.548] E> “plugin-manager” doesn’t exist, creating
[0003.553] E> “ids” doesn’t exist, creating
[0003.557] E> “connection” doesn’t exist, creating
[0003.562] E> “configs” doesn’t exist, creating
[0003.566] I> create_pm_ids: id: 3310-1000-B02-D, len: 15
[0003.571] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0003.582] I> create_pm_ids: id: 2597-0000-501-C, len: 15
[0003.587] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0003.598] I> Adding plugin-manager/ids/3310-1000-B02=/i2c@c250000:module@0x50
[0003.605] E> “i2c@c250000” doesn’t exist, creating
[0003.610] E> “module@0x50” doesn’t exist, creating
[0003.615] I> Adding plugin-manager/ids/2597-0000-501=/i2c@c250000:module@0x57
[0003.622] E> “module@0x57” doesn’t exist, creating
[0003.629] I> Adding plugin-manager/ids/3310-1000-B02-D
[0003.636] I> Adding plugin-manager/configs/3310-mem-type 00
[0003.642] I> Adding plugin-manager/configs/3310-power-config 00
[0003.648] I> Adding plugin-manager/configs/3310-misc-config 00
[0003.654] I> Adding plugin-manager/configs/3310-modem-config 00
[0003.660] I> Adding plugin-manager/configs/3310-touch-config 00
[0003.666] I> Adding plugin-manager/configs/3310-display-config 00
[0003.672] I> Adding plugin-manager/cvm
[0003.676] E> “chip-id” doesn’t exist, creating
[0003.680] I> Adding plugin-manager/chip-id/A02P
[0003.684] E> “odm-data” doesn’t exist, creating
[0003.689] I> Adding /chosen/plugin-manager/odm-data
[0003.699] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.705] I> added [base:0xf0200000, size:0x185600000] to /memory
[0003.711] I> added [base:0x275e00000, size:0x200000] to /memory
[0003.716] I> added [base:0x276600000, size:0x200000] to /memory
[0003.722] I> added [base:0x277000000, size:0x200000] to /memory
[0003.728] I> Updated memory info to DTB
[0003.732] E> add_disp_param: failed to get display params for du=1
[0003.740] E> “reset” doesn’t exist, creating
[0003.744] E> “pmc-reset-reason” doesn’t exist, creating
[0003.750] E> “pmic-reset-reason” doesn’t exist, creating
[0003.756] I> Adding ecid(00000001644036470c00000009028300) to DT
[0003.762] I> disabled_core_mask: 0xffffff0c
[0003.775] I> Add serial number:0320418051236 as DT property
[0003.784] I> Plugin-manager override starting
[0003.790] I> node /plugin-manager/fragement@0 matches
[0003.800] I> node /plugin-manager/fragement@4 matches
[0003.813] I> node /plugin-manager/fragment-sdwake-p3310-1000-300 matches
[0003.834] I> node /plugin-manager/fragement-pmon-p3310-1000-300 matches
[0003.843] I> node /plugin-manager/fragement-pmon-p3310-1000-800 matches
[0003.852] I> node /plugin-manager/fragment-devslp@0 matches
[0003.864] I> node /plugin-manager/fragment-500-pcie-config matches
[0003.879] I> node /plugin-manager/fragment-500-xusb-config matches
[0003.902] I> node /plugin-manager/fragment-p3310-c00-comm matches
[0003.915] I> node /plugin-manager/fragment-p3310-c00-pmic matches
[0003.926] I> node /plugin-manager/fragment-p3310-c01 matches
[0003.939] I> node /plugin-manager/fragment-p3310-c03 matches
[0003.977] I> node /plugin-manager/fragment-p3310-c00-camera matches
[0004.004] I> Disable plugin-manager status in FDT
[0004.008] I> Plugin-manager override finished successfully
[0004.014] I> tegrabl_load_kernel_and_dtb: Done
[0004.057] I> Kernel EP: 0x80800000, DTB: 0x80000000
U-Boot 2016.07-g0536cf2a27 (Dec 09 2019 - 22:43:10 -0800)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 68 ms (9.8 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5565140 bytes read in 187 ms (28.4 MiB/s)
Retrieving file: /boot/Image
34191368 bytes read in 858 ms (38 MiB/s)
append: root=PARTUUID=bb1e0ba5-e3b6-46d3-b4ce-dd9c75632ba4 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x9607d000 lut_mem2=0x2008@0x9607a000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet
Flattened Device Tree blob at 80000000
Booting using the fdt blob at 0x80000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000080000000, end 000000008005f9d7
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-1935) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Dec 9 22:52:02 PST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] Found tegra_fbmem2: 00800000@9607d000
[ 0.000000] Found lut_mem2: 00002008@9607a000
[ 4.275596] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[ 4.275596]
[ 4.284899] CPU: 2 PID: 1 Comm: chroot Not tainted 4.9.140-tegra #1
[ 4.291250] Hardware name: quill (DT)
[ 4.294963] Call trace:
[ 4.297485] [] dump_backtrace+0x0/0x198
[ 4.302948] [] show_stack+0x24/0x30
[ 4.308056] [] dump_stack+0x98/0xc0
[ 4.313160] [] panic+0x11c/0x298
[ 4.318011] [] do_exit+0xa04/0xa08
[ 4.323031] [] do_group_exit+0x40/0xa8
[ 4.328399] [] __wake_up_parent+0x0/0x40
[ 4.333941] [] el0_svc_naked+0x34/0x38
[ 4.339312] SMP: stopping secondary CPUs
[ 4.343289] Kernel Offset: disabled
[ 4.346827] Memory Limit: none
[ 4.349920] trusty-log panic notifier - trusty version Built: 22:43:54 Dec 9 2019 [ 4.365785] Rebooting in 5 seconds..
Thanks so much for any help!
