I feel that the problem has been spreading, and I have a similar problem using a custom board, so I use EVK to troubleshoot the problem, but it seems that there are more and more problems…
I find
@ShaneCCC why are not you able to release a simple patch that can be sourced from nvidia addressing that specific narrow issue?
The link[url] shared in the post above seems poorly documented
It appears that it suggests editing .dtsi file at Host PC,
for enabling the video driver to its prior state what edit is required exactly?
What is the proposed simple method[but for reflashing ] to update jetson setup from the file edited at Host PC?
-BR
AV
say " We may release device tree overlay(dtbo) for it in future release. "
When will this patch be released ???
Still working on it can’t tell which release will ready.
Next release should be coming soon at middle of August.
Does JetPack_5.0.2 have default support camera module board : 699-83326-1000-100 M ???
I use SDK manager to update jetpack 5.0.2 …
Can’t see ov5693 video device
xavier_5.0.2_kernel.log (83.7 KB)
/opt/nvidia/jetson-io/jetson-io.py
choose E3333 can’t see ov5693 video device
Should be e3326 instead of e3333.
But Jetpack 5.0.2 … can’t see e3326
Copy the attached file to /boot/ to run jetson-io again.
tegra194-p2822-camera-e3326-overlay.dtbo (4.2 KB)
Save and reboot to reconfigure pins
reboot …can see o5693
root@user-desktop:/home/user# dmesg | grep 5693
[ 12.077705] ov5693 2-0036: probing v4l2 sensor.
[ 12.078216] ov5693 2-0036: tegracam sensor driver:ov5693_v2.0.6
[ 12.976165] tegra-camrtc-capture-vi tegra-capture-vi: subdev ov5693 2-0036 bound
use gst command…
type or paste code here
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=1920,height=1080,framerate=30/1" ! nvvidconv ! nvoverlaysink
show WARNING …
WARNING: erroneous pipeline: no element “nvoverlaysink”
change gst command… is ok
gst-launch-1.0 nvarguscamerasrc sensor_id=0 ! 'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1, format=NV12' ! nvvidconv ! nvegltransform ! nveglglessink -e
How to enable tegra194-p2822-camera-e3326-overlay.dtbo by default ???
Need enable by jetson-io by future release.
you mean can’t use dts to enable ???
No, you can modify the dts to enable.
I didn’t find tegra194-p2822-camera-e3326-overlay.dts inJetpack 5.0.2…
Should be public in next release.
Can you give me tegra194-p2822-camera-e3326-overlay.dts first??
I need to modify it to a custom board after EVB verification
You can try dtc to dis-compiled the dtbo to dts
After comparing dts
Edit diff file
tegra194-p2822-0000-camera-e3326-a00.dtsi
tegra194-camera-e3326-a00.dtsi
But after compiling, some related modifications cannot be updated
seems to be overlaid,
How to cancel the overlay of e3326??
You can remove all of the overlay cameras and just only include e3326 relative dts to enable it.
