The two cameras have the same image
Hi
I used two OV5693 cameras attached to the CSI_C and CSI_E interfaces.After modifying the DT, the system can find video0 and video1, but when shown with nvgstcapture --cap-dev-node 0 and nvgstcapture --cap-dev-node 1, the images of the two cameras are the same
images is voide0
hello ben_blake,
could you please try to access camera sensor with nvcamerasrc, specify the sensor id into the pipeline.
for example,
$ gst-launch-1.0 nvcamerasrc sensor-id=X ! 'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1, format=NV12' ! nvoverlaysink -ev
Hi Jerry Chang
This one I’ve tried,is the same
Could it be a DT problem?
tegra186-camera-e3326-a00.dtsi
 * Copyright (c) 2015-2017, NVIDIA CORPORATION.  All rights reserved.
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful, but WITHOUT
 * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
 * FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for
 * more details.
 * You should have received a copy of the GNU General Public License
 * along with this program.  If not, see <http://www.gnu.org/licenses/>.
	host1x {
		vi@15700000 {
			num-channels = <2>;
			ports {
				#address-cells = <1>;
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					e3326_vi_in0: endpoint {
						csi-port = <2>;
						bus-width = <2>;
						remote-endpoint = <&e3326_csi_out0>;
				port@1 {
					reg = <1>;
					e3326_vi_in1: endpoint {
						csi-port = <4>;
						bus-width = <2>;
						remote-endpoint = <&e3326_csi_out1>;
		nvcsi@150c0000 {
			num-channels = <2>;
			channel@0 {
				reg = <0>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						e3326_csi_in0: endpoint@0 {
							csi-port = <2>;
							bus-width = <2>;
							remote-endpoint = <&e3326_ov5693_out0>;
					port@1 {
						reg = <1>;
						e3326_csi_out0: endpoint@1 {
							remote-endpoint = <&e3326_vi_in0>;
			channel@1 {
				reg = <1>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						e3326_csi_in1: endpoint@2 {
							csi-port = <4>;
							bus-width = <2>;
							remote-endpoint = <&e3326_ov5693_out1>;
					port@1 {
						reg = <1>;
						e3326_csi_out1: endpoint@3 {
							remote-endpoint = <&e3326_vi_in1>;
	i2c@3180000 {
		ov5693_c@10 {
			compatible = "nvidia,ov5693";
			/* I2C device address */
			reg = <0x10>;
			/* V4L2 device node location */
			devnode = "video0";
			/* Physical dimensions of sensor */
			physical_w = "3.674";
			physical_h = "2.738";
			/* Define any required hw resources needed by driver */
			/* ie. clocks, io pins, power sources */
			avdd-reg = "vana";
			iovdd-reg = "vif";
			/* Sensor output flip settings */
			vertical-flip = "true";
			mode0 { // OV5693_MODE_2592X1944
				mclk_khz = "24000";
				num_lanes = "2";
				tegra_sinterface = "serial_c";
				discontinuous_clk = "no";
				dpcm_enable = "false";
				cil_settletime = "0";
				active_w = "2592";
				active_h = "1944";
				pixel_t = "bayer_bggr";
				readout_orientation = "90";
				line_length = "2688";
				inherent_gain = "1";
				mclk_multiplier = "6.67";
				pix_clk_hz = "160000000";
				min_gain_val = "1.0";
				max_gain_val = "16";
				min_hdr_ratio = "1";
				max_hdr_ratio = "64";
				min_framerate = "1.816577";
				max_framerate = "30";
				min_exp_time = "34";
				max_exp_time = "550385";
			mode1 { //OV5693_MODE_2592X1458
				mclk_khz = "24000";
				num_lanes = "2";
				active_w = "2592";
				active_h = "1458";
			mode2 { //OV5693_MODE_1280X720
				mclk_khz = "24000";
				num_lanes = "2";
				active_w = "1280";
				active_h = "720";
				line_length = "1752";
				min_framerate = "2.787078";
				max_framerate = "120";
				min_exp_time = "22";
				max_exp_time = "358733";
			ports {
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					e3326_ov5693_out0: endpoint {
						csi-port = <2>;
						bus-width = <2>;
						remote-endpoint = <&e3326_csi_in0>;
	i2c@31c0000 {
		ov5693_e@10 {
			reg = <0x10>;
			devnode = "video1";
			avdd-reg = "vana";
			iovdd-reg = "vif";
				mclk_khz = "24000";
				num_lanes = "2";
				tegra_sinterface = "serial_e";
				active_w = "2592";
				active_h = "1944";
				mclk_khz = "24000";
				num_lanes = "2";
				active_w = "2592";
				active_h = "1458";
				mclk_khz = "24000";
				num_lanes = "2";
				active_w = "1280";
				active_h = "720";
			ports {
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					e3326_ov5693_out1: endpoint {
						csi-port = <4>;
						bus-width = <2>;
						remote-endpoint = <&e3326_csi_in1>;
	e3326_lens_ov5693@P5V27C {
		min_focus_distance = "0.0";
		hyper_focal = "0.0";
		focal_length = "2.67";
		f_number = "2.0";
		aperture = "2.0";
	tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		* Physical settings to calculate max ISO BW
		* num_csi_lanes = <>;
		* Total number of CSI lanes when all cameras are active
		* max_lane_speed = <>;
		* Max lane speed in Kbit/s
		* min_bits_per_pixel = <>;
		* Min bits per pixel
		* vi_peak_byte_per_pixel = <>;
		* Max byte per pixel for the VI ISO case
		* vi_bw_margin_pct = <>;
		* Vi bandwidth margin in percentage
		* max_pixel_rate = <>;
		* Max pixel rate in Kpixel/s for the ISP ISO case
		* isp_peak_byte_per_pixel = <>;
		* Max byte per pixel for the ISP ISO case
		* isp_bw_margin_pct = <>;
		* Isp bandwidth margin in percentage
		num_csi_lanes = <4>;
		max_lane_speed = <1500000>;
		min_bits_per_pixel = <10>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		max_pixel_rate = <160000>;
		isp_peak_byte_per_pixel = <5>;
		isp_bw_margin_pct = <25>;
		* The general guideline for naming badge_info contains 3 parts, and is as follows,
		* The first part is the camera_board_id for the module; if the module is in a FFD
		* platform, then use the platform name for this part.
		* The second part contains the position of the module, ex. “rear” or “front”.
		* The third part contains the last 6 characters of a part number which is found
		* in the module's specsheet from the vender.
		modules {
			module0 {
				badge = "e3326_rear_P5V27C";
				position = "rear";
				orientation = "1";
				drivernode0 {
					/* Declare PCL support driver (classically known as guid)  */
					pcl_id = "v4l2_sensor";
					/* Driver v4l2 device name */
					devname = "ov5693 2-0010";
					/* Declare the device-tree hierarchy to driver instance */
					proc-device-tree = "/proc/device-tree/i2c@3180000/ov5693_c@10";
				drivernode1 {
					pcl_id = "v4l2_lens";
					proc-device-tree = "/proc/device-tree/e3326_lens_ov5693@P5V27C/";
			module1 {
				badge = "e3326_front_P5V27C";
				position = "front";
				orientation = "1";
				drivernode0 {
					devname = "ov5693 6-0010";
					proc-device-tree = "/proc/device-tree/i2c@31c0000/ov5693_e@10";
				drivernode1 {
tegra186-quill-camera-plugin-manager.dtsi
fragment-e3326@0 {
			//ids = "3326-*";
			ids = ">=3310-1000-800";
			/* VI number of channels */
			override@0 {
				target = <&vi_base>;
				_overlay_ {
					num-channels=<2>;
			/* CSI number of channels */
			override@1 {
				target = <&csi_base>;
				_overlay_ {
					num-channels=<2>;
			/* tegra-camera-platform settings */
			override@2 {
				target = <&tcp>;
				_overlay_ {
					//max_pixel_rate = <200000>;
			/* Camera 0: Module */
			override@3 {
				target = <&e3326_cam0>;
				_overlay_ {
					status = "okay";
			override@4 {
				target = <&cam_module0>;
				_overlay_ {
					status = "okay";
					position = "rear";
					orientation = "1";
			override@5 {
				target = <&cam_module0_drivernode0>;
				_overlay_ {
					status = "okay";
			override@6 {
				target = <&cam_module0_drivernode1>;
				_overlay_ {
					status = "okay";
			/* Camera 0: VI */
			override@7 {
				target = <&vi_port0>;
				_overlay_ {
					status = "okay";
			override@8 {
				target = <&e3326_vi_in0>;
				_overlay_ {
					status = "okay";
					csi-port = <2>;
					bus-width = <2>;
			/* Camera 0: CSI */
			override@9 {
				target = <&csi_chan0>;
				_overlay_ {
					status = "okay";
			override@10 {
				target = <&csi_chan0_port0>;
				_overlay_ {
					status = "okay";
			override@11 {
				target = <&e3326_csi_in0>;
				_overlay_ {
					status = "okay";
					csi-port = <2>;
					bus-width = <2>;
			override@12 {
				target = <&csi_chan0_port1>;
				_overlay_ {
					status = "okay";
			override@13 {
				target = <&e3326_csi_out0>;
				_overlay_ {
					status = "okay";
			/* Camera 1: Module */
			override@14 {
				target = <&e3326_cam1>;
				_overlay_ {
					status = "okay";
			override@15 {
				target = <&cam_module1>;
				_overlay_ {
					status = "okay";
					position = "front";
					orientation = "1";
			override@16 {
				target = <&cam_module1_drivernode0>;
				_overlay_ {
					status = "okay";
			override@17 {
				target = <&cam_module1_drivernode1>;
				_overlay_ {
					status = "okay";
			/* Camera 1: VI */
			override@18 {
				target = <&vi_port1>;
				_overlay_ {
					status = "okay";
			override@19 {
				target = <&e3326_vi_in1>;
				_overlay_ {
					status = "okay";
					csi-port = <4>;
					bus-width = <2>;
			/* Camera 1: CSI */
			override@20 {
				target = <&csi_chan1>;
				_overlay_ {
					status = "okay";
			override@21 {
				target = <&csi_chan1_port0>;
				_overlay_ {
					status = "okay";
			override@22 {
				target = <&e3326_csi_in1>;
				_overlay_ {
					status = "okay";
					csi-port = <4>;
					bus-width = <2>;
			override@23 {
				target = <&csi_chan1_port1>;
				_overlay_ {
					status = "okay";
			override@24 {
				target = <&e3326_csi_out1>;
				_overlay_ {
					status = "okay";
			override@25 {
				target = <&{/gpio@2200000}>;
				_overlay_ {
					camera-control-input {
						status = "disabled";
					camera-control-output-low {
						gpio-hog;
//						gpios = <CAM0_RST_L 0 CAM0_PWDN 0>;
//						label = "cam0-rst", "cam0-pwdn";
							 CAM1_RST_L 0 CAM1_PWDN 0>;
						label = "cam0-rst", "cam0-pwdn",
							"cam1-rst", "cam1-pwdn";
						output-low;
						status = "okay";
					camera-control-output-high {
			override@26 {
				target = <&{/gpio@c2f0000}>;
				_overlay_ {
hello ben_blake,
looks both of your camera sensor connected to 0x10, do you have i2c mux device?
please refer to below device tree as example, thanks
sources/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-modules/tegra186-camera-e3333-a00.dtsi
Hi Jerry Chang
Instead of using i2c mux, I use a different i2c interface, and my camera address is 0x10.
I refer to this file,only i2c is different and everything else is the same
Who can help me check if this is caused by the problem of DT?
THANKS
hello ben_blake,
please try to access camera sensor with v4l2 standard controls instead,
for example,
v4l2-ctl -d /dev/video0 --set-fmt-video=width=2592,height=1944,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=10 --stream-to=test.raw
please check the raw files by 3rdparty viewing tools, such as 7yuv.
thanks
$ sudo media-ctl -p
Media controller API version 0.1.0
Media device information
driver          tegra-vi4
model           NVIDIA Tegra Video Input Device
serial
bus info
hw revision     0x3
driver version  0.0.0
Device topology
- entity 1: 150c0000.nvcsi-4 (2 pads, 2 links)
            type V4L2 subdev subtype Unknown flags 0
            device node name /dev/v4l-subdev0
	pad0: Sink
		<- "ov5693 6-0010":0 [ENABLED]
	pad1: Source
		-> "vi-output, ov5693 6-0010":0 [ENABLED]
- entity 2: 150c0000.nvcsi-2 (2 pads, 2 links)
            device node name /dev/v4l-subdev1
	pad0: Sink
		<- "ov5693 2-0010":0 [ENABLED]
	pad1: Source
		-> "vi-output, ov5693 2-0010":0 [ENABLED]
- entity 3: ov5693 6-0010 (1 pad, 1 link)
            type V4L2 subdev subtype Sensor flags 0
            device node name /dev/v4l-subdev2
	pad0: Source
		[fmt:SRGGB10/2592x1944 field:none]
		-> "150c0000.nvcsi-4":0 [ENABLED]
- entity 4: ov5693 2-0010 (1 pad, 1 link)
            device node name /dev/v4l-subdev3
	pad0: Source
		[fmt:SRGGB10/2592x1458 field:none]
		-> "150c0000.nvcsi-2":0 [ENABLED]
- entity 5: vi-output, ov5693 2-0010 (1 pad, 1 link)
            type Node subtype V4L flags 0
            device node name /dev/video0
	pad0: Sink
		<- "150c0000.nvcsi-2":1 [ENABLED]
- entity 6: vi-output, ov5693 6-0010 (1 pad, 1 link)
            device node name /dev/video1
	pad0: Sink
		<- "150c0000.nvcsi-4":1 [ENABLED]
hello ben_blake,
  1. had you check the raw files dumped by v4l2 standard controls?
  2. please measure the signals of camera sensor boards while using commands to access camera-0 and camera-1,
    thanks
