Now I have finished the driver of two cameras referring to the tegra210-camera-e3323-a00.dtsi.But now I need to drive 3 cameras. There was something wrong with my dts file. The dts file is as follows:
- Copyright (c) 2015-2016, NVIDIA CORPORATION. All rights reserved.
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- This program is distributed in the hope that it will be useful, but WITHOUT
- ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
- FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
- more details.
- You should have received a copy of the GNU General Public License
- along with this program. If not, see http://www.gnu.org/licenses/.
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
host1x {
vi {
num-channels = <3>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
e3323_vi_in0: endpoint {
csi-port = <0>;
bus-width = <4>;
remote-endpoint = <&ov23850_out0>;
port@1 {
reg = <1>;
e3323_vi_in1: endpoint {
csi-port = <2>;
bus-width = <4>;
remote-endpoint = <&ov23850_out1>;
port@2 {
reg = <2>;
e3323_vi_in2: endpoint {
csi-port = <4>;
bus-width = <4>;
remote-endpoint = <&ov23850_out2>;
i2c@546c0000 {
ov23850_a@48 {
compatible = "nvidia,ov23850";
reg = <0x48>;
/* Physical dimensions of sensor */
physical_w = "7.3998";
physical_h = "5.5998";
/* Sensor Model */
sensor_model ="ov23850";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
dvdd-reg = "vdig";
iovdd-reg = "vif";
vcmvdd-reg = "vvcm";
/* Defines number of frames to be dropped by driver internally after applying */
/* sensor crop settings. Some sensors send corrupt frames after applying */
/* crop co-ordinates */
post_crop_frame_drop = "0";
mode0 { // OV23850_MODE_5632X4224
mclk_khz = "24000";
num_lanes = "4";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1280";
active_h = "720";
pixel_t = "yuyv";
readout_orientation = "270";
line_length = "6000";
inherent_gain = "1";
mclk_multiplier = "25";
pix_clk_hz = "600000000";
min_gain_val = "1.0";
max_gain_val = "15.5";
min_hdr_ratio = "1";
max_hdr_ratio = "64";
min_framerate = "3.05185";
max_framerate = "20.8";
min_exp_time = "20";
max_exp_time = "327350";
embedded_metadata_height = "0";
mode1 { // OV23850_MODE_5632X3168
mclk_khz = "24000";
num_lanes = "4";
active_w = "1280";
active_h = "720";
pixel_t = "yuyv";
line_length = "5922";
min_framerate = "3.09135";
max_framerate = "30";
min_exp_time = "19.74";
max_exp_time = "323094";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
ov23850_out0: endpoint {
csi-port = <0>;
bus-width = <4>;
remote-endpoint = <&e3323_vi_in0>;
lc898212@72 {
compatible = "nvidia,lc898212";
reg = <0x72>;
type = "default";
min_focus_distance = "10.0"; /* 1.0f/0.1f */
hyper_focal = "0.2"; /* 1.0f/5.0f */
focal_length = "4.73";
f_number = "2.2";
aperture = "2.2";
support_mfi = "true";
i2c@7000c000 {
ov23850_c@48 {
reg = <0x48>;
/* Sensor Model */
avdd-reg = "vana";
dvdd-reg = "vdig";
iovdd-reg = "vif";
mclk_khz = "24000";
num_lanes = "4";
tegra_sinterface = "serial_c";
active_w = "1280";
active_h = "720";
pixel_t = "yuyv";
mclk_khz = "24000";
num_lanes = "4";
active_w = "1280";
active_h = "720";
pixel_t = "yuyv";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
ov23850_out1: endpoint {
csi-port = <2>;
bus-width = <4>;
remote-endpoint = <&e3323_vi_in1>;
lc898212@72 {
reg = <0x72>;
/* physical camera layer interface tags */
type = "default";
f_number = "2.2";
aperture = "2.2";
i2c@7000c500 {
ov23850_e@48 {
reg = <0x48>;
/* Sensor Model */
avdd-reg = "vana";
dvdd-reg = "vdig";
iovdd-reg = "vif";
mclk_khz = "24000";
num_lanes = "4";
active_w = "1280";
active_h = "720";
pixel_t = "yuyv";
mclk_khz = "24000";
num_lanes = "4";
active_w = "1280";
active_h = "720";
pixel_t = "yuyv";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
ov23850_out2: endpoint {
csi-port = <4>;
bus-width = <4>;
remote-endpoint = <&e3323_vi_in2>;
lc898212@72 {
reg = <0x72>;
type = "default";
f_number = "2.2";
aperture = "2.2";
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. “rear” or “front”.
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "e3323_bottom_CH06P1";
position = "bottom";
orientation = "3";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver's v4l2 device name */
devname = "ov23850 6-0048";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/host1x/i2c@546c0000/ov23850_a@48";
module1 {
badge = "e3323_top_CH06P1";
position = "top";
orientation = "3";
drivernode0 {
devname = "ov23850 0-0048";
proc-device-tree = "/proc/device-tree/i2c@7000c000/ov23850_c@48";
module2 {
position = "top";
orientation = "3";
drivernode0 {
devname = "ov23850 2-0048";
proc-device-tree = "/proc/device-tree/i2c@7000c500/ov23850_e@48";
tegra210-camera-e3323-a00.txt (10.4 KB)
