Thanks for the reply, linuxdev!
Unfortunately I am more confused…
I’m not sure if using the dtc to compile my altered dts is the path I should even be taking, as there is no mention of it in the development guide steps.
The steps listed in the Devguide are:
- Locate the following file:
hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-a00-00-bast.dsi
- In the DSI, remove the following line:
#include
- Replace the following line with an include statement specifying the DTSI of your new device
#include
After performing those steps, rebuilding and rebooting from a new kernel, the sensor is not recognized as a video device. I have ensured that the names in the .dtsi and driver file match.
Here is my .dtsi for the device
* Copyright (c) 2015-2017, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
host1x {
vi@15700000 {
num-channels = <6>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
e3333_vi_in0: endpoint {
csi-port = <0>;
bus-width = <2>;
remote-endpoint = <&e3333_csi_out0>;
port@1 {
reg = <1>;
e3333_vi_in1: endpoint {
csi-port = <1>;
bus-width = <2>;
remote-endpoint = <&e3333_csi_out1>;
port@2 {
reg = <2>;
e3333_vi_in2: endpoint {
csi-port = <2>;
bus-width = <2>;
remote-endpoint = <&e3333_csi_out2>;
port@3 {
reg = <3>;
e3333_vi_in3: endpoint {
csi-port = <3>;
bus-width = <2>;
remote-endpoint = <&e3333_csi_out3>;
port@4 {
reg = <4>;
e3333_vi_in4: endpoint {
csi-port = <4>;
bus-width = <2>;
remote-endpoint = <&e3333_csi_out4>;
port@5 {
reg = <5>;
e3333_vi_in5: endpoint {
csi-port = <5>;
bus-width = <2>;
remote-endpoint = <&e3333_csi_out5>;
nvcsi@150c0000 {
num-channels = <6>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3333_csi_in0: endpoint@0 {
csi-port = <0>;
bus-width = <2>;
remote-endpoint = <&e3333_ar0144_out0>;
port@1 {
reg = <1>;
e3333_csi_out0: endpoint@1 {
remote-endpoint = <&e3333_vi_in0>;
channel@1 {
reg = <1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3333_csi_in1: endpoint@2 {
csi-port = <1>;
bus-width = <2>;
remote-endpoint = <&e3333_ar0144_out1>;
port@1 {
reg = <1>;
e3333_csi_out1: endpoint@3 {
remote-endpoint = <&e3333_vi_in1>;
channel@2 {
reg = <2>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3333_csi_in2: endpoint@4 {
csi-port = <2>;
bus-width = <2>;
remote-endpoint = <&e3333_ar0144_out2>;
port@1 {
reg = <1>;
e3333_csi_out2: endpoint@5 {
remote-endpoint = <&e3333_vi_in2>;
channel@3 {
reg = <3>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3333_csi_in3: endpoint@6 {
csi-port = <3>;
bus-width = <2>;
remote-endpoint = <&e3333_ar0144_out3>;
port@1 {
reg = <1>;
e3333_csi_out3: endpoint@7 {
remote-endpoint = <&e3333_vi_in3>;
channel@4 {
reg = <4>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3333_csi_in4: endpoint@8 {
csi-port = <4>;
bus-width = <2>;
remote-endpoint = <&e3333_ar0144_out4>;
port@1 {
reg = <1>;
e3333_csi_out4: endpoint@9 {
remote-endpoint = <&e3333_vi_in4>;
channel@5 {
reg = <5>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3333_csi_in5: endpoint@10 {
csi-port = <5>;
bus-width = <2>;
remote-endpoint = <&e3333_ar0144_out5>;
port@1 {
reg = <1>;
e3333_csi_out5: endpoint@11 {
remote-endpoint = <&e3333_vi_in5>;
i2c@3180000 {
tca9548@77 {
i2c@0 {
ar0144_a@10 {
compatible = "nvidia,ar0144";
reg = <0x10>;
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "3.674";
physical_h = "2.738";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
iovdd-reg = "vif";
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* mclk_khz = "";
* Standard MIPI driving clock, typically 24MHz
* num_lanes = "";
* Number of lane channels sensor is programmed to output
* tegra_sinterface = "";
* The base tegra serial interface lanes are connected to
* discontinuous_clk = "";
* The sensor is programmed to use a discontinuous clock on MIPI lanes
* dpcm_enable = "true";
* The sensor is programmed to use a DPCM modes
* cil_settletime = "";
* MIPI lane settle time value.
* A "0" value attempts to autocalibrate based on mclk_multiplier
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* line_length = "";
* Pixel line length (width) for sensor mode.
* This is used to calibrate features in our camera stack.
* mclk_multiplier = "";
* Multiplier to MCLK to help time hardware capture sequence
* TODO: Assign to PLL_Multiplier as well until fixed in core
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* inherent_gain = "";
* Gain obtained inherently from mode (ie. pixel binning)
* min_gain_val = ""; (floor to 6 decimal places)
* max_gain_val = ""; (floor to 6 decimal places)
* Gain limits for mode
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (us)
* min_hdr_ratio = "";
* max_hdr_ratio = "";
* HDR Ratio limits for mode
* min_framerate = "";
* max_framerate = "";
* Framerate limits for mode (fps)
mode0 { // ar0144_MODE_2592X1944
mclk_khz = "24000";
num_lanes = "2";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1280";
active_h = "800";
pixel_t = "bayer_bggr";
readout_orientation = "90";
line_length = "2688";
inherent_gain = "1";
mclk_multiplier = "6.67";
pix_clk_hz = "160000000";
min_gain_val = "1.0";
max_gain_val = "16";
min_hdr_ratio = "1";
max_hdr_ratio = "64";
min_framerate = "1.816577";
max_framerate = "30";
min_exp_time = "34";
max_exp_time = "550385";
/* mode1 { //ar0144_MODE_2592X1458
mclk_khz = "24000";
num_lanes = "2";
active_w = "2592";
active_h = "1458";
mode2 { //ar0144_MODE_1280X720
mclk_khz = "24000";
num_lanes = "2";
active_w = "1280";
active_h = "720";
line_length = "1752";
min_framerate = "2.787078";
max_framerate = "120";
min_exp_time = "22";
max_exp_time = "358733";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3333_ar0144_out0: endpoint {
csi-port = <0>;
bus-width = <2>;
remote-endpoint = <&e3333_csi_in0>;
i2c@1 {
ar0144_b@10 {
reg = <0x10>;
devnode = "video1";
physical_w = "3.671";
avdd-reg = "vana";
iovdd-reg = "vif";
* mclk_khz = "";
* num_lanes = "";
* active_w = "";
* active_h = "";
* pixel_t = "";
* line_length = "";
* pix_clk_hz = "";
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_b";
active_w = "1280";
active_h = "800";
mclk_khz = "24000";
num_lanes = "2";
active_w = "2592";
active_h = "1458";
mclk_khz = "24000";
num_lanes = "2";
active_w = "1280";
active_h = "720";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3333_ar0144_out1: endpoint {
csi-port = <1>;
bus-width = <2>;
remote-endpoint = <&e3333_csi_in1>;
i2c@2 {
ar0144_c@36 {
reg = <0x10>;
devnode = "video2";
avdd-reg = "vana";
iovdd-reg = "vif";
* mclk_khz = "";
* num_lanes = "";
* active_w = "";
* active_h = "";
* pixel_t = "";
* line_length = "";
* pix_clk_hz = "";
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_c";
active_w = "1280";
active_h = "800";
/*mode1 { //ar0144_MODE_2592X1458
mclk_khz = "24000";
num_lanes = "2";
active_w = "2592";
active_h = "1458";
mclk_khz = "24000";
num_lanes = "2";
active_w = "1280";
active_h = "720";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3333_ar0144_out2: endpoint {
csi-port = <2>;
bus-width = <2>;
remote-endpoint = <&e3333_csi_in2>;
i2c@3 {
ar0144_d@10 {
reg = <0x10>;
devnode = "video3";
avdd-reg = "vana";
iovdd-reg = "vif";
* mclk_khz = "";
* num_lanes = "";
* active_w = "";
* active_h = "";
* pixel_t = "";
* line_length = "";
* pix_clk_hz = "";
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_d";
active_w = "2592";
active_h = "1944";
mclk_khz = "24000";
num_lanes = "2";
active_w = "2592";
active_h = "1458";
mclk_khz = "24000";
num_lanes = "2";
active_w = "1280";
active_h = "720";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3333_ar0144_out3: endpoint {
csi-port = <3>;
bus-width = <2>;
remote-endpoint = <&e3333_csi_in3>;
i2c@4 {
ar0144_e@10 {
reg = <0x10>;
devnode = "video4";
avdd-reg = "vana";
iovdd-reg = "vif";
* mclk_khz = "";
* num_lanes = "";
* active_w = "";
* active_h = "";
* pixel_t = "";
* line_length = "";
* pix_clk_hz = "";
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_e";
active_w = "1280";
active_h = "800";
mclk_khz = "24000";
num_lanes = "2";
active_w = "2592";
active_h = "1458";
mclk_khz = "24000";
num_lanes = "2";
active_w = "1280";
active_h = "720";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3333_ar0144_out4: endpoint {
csi-port = <4>;
bus-width = <2>;
remote-endpoint = <&e3333_csi_in4>;
i2c@5 {
ar0144_f@10 {
reg = <0x10>;
devnode = "video5";
avdd-reg = "vana";
iovdd-reg = "vif";
* mclk_khz = "";
* num_lanes = "";
* active_w = "";
* active_h = "";
* pixel_t = "";
* line_length = "";
* pix_clk_hz = "";
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_f";
active_w = "1280";
active_h = "800";
mclk_khz = "24000";
num_lanes = "2";
active_w = "2592";
active_h = "1458";
mclk_khz = "24000";
num_lanes = "2";
active_w = "1280";
active_h = "720";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3333_ar0144_out5: endpoint {
csi-port = <5>;
bus-width = <2>;
remote-endpoint = <&e3333_csi_in5>;
e3333_lens_ar0144@P5V27C {
min_focus_distance = "0.0";
hyper_focal = "0.0";
focal_length = "2.67";
f_number = "2.0";
aperture = "2.0";
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* Set this to the highest pix_clk_hz out of all available modes.
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <12>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <160000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. “rear” or “front”.
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "e3333_bottomleft_P5V27C";
position = "bottomleft";
orientation = "1";
drivernode0 {
pcl_id = "v4l2_sensor";
devname = "ar0144 30-0036";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@77/i2c@0/ar0144_a@10";
drivernode1 {
pcl_id = "v4l2_lens";
proc-device-tree = "/proc/device-tree/e3333_lens_ar0144@P5V27C/";
module1 {
badge = "e3333_centerleft_P5V27C";
position = "centerleft";
orientation = "1";
drivernode0 {
devname = "ar0144 31-0036";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@77/i2c@1/ar0144_b@10";
drivernode1 {
module2 {
badge = "e3333_centerright_P5V27C";
position = "centerright";
orientation = "1";
drivernode0 {
devname = "ar0144 32-0036";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@77/i2c@2/ar0144_c@10";
drivernode1 {
module3 {
badge = "e3333_topleft_P5V27C";
position = "topleft";
orientation = "1";
drivernode0 {
devname = "ar0144 33-0036";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@77/i2c@3/ar0144_d@10";
drivernode1 {
module4 {
badge = "e3333_bottomright_P5V27C";
position = "bottomright";
orientation = "1";
drivernode0 {
devname = "ar0144 34-0036";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@77/i2c@4/ar0144_d@10";
drivernode1 {
module5 {
badge = "e3333_topright_P5V27C";
position = "topright";
orientation = "1";
drivernode0 {
devname = "ar0144 35-0036";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@77/i2c@5/ar0144_e@10";
drivernode1 {
What else can I troubleshoot?
