Jetpack 7.2. Jetson Orin Nano Super (8gb) Pytorch for Compute Capability 8.7
Hi.
I have Jetson Orin Nano Reference Developer Kit Super (8gb)
Installed Jetpack 7.2.
Tried to compile ENGINE file from .pt and checked versions of installed software:
python3 -c “import torch; print(torch.version, torch.version.cuda, torch.cuda.is_available(), torch.cuda.get_device_name(0))”
I got gollowing message with WARNING:
/home/jetson1/.local/lib/python3.12/site-packages/torch/cuda/init.py:422: UserWarning: Found GPU0 Orin which is of compute capability (CC) 8.7.
The following list shows the CCs this version of PyTorch was built for and the hardware CCs it supports:
  • 8.0 which supports hardware CC >=8.0,<9.0 except {8.7}
  • 9.0 which supports hardware CC >=9.0,<10.0
  • 10.0 which supports hardware CC >=10.0,<11.0 except {10.1}
  • 11.0 which supports hardware CC >=11.0,<12.0
  • 12.0 which supports hardware CC >=12.0,<13.0
    No published PyTorch CUDA builds for release 2.13.0+cu132 support this GPU. Visit https://pytorch.org/get-started/locally/ to find a compatible release.
So I cant install correct version of pytorch for Jetpack 7.2 (jetson orin nano super).
Where to find correct version and how to upgrade it properly?
Tried to find here: Start Locally | PyTorch (<https://docs.pytorch.org/get-started/locally/>)
But still not sure which one to install to get full compatibility with Compute Capability 8.7.
Checked current libs:
python3 -c “import sys, cv2, torch, torchvision, ultralytics; print(f’Python: {sys.version.split()[0]}\nPyTorch: {torch.version}\nTorchvision: {torchvision.version}\nUltralytics (YOLO): {ultralytics.version}\nOpenCV: {cv2.version}')” && gst-inspect-1.0 --version | head -n 1
python3 -c “import cv2; print(‘Версия OpenCV:’, cv2.version); print(cv2.getBuildInformation())” | grep -E “GStreamer|NVIDIA|CUDA”
pip list | grep -E “opencv|ultralytics|torch|gpio”
/usr/local/cuda/bin/nvcc --version
dpkg -l | grep -E “opencv|gstreamer|v4l2|gpiod”
ii gir1.2-gstreamer-1.0:arm64 1.24.2-1ubuntu0.1 arm64 GObject introspection data for the GStreamer library
ii gpiod 1.6.3-1.1build1 arm64 Tools for interacting with Linux GPIO character device - binary
ii gstreamer1.0-alsa:arm64 1.24.2-1ubuntu0.4 arm64 GStreamer plugin for ALSA
ii gstreamer1.0-gl:arm64 1.24.2-1ubuntu0.4 arm64 GStreamer plugins for GL
ii gstreamer1.0-gtk3:arm64 1.24.2-1ubuntu1.5 arm64 GStreamer plugin for GTK+3
ii gstreamer1.0-libcamera:arm64 0.2.0-3fakesync1build6 arm64 complex camera support library (GStreamer plugin)
ii gstreamer1.0-packagekit 1.2.8-2ubuntu1.5 arm64 GStreamer plugin to install codecs using PackageKit
ii gstreamer1.0-pipewire:arm64 1.0.5-1ubuntu3.3 arm64 GStreamer 1.0 plugin for the PipeWire multimedia server
ii gstreamer1.0-plugins-bad:arm64 1.24.2-1ubuntu4 arm64 GStreamer plugins from the “bad” set
ii gstreamer1.0-plugins-base:arm64 1.24.2-1ubuntu0.4 arm64 GStreamer plugins from the “base” set
ii gstreamer1.0-plugins-base-apps 1.24.2-1ubuntu0.4 arm64 GStreamer helper programs from the “base” set
ii gstreamer1.0-plugins-good:arm64 1.24.2-1ubuntu1.5 arm64 GStreamer plugins from the “good” set
ii gstreamer1.0-plugins-ugly:arm64 1.24.1-1build1 arm64 GStreamer plugins from the “ugly” set
ii gstreamer1.0-tools 1.24.2-1ubuntu0.1 arm64 Tools for use with GStreamer
ii gstreamer1.0-x:arm64 1.24.2-1ubuntu0.4 arm64 GStreamer plugins for X11 and Pango
ii libgpiod-dev:arm64 1.6.3-1.1build1 arm64 C library for interacting with Linux GPIO device - static libraries and headers
ii libgpiod2t64:arm64 1.6.3-1.1build1 arm64 C library for interacting with Linux GPIO device - shared libraries
ii libgstreamer-gl1.0-0:arm64 1.24.2-1ubuntu0.4 arm64 GStreamer GL libraries
ii libgstreamer-opencv1.0-0:arm64 1.24.2-1ubuntu4 arm64 GStreamer OpenCV libraries
ii libgstreamer-plugins-bad1.0-0:arm64 1.24.2-1ubuntu4 arm64 GStreamer libraries from the “bad” set
ii libgstreamer-plugins-base1.0-0:arm64 1.24.2-1ubuntu0.4 arm64 GStreamer libraries from the “base” set
ii libgstreamer-plugins-base1.0-dev 1.24.2-1ubuntu0.4 arm64 GStreamer development files for libraries from the “base” set
ii libgstreamer-plugins-good1.0-0:arm64 1.24.2-1ubuntu1.5 arm64 GStreamer development files for libraries from the “good” set
ii libgstreamer-plugins-good1.0-dev 1.24.2-1ubuntu1.5 arm64 GStreamer development files for libraries from the “good” set
ii libgstreamer1.0-0:arm64 1.24.2-1ubuntu0.1 arm64 Core GStreamer libraries and elements
ii libgstreamer1.0-dev:arm64 1.24.2-1ubuntu0.1 arm64 GStreamer core development files
ii libgtk-4-media-gstreamer 4.14.5+ds-0ubuntu0.10 arm64 GStreamer media backend for the GTK graphical user interface library
ii libopencv 4.8.0-3-g6ef37b4 arm64 Open Computer Vision Library
ii libopencv-calib3d406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision Camera Calibration library
ii libopencv-contrib406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision contrlib library
ii libopencv-core406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision core library
ii libopencv-dev 4.8.0-3-g6ef37b4 arm64 Open Computer Vision Library
ii libopencv-dnn406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision Deep neural network module
ii libopencv-features2d406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision Feature Detection and Descriptor Extraction library
ii libopencv-flann406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision Clustering and Search in Multi-Dimensional spaces library
ii libopencv-highgui406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision High-level GUI and Media I/O library
ii libopencv-imgcodecs406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision Image Codecs library
ii libopencv-imgproc406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision Image Processing library
ii libopencv-ml406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision Machine Learning library
ii libopencv-objdetect406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision Object Detection library
ii libopencv-photo406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision computational photography library
ii libopencv-python 4.8.0-3-g6ef37b4 arm64 Open Computer Vision Library
ii libopencv-samples 4.8.0-3-g6ef37b4 arm64 Open Computer Vision Library
ii libopencv-shape406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision shape descriptors and matchers library
ii libopencv-stitching406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision image stitching library
ii libopencv-video406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision Video analysis library
ii libopencv-videoio406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision Video I/O library
ii libopencv-viz406t64:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 computer vision 3D data visualization library
ii libv4l2rds0t64:arm64 1.26.1-4build3 arm64 Video4Linux Radio Data System (RDS) decoding library
ii nvidia-l4t-gstreamer 39.2.0-20260601141651 arm64 NVIDIA GST Application files
ii nvidia-opencv 7.2-b187 arm64 NVIDIA OpenCV Meta Package
ii nvidia-opencv-dev 7.2-b187 arm64 NVIDIA OpenCV dev Meta Package
ii opencv-licenses 4.8.0-3-g6ef37b4 arm64 Open Computer Vision Library
ii opencv-samples-data 4.8.0-3-g6ef37b4 arm64 Open Computer Vision Library
ii python3-opencv:arm64 4.6.0+dfsg-13.1ubuntu1 arm64 Python 3 bindings for the computer vision library
Now I cant even uninstall current version (not mentioning about lack of knowledge which correct link or command to use for install…
Found some link with versions, but maximum Jetpack 7.1 supported for now… https://docs.nvidia.com/deeplearning/frameworks/install-pytorch-jetson-platform-release-notes/pytorch-jetson-rel.html>
This message is a harmless warning:
You can install upstream PyTorch on JetPack 7.2+Orin with the below command:
$ pip3 install torch torchvision --index-url https://download.pytorch.org/whl/cu132
Below is the command for ignoring the warning for your reference:
import warnings
warnings.filterwarnings("ignore", message=".*Found GPU.*compute capability.*")
Please find the comment below for details:
ISNt it for x86_64 on that link ? I have Jetson Orin Nano board. Will it fit?
And also which Numpy and Gstreamer versions work together?
OpenCV 4.8.0 ↔ NumPy 1.26.4 ↔ CuPy 13.x ↔ TensorRT 10.16 ↔ PyTorch 2.5/2.6 ?
OpenCV 4.8.0 ↔ NumPy ??? ↔ CuPy 13.x ↔ TensorRT 10.16 ↔ PyTorch ???
It will install the aarch64 packages from the https://download.pytorch.org/whl/cu132.
Is this question for Deepstream? There is no dependency between TensorRT and PyTorch.
Thanks. Just trying to restore original Jetpack 7.2 versions after occasional updating libraries in main system with flag “–break-system-packages” :) Want to restore original list, to install the rest (non-standard) into the venv. Want to use native NVIDIA utils for the jetpack 7.2. is there any easy way to restore the package without flashing all SSD?
Why I asked about NumPy - there is a message shown in my script running inside the venv. Tthe same message when I check by the command python3 -c “import cv2; print(cv2.version)” outside the venv…
even when I run such script inside the venv (with checked OpenCV = 5.0.0)
So maybe I compiled some .Engine file on the old 1.xx version (apparently manually installed into the main system), and after System updating so many messages appeared… ? Is it NORMAL situation with the libraries as I revised them below:
What should I do to bring things into order?
thx
hi again. I have Jetson Orin Nano Super (8gb) board,
I installed pytorch to VENV from there: $ pip3 install torch torchvision --index-url https://download.pytorch.org/whl/cu132
BUT should I install it with some flag for Orin (sm_87)?
Many times to compile .engine file inside .venv
resulted :
ONNX: starting export with onnx 1.22.0 opset 18…
ONNX: slimming with onnxslim 0.1.95…
ONNX: export success ✅ 7.7s, saved as ‘yolo11n.onnx’ (10.2 MB)
TensorRT: starting export with TensorRT 10.16.2.10…
TensorRT: input “images” with shape(1, 3, 640, 640) DataType.FLOAT
TensorRT: output “output0” with shape(1, 84, 8400) DataType.FLOAT
TensorRT: building FP16 engine as yolo11n.engine
TensorRT: export success ✅ 418.5s, saved as ‘yolo11n.engine’ (8.1 MB)
Export complete (419.8s)
Results saved to /home/jetson1/Desktop/yolo11/yolo11n.engine
(Warm-up)…
Loading yolo11n.engine for TensorRT inference…
[TRT] [I] Loaded engine size: 8 MiB
[TRT] [I] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +9, now: CPU 0, GPU 14 (MiB)
(FPS): 86.06
Looks OK right? BUT NO ! if I try to get metadata from that .engine file or open it with
/usr/src/tensorrt/bin/trtexec --loadEngine=yolo11n.engine
&&& RUNNING TensorRT.trtexec [TensorRT v101602] [b10]
&&&& FAILED TensorRT.trtexec [TensorRT v101602] [b10] # /usr/src/tensorrt/bin/trtexec --loadEngine=yolo11n.engine
Where to get Pytorch for Jetson orin nano board (Jetpack 7.2) (sm_87)?
Or I need to use that WHL from https://download.pytorch.org/whl/torch/
image?
Or I need to make adopted lib from “torch-2.5.1-cp312-cp312-linux_aarch64.whl” directly for my board ?
Or how to compile .engine files to keep correct working through native trtexec ?
thx
I reinstalled jetpack completely, created venv environment and tried to install pytorch there according to your instructions: run from inside
pip install torch torchvision torchaudio --index-url https://download.pytorch.org/whl/cu132
Some packages installed but errors in the end:
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from torchvision) (1.16.0)
Downloading https://download-r2.pytorch.org/whl/torchvision-0.1.6-py3-none-any.whl (16 kB)
ERROR: Cannot install torch and torchaudio==2.2.0 because these package versions have conflicting dependencies.
The conflict is caused by:
The user requested torch
torchaudio 2.2.0 depends on torch==2.2.0
To fix this you could try to:
  1. loosen the range of package versions you’ve specified
  2. remove package versions to allow pip attempt to solve the dependency conflict
ERROR: ResolutionImpossible: for help visit Dependency Resolution - pip documentation v26.3.dev0
So do I need to find another version matched with my JetPack 7.2 (Python 3.12, CUDA 13.2)?
maybe
  • torch-2.5.1+nv24.11-cp312-cp312-linux_aarch64.whl ?
  • torchvision-0.20.1+nv24.11-cp312-cp312-linux_aarch64.whl ?
  • torchaudio-2.5.1+nv24.11-cp312-cp312-linux_aarch64.whl ?
Is there a correct link there or need some flags? please send full command to be sure.
thx
there is temporary solution found without making own wheels.
pip install torch==2.12.1+cu132 torchvision==0.27.1+cu132 torchaudio --pre --index-url https://download.pytorch.org/whl/cu132
uses pre-release version, installs with flags (inside VENV just not to break native system packages). Kind of that…
Sorry for the late update.
No, you don’t need to. The upstream pacakge contains sm_80 that can work on Orin already.
It looks like the installer is finding an old package so trigger this error (there is no 2.2.0+python3.12 package).
Is there any package insider your virtual environment depends on torch 2.2.0?
Is the virtual environment created with Python 3.12?
Here is full review what the CLEAN os Ubuntu 24.04 +jetpack 7.2 from the USB contained initially and what had been installed into the VENV.
I spent several days jut to wind how to get it works! Why native jetpack downt contain the right versions out of the box? And why no proper wheels without breaking system flags usage?
This time I just reinstalled full OS+jetpack from scratch, than was trying to install the rest libs I need (pytorch, torchvision, Simpy, Onnx, ultralytics, Opencv).
Created VENV (because as you know, its impossible to install all these libs without breack-system-package flags into the main system), so I decided to keep it safe and install all the rest into the venv. For normal use NATIVE OPENCV and GSTREAMER with hardware GPU support.
If I used standard link you gave me (just pip install torch torchvision torchaudio --index-url https://download.pytorch.org/whl/cu132 without flags), some issues appeared with coordination between NATIVE system versions and installed pytorch components versions. Thats why I installed with that flag, to avoid conflict of the libs, and than also downgraded numpy from 2.5.2 to 1.26.4 + opencv-python from 5.0.0.93 to 4.8.0
There is the list what was initially in system and after installed VENV with another versions.
OS initial installed into VENV (works)
OS L4T R39.2.1 L4T R39.2.1
L4T Nvidia-l4t-core 39.2.1-20260806224157 Nvidia-l4t-core 39.2.1-20260806224157
Jetpack 7.2.1-b49 7.2.1-b49
Machine aarch64 aarch64
System Linux Linux
Distribution Ubuntu 24.04 Ubuntu 24.04
Release 6.8.12-1021 tegra 6.8.12-1021 tegra
CUDA 13.2.86 13.2.86
cuDNN _9.20.0 _9.20.0
TensorRT 10.16.2.10 10.16.2.10
VPI 4.1.4.0 4.1.4.0
Vulkan 1.4.321 1.4.321
OpenCV 4.8.0. with cuda NO 4.8.0. with cuda NO
P-number p3767-0005 p3767-0005
Soc Tegra 234 Tegra 234
L4T L4T R39.2.1 L4T R39.2.1
Jetpack 7.2 7.2
Cuda Arch Bin 8.7 8.7
python –version Python 3.12.3 Python 3.12.3
Nvidia-smi NVIDIA-SMI 595.78 NVIDIA-SMI 595.78
Driver Version: 595.78 Driver Version: 595.78
CUDA Version: 13.2 CUDA Version: 13.2
pip3 –version pip 24.0 from /usr/lib/python3/dist-packages/pip (python 3.12) pip 26.2.1 from /home/jetson1/venv1/lib/python3.12/site-packages/pip (python 3.12)
libjpeg-dev:arm64 8c-2ubuntu11 0.3.26+ds-1ubuntu0.1
libopenblas-dev:arm64 0.3.26+ds-1ubuntu0.1 0.3.26+ds-1ubuntu0.1
python3-pip 24.0+dfsg-1ubuntu1.3 24.0+dfsg-1ubuntu1.3
zlib1g:arm64 1:1.3.dfsg-3.1ubuntu2.1 1:1.3.dfsg-3.1ubuntu2.1
zlib1g-dev:arm64 1:1.3.dfsg-3.1ubuntu2.1 1:1.3.dfsg-3.1ubuntu2.1
Libopenblas-dev not installed 0.3.26+ds-1ubuntu0.1
numpy 1.26.4 numpy (2.5.2) — versions conflict possible (2.5.2) downgraded to native 1.26.4
SciPy 1.11.4 1.11.4
simpy not installed 4.1.2
onnx not installed 1.22.0
ultralytics not installed 8.4.120
Ultralytics-platform not installed 0.1.5
Ultralytics-platform not installed 2.1.6
opencv-python not installed Opencv-python (5.0.0.93) — performance issue possible 5.0.0.93 downgraded to 4.8.0
4.8.0 4.8.0
gstreamer 1.24.2 1.24.2
tensorrt 10.16.2.10-1+cuda13.2 10.16.2.10-1+cuda13.2
opencv 4.8.0-4-g18251aa 4.8.0-4-g18251aa
numpy 1.26.4 uses global ?
scipy 1.11.4 uses global ?
PyTorch not installed 2.12.1+cu132
Torchvision not installed 2.12.1+cu132
torchaudio not installed 2.11.0+cpu
Please tell me, is it OK? WHICH IS THE RIGHT WAY to get a proper versions of working Pytorch + ultralytics package without docker and without breaking system versions of the libs?
in curernt state all works without errors. But Im still thinking whether it worth using OpenCV 5.0 and numpy 2.5.2 versions (without downgrading) or maybe some MAIN os upgrade should be dome just to fit newer versions of the native wheels for Jetson Orin Nano (jetpack 7.2) ?
! significant note. If you run heavy engine/opencv tasks like creating .engine files with multi-batch parameters, ultralyticsupdates automatically and dragged with it NumPy 2.5.2 back !!!
native PyTorch for Jetson (NVIDIA) included into OpenCV (cv2) compiled by old good NumPy 1.x. [1, 2, 3]
Running pencv-python you leaned Python- OpenCV to overwrite NumPy up to 2.5.2.
It breakes the harmony and crashes your inference…
To avoid that just LOCK NumPy at stable 1.x. version:
  1. pip uninstall -y opencv-python opencv-python-headless
  2. pip install “numpy==1.26.4” --force-reinstall
  3. python3 -m venv /home/jetson1/venv1 --system-site-packages
  4. pip freeze > /home/jetson1/Desktop/models/requirements.txt
in the future install applications throught PIP with –no-deps
like this: pip install blabla-something --no-deps
It might help.
Do you get a working environment now?
To run Ultralytics software, you can check their installation steps (native/container) below:
Ultralytics has guide for Ultralytics installation and PyTorch installation on JetPack 7.2 linked above.
You just need to follow that. Except don’t use [export]. Just pip install ultralytics
