NO WAY TO USE GPU - TORCH NOT DETECTING GPU - CUDA 12.6 - JP 6.1 ORIN NANO
I have tried to install PyTorch torch-vision and torch-audio for my Jetson Orin Nano
I have used the pre-built one itself from the below website,
but im stil getting the same errors when im checking
and this too
meghana@meghana-desktop:~$ python -c “import torch; print(torch.version)”
2.10.0+cpu
why is it still cpu?
You can find the cuDSS library below:
The CPU PyTorch package is listed in the apt so you can check if any package (ex., TorchVision) has installed it to meet the dependencies.
now GPU is installed, why is it still not working?
i downloaded the pre-trained model yolov8s from the Ultralytics and I’m trying to train this model with my dataset to detect if the person is wearing a safety suit or not, basically a ppe detection.
so i downloaded the dataset from the Kaggle and below is the data.yaml file for the dataset
how do i go about it?
You have multiple Python environments. You installed PyTorch with CUDA in yoloenv but installed Ultralytics in the local system environment (see the path of Python packages in your logs; they are different for PyTorch with CUDA vs..Ultralytics). You should uninstall Ultralytics from system environment and install it to yoloenv.
deactivate
pip uninstall ultralytics -y
source yoloenv/bin/activate
pip install ultralytics
~0324
Could you try to remove the torch-2.10.0+cpu on your environment so Ultralytics script won’t load it by default?
