1、安装Jetpack6.0,Cuda12.2,配置pytorch+torchvision后,torch.cuda_is_available() 显示:False。
(1)NVIDIA-smi 显示 Driver Version: N/A;
(2)nvcc 显示正常。
2、安装Jetpack5.1,Cuda11.4,配置pytorch+torchvision后,torch.cuda_is_available() 显示:False。
Could you share more about how you install PyTorch and TorchVision?
感谢回复。刷机到6.0之后,运行nvidia-smi,提示:Driver Version: N/A(正常情况应该显示已安装的驱动版本号才对)。于是我安装Cuda12.2开发工具包,当我安装 * Python 3.10 - torch-2.1.0-cp310-cp310-linux_aarch64.whl
(USE_DISTRIBUTED=on)
后,通过执行:python,torch.cuda_is_available() 显示:False。也就是说,GPU根本没有得到识别。
另外, torch-2.2.0a0+6a974be.nv23.11-cp310-cp310-linux_aarch64.whl 对应的torchvision版本是多少?
Based on the image above, it looks like you have two GPUs on the device.
Index 0 is Orin and the other is N/A.
Are you using Jetson AGX Orin since the device should have only one GPU?
