Get thousands of debug messages, Program seems to run OK otherwise, since I get an image at end and it ends OK.
Why is debugging on and how do I turn it off. I have seen similar postings. But I have no idea which specific file I would need to modify for the debug logging level.
Here is the situation. I am using docker to pull the container for jetson-inference.
Then invoke run.sh, and then use imagenet.py. That is when I get the debug messages.
So, I am not using any C code, directly at least. Is there a solution, python based, that I can make this changes in, within the context of the docker/container?
Just for testing, if I redirect tehe outout to >/dev/null, things work much better. I am
puzzled why debus is on. Is there is another container I need to use?
