Hey Everyone,
I currently have a Jetson AGX Xavier. I am trying build a library from source and I got the errors.
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
cuda-drivers-470 : Depends: libnvidia-compute-470 (>= 470.42.01) but it is not going to be installed
Depends: libnvidia-gl-470 (>= 470.42.01) but it is not going to be installed
libnvidia-decode-470 : Depends: libnvidia-compute-470 (= 470.42.01-0ubuntu1) but it is not going to be installed
libnvidia-ifr1-470 : Depends: libnvidia-gl-470 but it is not going to be installed
nvidia-compute-utils-470 : Depends: libnvidia-compute-470 but it is not going to be installed
nvidia-driver-470 : Depends: libnvidia-gl-470 (= 470.42.01-0ubuntu1) but it is not going to be installed
nvidia-utils-470 : Depends: libnvidia-compute-470 but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I tried running ‘apt --fix-broken install’ but still got the same errors.
When I run "sudo dpkg --configure -a " I get the following errors:
dpkg: dependency problems prevent configuration of cuda-drivers-470:
cuda-drivers-470 depends on libnvidia-compute-470 (>= 470.42.01); however:
Package libnvidia-compute-470:arm64 is not installed.
cuda-drivers-470 depends on libnvidia-gl-470 (>= 470.42.01); however:
Package libnvidia-gl-470:arm64 is not installed.
dpkg: error processing package cuda-drivers-470 (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-compute-utils-470:
nvidia-compute-utils-470 depends on libnvidia-compute-470; however:
dpkg: error processing package nvidia-compute-utils-470 (--configure):
dpkg: dependency problems prevent configuration of nvidia-driver-470:
nvidia-driver-470 depends on libnvidia-gl-470 (= 470.42.01-0ubuntu1); however:
nvidia-driver-470 depends on libnvidia-compute-470 (= 470.42.01-0ubuntu1); however:
dpkg: error processing package nvidia-driver-470 (--configure):
dpkg: dependency problems prevent configuration of cuda-drivers:
cuda-drivers depends on cuda-drivers-470 (= 470.42.01-1); however:
Package cuda-drivers-470 is not configured yet.
dpkg: error processing package cuda-drivers (--configure):
dpkg: dependency problems prevent configuration of libnvidia-ifr1-470:arm64:
libnvidia-ifr1-470:arm64 depends on libnvidia-gl-470; however:
dpkg: error processing package libnvidia-ifr1-470:arm64 (--configure):
dpkg: dependency problems prevent configuration of nvidia-utils-470:
nvidia-utils-470 depends on libnvidia-compute-470; however:
dpkg: error processing package nvidia-utils-470 (--configure):
dpkg: dependency problems prevent configuration of libnvidia-decode-470:arm64:
libnvidia-decode-470:arm64 depends on libnvidia-compute-470 (= 470.42.01-0ubuntu1); however:
dpkg: error processing package libnvidia-decode-470:arm64 (--configure):
dpkg: dependency problems prevent configuration of cuda-runtime-11-4:
cuda-runtime-11-4 depends on cuda-drivers (>= 470.42.01); however:
Package cuda-drivers is not configured yet.
dpkg: error processing package cuda-runtime-11-4 (--configure):
dpkg: dependency problems prevent configuration of libnvidia-encode-470:arm64:
libnvidia-encode-470:arm64 depends on libnvidia-decode-470; however:
Package libnvidia-decode-470:arm64 is not configured yet.
dpkg: error processing package libnvidia-encode-470:arm64 (--configure):
dpkg: dependency problems prevent configuration of cuda-11-4:
cuda-11-4 depends on cuda-runtime-11-4 (>= 11.4.0); however:
Package cuda-runtime-11-4 is not configured yet.
dpkg: error processing package cuda-11-4 (--configure):
dpkg: dependency problems prevent configuration of cuda:
cuda depends on cuda-11-4 (>= 11.4.0); however:
Package cuda-11-4 is not configured yet.
dpkg: error processing package cuda (--configure):
Processing triggers for libc-bin (2.27-3ubuntu1.4) ...
Errors were encountered while processing:
cuda-drivers-470
nvidia-driver-470
cuda-drivers
nvidia-utils-470
cuda-runtime-11-4
cuda-11-4
cuda
Could you please help me in solving this problem?
Here’s some info about my Jetosn:
NVIDIA Jetson AGX Xavier [16GB]
L4T 32.3.1 [ JetPack 4.3 ]
Ubuntu 18.04.5 LTS
Kernel Version: 4.9.140-tegra
CUDA NOT_INSTALLED
CUDA Architecture: 7.2
OpenCV version: 4.1.1
OpenCV Cuda: NO
CUDNN: NOT_INSTALLED
TensorRT: NOT_INSTALLED
Vision Works: NOT_INSTALLED
VPI: NOT_INSTALLED
Vulcan: 1.1.70
