Hello, I am using jetson agx orin. I want to apply the disk encryption specified in the link Disk Encryption — NVIDIA Jetson Linux Developer Guide 1 documentation, but I have some questions in my mind. Will I have any problems with disk access with this encryption and will it cause boot slowdowns etc.? thanks a lot.
Hi feyzaorak2002,
If you have the key and password, then you can still access it successfully.
We’ve not compared the boot time before and after enabling disk encryption.
You can test them locally.
I use Rogue Carrier for NVIDIA® Jetson AGX Orin and my jetpack version is jetpack 6.
I also have one more question. When I want to access, do I go through separate access processes for each file and use key and password? Will encryption processes occur again for every place/file I want to access on the disk?
No, only the partition(normally, it’s rootfs) will be encrypted, and you don’t need to do that for each files.
