Jetson AGX Orin don't work cuda with pytorch
Hello.
I installed the prebuild pytorch version on the Jetson. The jetpack version is 6.0.
The cuda version
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Tue_Aug_15_22:08:11_PDT_2023
Cuda compilation tools, release 12.2, V12.2.140
Build cuda_12.2.r12.2/compiler.33191640_0
The pytorch have cuda support
Python 3.10.12 (main, Jul 29 2024, 16:56:48) [GCC 11.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torch
>>> torch.cuda.is_available()
True
And the torch version
$ pip list | grep torch
torch 2.3.0
torchvision 0.18.0a0+6043bc2
i have a sample program:
from torchvision.io.image import read_image
from torchvision.models.detection import fasterrcnn_resnet50_fpn_v2, FasterRCNN_ResNet50_FPN_V2_Weights
from torchvision.utils import draw_bounding_boxes
from torchvision.transforms.functional import to_pil_image
import torch
device = torch.device('cuda:0' if torch.cuda.is_available() else 'cpu')
print(f"Using device: {device}")
img = read_image("demo.jpg")
# Step 1: Initialize model with the best available weights
weights = FasterRCNN_ResNet50_FPN_V2_Weights.DEFAULT
model = fasterrcnn_resnet50_fpn_v2(weights=weights, box_score_thresh=0.9).to(device)
model.eval()
# Step 2: Initialize the inference transforms
preprocess = weights.transforms()
# Step 3: Apply inference preprocessing transforms
batch = [preprocess(img).to(device)]
# Step 4: Use the model and visualize the prediction
prediction = model(batch)[0]
labels = [weights.meta["categories"][i] for i in prediction["labels"]]
box = draw_bounding_boxes(img, boxes=prediction["boxes"],
                          labels=labels,
                          colors="red",
                          width=4)
im = to_pil_image(box.detach())
im.save("out.jpg")
# save_image(im, "out.img")
# im.show()
and the output of the program is
python test.py
Using device: cuda:0
/home/tkp/.local/lib/python3.10/site-packages/torch/nn/modules/conv.py:456: UserWarning: Plan failed with a cudnnException: CUDNN_BACKEND_EXECUTION_PLAN_DESCRIPTOR: cudnnFinalize Descriptor Failed cudnn_status: CUDNN_STATUS_NOT_SUPPORTED (Triggered internally at /opt/pytorch/aten/src/ATen/native/cudnn/Conv_v8.cpp:919.)
  return F.conv2d(input, weight, bias, self.stride,
Thanks for the help.
Thanks for sharing this issue.
We will give it a try and provide more info to you later.
Confirmed that we can reproduce the same error:
$ python3 test.py
Downloading: "https://download.pytorch.org/models/fasterrcnn_resnet50_fpn_v2_coco-dd69338a.pth" to /home/nvidia/.cache/torch/hub/checkpoints/fasterrcnn_resnet50_fpn_v2_coco-dd69338a.pth
100.0%
/home/nvidia/.local/lib/python3.10/site-packages/torch/nn/modules/conv.py:456: UserWarning: Plan failed with a cudnnException: CUDNN_BACKEND_EXECUTION_PLAN_DESCRIPTOR: cudnnFinalize Descriptor Failed cudnn_status: CUDNN_STATUS_NOT_SUPPORTED (Triggered internally at /opt/pytorch/aten/src/ATen/native/cudnn/Conv_v8.cpp:919.)
/home/nvidia/.local/lib/python3.10/site-packages/torchvision/utils.py:210: UserWarning: boxes doesn't contain any box. No box was drawn
  warnings.warn("boxes doesn't contain any box. No box was drawn")
Based on the discussion here, the issue comes from PyTorch 2.3.0 but is fixed in 2.3.1.
When testing with 24.07 our PyTorch container, the error doesn’t appear.
Please give it a try.
$ sudo docker run -it --rm --runtime nvidia --network host -v /home/nvidia/topic_302606:/home/nvidia/topic_302606 nvcr.io/nvidia/pytorch:24.07-py3-igpu
# python3 test.py
Downloading: "https://download.pytorch.org/models/fasterrcnn_resnet50_fpn_v2_coco-dd69338a.pth" to /root/.cache/torch/hub/checkpoints/fasterrcnn_resnet50_fpn_v2_coco-dd69338a.pth
100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 167M/167M [00:05<00:00, 30.8MB/s]
/usr/local/lib/python3.10/dist-packages/torchvision/utils.py:211: UserWarning: boxes doesn't contain any box. No box was drawn
Thank for the answer that works well.
