Jetson AGX Orin fTPM with OP-TEE: EKB Extraction and SSK Derivation Failure under Secure Boot
I am trying to enable fTPM with OP-TEE on a Jetson AGX Orin 64GB, and I am getting the following error during EKB key derivation / extraction:
��NOTICE: BL31: v2.8(release):l4t-r36.4.4
NOTICE: BL31: Built : 2025-06-16 15:14:01
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 4.2 (gcc version 13.4.0 (GCC)) #1 Mon Jun 16 15:53:22 UTC 2025 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
M/TC: engine AES0 engine [AES/RNG](16) post op: SE0 err_status register 0x10f8 nonzero (value 0x80000000)
M/TC: SE abnormal cond, error info: 0x30040000
M/TC: HW error: d(0), e(0), ro(0x110), rv(0xb0040000), che(0x30), act(0x0)
M/TC: device SE0(0) post op: error_capture 0x30040000
M/TC: AES crypto failed: -17
E/TC:00 00 se_aes_encrypt:35 se_aes_encrypt failed with: -17
I/TC: Derive EKB_RK from #1 fuse key failed, ignored.
E/TC:00 00 hwkey_derivation_process:452 hwkey_derivation_process: Failed to derive SSK root key (ffff0000)
E/TC:00 00 ekb_extraction_process:404 Tried all EKB_RKs but still can’t extract the EKB image.
E/TC:00 00 jetson_user_key_pta_init:1154 jetson_user_key_pta_init: Failed (ffff000f).
E/TC:00 00 call_initcalls:43 Initcall __text_start + 0x0016b620 failed
I/TC: Primary CPU switching to normal world boot
I am using secure boot with the fuses burned with the following valures:
genericfuse MagicId=“0x45535546” version=“1.0.0”
fuse name=“OdmId” size=“8” value=“0x0000000000000001”/>
fuse name=“OdmInfo” size=“4” value=“0x0001”/>
fuse name=“OptInEnable” size=“4” value=“0x1”/>
fuse name=“PublicKeyHash” size=“64” value=“******”/>
fuse name=“PkcPubkeyHash1” size=“64” value=“******”/>
fuse name=“PkcPubkeyHash2” size=“64” value=“******”/>
fuse name=“SecureBootKey” size=“32” value=“******”/>
fuse name=“Kdk0” size=“32” value=“******”/>
fuse name=“PscOdmStatic” size=“4” value=“0x00000060”/>
fuse name=“OemK1” size=“32” value=“******”/>
fuse name=“OemK2” size=“32” value=“******”/>
fuse name=“BootSecurityInfo” size=“4” value=“0x2be9”/>
/genericfuse>
and used the odm_ekb_gen.py script to create the ekb.
what is the reason for this error? is there a problem with how i flashed the fuses or is it a problem with creation of the ekb?
any help with solving the issue will be greatly appreciated.
Thats seems to be an known issue, we’re investigating this issue, will update the status once got more result. Thanks
hello arielz742,
FYI, we’ve test fTPM works with an Orin platform on JP-6.2/r36.4.3, which has PKC+SBK+OEM_K1+KDK fused.
please see-also Topic 353623 for the details.
