[Jetson AGX Orin] Intel Network Card RX Interrupts Locked to CPU0 Despite Affinity Settings
Dear NVIDIA Support Team,
I am encountering issues with interrupt distribution on my Jetson AGX Orin when using an Intel 82599ES 10-Gigabit Network Card. All RX interrupts are consistently routed to CPU0, even after attempting various affinity configuration methods.
System Configuration
  • Hardware:
    • Jetson AGX Orin Dev Kit (JetPack 6.0 rev2 / L4T R36.2.1)
    • PCIe Card: Intel 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
    • PCIe Slot: x16 Gen3
  • Software:
    • Kernel: 5.15.136-tegra (PREEMPT RT)
    • Driver: ixgbe v5.15.136-tegra
    • Firmware: 0x8000091d, 1.1825.0
Problem Symptoms
  1. Interrupt Concentration:
    All RX queues (eth1-TxRx-0 to eth1-TxRx-11) are handled by CPU0, as shown in /proc/interrupts:
302:      89874          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI 671612928 Edge      eth1-TxRx-0
303:   18512388          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI 671612929 Edge      eth1-TxRx-1
304:    2211057          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI 671612930 Edge      eth1-TxRx-2
305:   17802941          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI 671612931 Edge      eth1-TxRx-3
306:     308635          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI 671612932 Edge      eth1-TxRx-4
307:     660103          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI 671612933 Edge      eth1-TxRx-5
308:     371502          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI 671612934 Edge      eth1-TxRx-6
309:      95708          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI 671612935 Edge      eth1-TxRx-7
310:     251272          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI 671612936 Edge      eth1-TxRx-8
311:     829679          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI 671612937 Edge      eth1-TxRx-9
312:     201855          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI 671612938 Edge      eth1-TxRx-10
313:     156559          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI 671612939 Edge      eth1-TxRx-11
314:          3          0          0          0          0          0          0          0          0          0          0          0   PCI-MSI 671612940 Edge      eth1
  1. Failed Affinity Configuration:
    Attempts to set CPU affinity via /proc/irq or /sys/class/net have failed:
$ echo 1 | sudo tee /proc/irq/302/smp_affinity_list
tee: /proc/irq/302/smp_affinity_list: Invalid argument
tee: /proc/irq/302/smp_affinity: Invalid argument
  1. RPS Configuration Ineffective:
    Configuring RPS (Receive Packet Steering) did not redistribute interrupts:
$ cat /sys/class/net/eth1/queues/rx-*/rps_cpus
001
008
016
002
004
008
016
032
064
128
256
512
Despite configuration, interrupts remain on CPU0.
Troubleshooting Steps
  1. PCIe Device Verification:
$ lspci -s 0005:01:00.0
0005:01:00.0 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
  1. Multi-Queue Support:
$ ethtool -l eth1
  Channel parameters for eth1:
  Pre-set maximums:
  RX:             n/a
  TX:             n/a
  Other:          1
  Combined:       12
  Current hardware settings:
  RX:             n/a
  TX:             n/a
  Other:          1
  Combined:       12
  1. Interrupt Affinity Settings:
    All IRQs show affinity mask 0-11 (all CPUs), but interrupts still go to CPU0:
$ cat /proc/irq/{302..314}/smp_affinity_list
0-11
0-11
0-11
0-11
0-11
0-11
0-11
0-11
0-11
0-11
0-11
0-11
0-11
Questions
  1. Why are interrupts locked to CPU0 even when:
  • smp_affinity_list is set to 0-11?
  • RPS is configured to distribute to other CPUs?
  1. How can I force interrupts to be distributed across CPU1-CPU11?
  • Are there Tegra-specific kernel parameters or driver flags for this?
  1. Is there a hardware/software compatibility issue between the pcie network card and Jetson AGX Orin?
Thank you for your assistance!
yes, it is a known issue and will not fix.
You could apply the GIC MSI patch here to unblock the GIC MSI and your interrupt could be routed to other CPU cores.
Here’s my operation process on the Jetson device:
sudo apt update
sudo apt dist-upgrade
sudo apt install nvidia-l4t-openwfd nvidia-l4t-vulkan-sc-dev nvidia-l4t-vulkan-sc-samples nvidia-l4t-vulkan-sc-sdk nvidia-l4t-vulkan-sc nvidia-l4t-jetsonpower-gui-tools
mkdir -p /nvme/ff/mnt/r363/Linux_for_Tegra/rootfs/boot
export KERNEL_HEADERS=/nvme/ff/mnt/r363/Linux_for_Tegra/source/kernel/kernel-jammy-src
export CROSS_COMPILE=/usr/bin/aarch64-linux-gnu-
export INSTALL_MOD_PATH=/nvme/ff/mnt/r363/Linux_for_Tegra/rootfs
tar -xjf public_sources.tbz2
cd /nvme/ff/mnt/r363/Linux_for_Tegra/source
tar xf kernel_src.tbz2
tar xf kernel_oot_modules_src.tbz2
tar xf nvidia_kernel_display_driver_source.tbz2
zcat /proc/config.gz > /nvme/ff/mnt/r363/Linux_for_Tegra/source/kernel/kernel-jammy-src/.config
cd /nvme/ff/mnt/r363/Linux_for_Tegra/source/kernel/kernel-jammy-src
patch -p1 < /home/ff/nv_src/msi-patch-kernel.patch
cd /nvme/ff/mnt/r363/Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public
patch -p1 < /home/ff/nv_src/msi-patch-dt.patch
make -C kernel
sudo -E make install -C kernel
make modules
sudo -E make modules_install
make dtbs
cp ./nvidia-oot/device-tree/platform/generic-dts/dtbs/tegra234-p3737-0000+p3701-0005-nv.dtb /boot/dtb/ff_tegra234-p3737-0000+p3701-0005-nv.dtb
cp ./kernel/kernel-jammy-src/arch/arm64/boot/Image /boot/Image
cp -r /nvme/ff/mnt/r363/Linux_for_Tegra/rootfs/lib/modules/5.15.136-tegra  /lib/modules/
ff@ubuntu:~$ cat /boot/extlinux/extlinux.conf
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
      MENU LABEL primary kernel
      LINUX /boot/Image
      FDT /boot/dtb/ff_tegra234-p3737-0000+p3701-0005-nv.dtb
      INITRD /boot/initrd
      APPEND ${cbootargs} root=PARTUUID=414fd07d-bcf2-47ca-bd64-6f3e420fabe3 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config
# When testing a custom kernel, it is recommended that you create a backup of
# the original kernel and add a new entry to this file so that the device can
# fallback to the original kernel. To do this:
# 1, Make a backup of the original kernel
#      sudo cp /boot/Image /boot/Image.backup
# 2, Copy your custom kernel into /boot/Image
# 3, Uncomment below menu setting lines for the original kernel
# 4, Reboot
LABEL backup
      MENU LABEL backup kernel
      LINUX /boot/Image_bak
      INITRD /boot/initrd
 When starting the Jetson with the compiled product image, the device fails to boot normally, and the screen outputs the error messages shown in the attached picture.
