Based on the provided context, I will attempt to address the issues you are facing with your custom carrier board and the Jetson AGX Orin modules.
Issue 1: Standalone module not recognized as DevKit module in SDK Manager
The reason you are unable to select the device target as DevKit in the SDK Manager is due to the module ID. The DevKit module (P3701-0000) has a specific ID that is recognized by the SDK Manager, whereas the standalone module (P3701-0004) has a different ID (7223). This ID is stored in the EEPROM of the module.
When you plug the DevKit module into your custom carrier, it works because the module ID is recognized, and the SDK Manager can configure the device accordingly. However, when you try to flash the standalone module, the SDK Manager does not recognize the module ID, and therefore, it does not allow you to select the DevKit as the target device.
Issue 2: USB drives not recognized after flashing in preconfig mode
When you flash the standalone module in preconfig mode, the device tree is not properly configured for your custom carrier board. The preconfig mode is used for flashing the module with a minimal configuration, but it does not account for the specific pinmuxes and configurations of your custom carrier.
To resolve this issue, you need to edit the device tree to match the pinmuxes and configurations of your custom carrier board. You can do this by modifying the device tree files (e.g., tegra194-agx-orin-p3701-0000.dtb) to match your custom carrier’s configuration.
Creating a system from scratch
To create a system from scratch, you will need to:
- Modify the device tree files to match your custom carrier’s configuration.
- Update the kernel configuration to match your custom carrier’s pinmuxes and configurations.
- Update the MB1 and MB2 configurations to match your custom carrier’s configuration.
- Update the ODM data to match your custom carrier’s configuration.
- Flash the module with the updated configurations.
Here is a high-level overview of the steps:
- Clone the Jetson Linux repository and navigate to the
device-tree directory.
- Modify the
tegra194-agx-orin-p3701-0000.dtb file to match your custom carrier’s configuration.
- Update the
pinmux and gpio configurations to match your custom carrier’s pinmuxes.
- Update the
- Build the device tree and kernel using the
make command.
- Flash the module with the updated configurations using the
flash.sh script.
Comparison of DevKit and standalone modules
The main difference between the DevKit module (P3701-0000) and the standalone module (P3701-0004) is the module ID. The DevKit module has a specific ID that is recognized by the SDK Manager, whereas the standalone module has a different ID.
In terms of functionality, both modules are identical, and they can be used interchangeably. However, the DevKit module is specifically designed for development and testing, whereas the standalone module is intended for production use.
EEPROM data
The EEPROM data on the DevKit module contains information about the module’s configuration, including the pinmuxes and configurations. When you design a custom carrier board, you need to ensure that the EEPROM data matches the configuration of your custom carrier.
In your case, since you have designed a custom carrier board with the same pinmuxes and configurations as the DevKit carrier, you can use the same EEPROM data on your custom carrier. However, you will need to update the module ID to match the standalone module’s ID (7223).
I hope this comprehensive answer helps you resolve the issues you are facing with your custom carrier board and the Jetson AGX Orin modules.
