Jetson AGX Xavier 32GB 在MAXN模式下,长时间运行一段时间后关机
查看syslog并没有异常告警日志,
Aug 11 18:48:52 nvidia-desktop systemd-resolved[362]: Using degraded feature set (UDP) for DNS server 8.8.8.8.
Aug 11 18:48:55 nvidia-desktop systemd-resolved[362]: Using degraded feature set (TCP) for DNS server 8.8.8.8.
Aug 11 18:49:04 nvidia-desktop systemd-resolved[362]: Using degraded feature set (UDP) for DNS server 8.8.8.8.
Aug 11 18:49:07 nvidia-desktop systemd-resolved[362]: Using degraded feature set (TCP) for DNS server 8.8.8.8.
Aug 12 08:38:26 nvidia-desktop systemd-modules-load[324]: Inserted module ‘product’
Aug 12 08:38:26 nvidia-desktop systemd-modules-load[324]: Inserted module ‘nvmap’
Aug 12 08:38:26 nvidia-desktop systemd-modules-load[324]: Inserted module ‘nvgpu’
Aug 12 08:38:26 nvidia-desktop systemd-modules-load[324]: Inserted module ‘pwm_fan’
Aug 12 08:38:26 nvidia-desktop systemd-modules-load[324]: Inserted module ‘ina3221’
有什么办法可以抓取设备关机的原因?另:这个设备的固件刷的配置是30W模式的散热规格,是否和这个相关?
Check uart serial console.
Thanks but The serial port has not been pulled out,have other ways?
No, the serial port is the most precise way.
ok,I will try it,thank you!
