Situation: Run jetson-containers run dustynv/nano_llm:r36.2.0 python3 -m nano_llm.agents.web_chat --api=mlc --model Efficient-Large-Model/VILA1.5-3b --asr=riva --tts=piper on AGX Orin Developer Kit - Jetpack 6.0 [L4T 36.3.0]
Expectation: The necessary images should be built, and a docker container started. I fully expect to be placed at a >Prompt
Actual: I get the error below, and i’m kicked back out to the host prompt
/opt/NanoLLM/nano_llm/utils/tensor.py:109: UserWarning: The given NumPy array is not writable, and PyTorch does not support non-writable tensors. This means writing to this tensor will result in undefined behavior. You may want to copy the array to protect its data or make it writable before converting it to a tensor. This type of warning will be suppressed for the rest of this program. (Triggered internally at /opt/pytorch/torch/csrc/utils/tensor_numpy.cpp:206.)
return torch.from_numpy(tensor).to(device=device, dtype=convert_dtype(dtype, to=‘pt’), **kwargs)
File “/usr/lib/python3.10/runpy.py”, line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File “/usr/lib/python3.10/runpy.py”, line 86, in _run_code
exec(code, run_globals)
File “/opt/NanoLLM/nano_llm/agents/web_chat.py”, line 310, in
agent = WebChat(vars(args))
File “/opt/NanoLLM/nano_llm/agents/web_chat.py”, line 55, in init
self.llm.functions = BotFunctions()
File “/opt/NanoLLM/nano_llm/plugins/bot_functions/init.py”, line 86, in new
cls.load(test=test)
File “/opt/NanoLLM/nano_llm/plugins/bot_functions/init.py”, line 265, in load
cls.test()
File “/opt/NanoLLM/nano_llm/plugins/bot_functions/init.py”, line 275, in test
logging.info(f"Bot function descriptions:\n{cls.generate_docs()}")
File “/opt/NanoLLM/nano_llm/plugins/bot_functions/init.py”, line 167, in generate_docs
docs = ‘\n’.join([’ ’ + x.docs for x in cls.functions if x.enabled])
TypeError: can only concatenate str (not “dict”) to str
