Expected Outcome: “llamaspeak” enabled with text LLM and ASR/TTS
Actual Outcome:
System gets stuck at the steps below. I have to Ctrl+C to get back to prompt →
docker run --runtime nvidia -it --rm --network host --volume /tmp/argus_socket:/tmp/argus_socket --volume /etc/enctune.conf:/etc/enctune.conf --volume /etc/nv_tegra_release:/etc/nv_tegra_release --volume /tmp/nv_jetson_model:/tmp/nv_jetson_model --volume /var/run/dbus:/var/run/dbus --volume /var/run/avahi-daemon/socket:/var/run/avahi-daemon/socket --volume /var/run/docker.sock:/var/run/docker.sock --volume /ssd/jetson-containers/data:/data --device /dev/snd --device /dev/bus/usb -e DISPLAY=:0 -v /tmp/.X11-unix/:/tmp/.X11-unix -v /tmp/.docker.xauth:/tmp/.docker.xauth -e XAUTHORITY=/tmp/.docker.xauth --env HUGGINGFACE_TOKEN=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 dustynv/nano_llm:r35.4.1 python3 -m nano_llm.agents.web_chat --api=mlc --model meta-llama/Meta-Llama-3-8B-Instruct --asr=riva --tts=piper
/usr/lib/python3/dist-packages/requests/init.py:89: RequestsDependencyWarning: urllib3 (1.26.18) or chardet (3.0.4) doesn’t match a supported version!
warnings.warn("urllib3 ({}) or chardet ({}) doesn’t match a supported "
/usr/local/lib/python3.8/dist-packages/transformers/utils/hub.py:124: FutureWarning: Using TRANSFORMERS_CACHE is deprecated and will be removed in v5 of Transformers. Use HF_HOME instead.
warnings.warn(
warnings.warn(
Process Process-1:
File “/usr/lib/python3.8/multiprocessing/process.py”, line 315, in _bootstrap
self.run()
File “/usr/lib/python3.8/multiprocessing/process.py”, line 108, in run
self._target(*self._args, **self._kwargs)
File “/opt/NanoLLM/nano_llm/plugins/process_proxy.py”, line 103, in run_process
from cuda.cudart import (
ImportError: cannot import name ‘cudaInitDevice’ from ‘cuda.cudart’ (/usr/local/lib/python3.8/dist-packages/cuda/cudart.cpython-38-aarch64-linux-gnu.so)
Hi @dusty_nv,
Thanks for your quick response.
I saw that most of the containers of interest required Jetpack 6. Therefore, to make my life a bit easier, I updated from Jetpack 5.1.2 [L4T 35.4.1] to Jetpack 6.0-b52.
I’ll update shortly to see if the Llamaspeak - NVIDIA Jetson AI Lab tutorial worked.
Quick update (being verbose for anyone else encountering a similar issue)
Flashed Jetpack 6 on my AGX Orin; however, ran into too many compatibility issues that I simply did not have the bandwidth to resolve. So, went back to Jetpack 5.1.2
@dusty_nv With Jetpack 5.1.2, and your newly rebuilt container, and, it now works. Thanks for your help.
and I use the newest docker image dustynv/nano_llm:r35.4.1(update May 2, 2024 at 12:22 pm) running the same script:
jetson-containers run --env HUGGINGFACE_TOKEN=
$(autotag nano_llm)
–model meta-llama/Meta-Llama-3-8B-Instruct
–asr=riva --tts=piper
is OK.
But when I use this docker to run live-llava (Live LLaVA - NVIDIA Jetson AI Lab), this is a trouble, the error message look like the same:
– L4T_VERSION=35.4.1 JETPACK_VERSION=5.1.2 CUDA_VERSION=11.4
– Finding compatible container image for [‘nano_llm’]
localuser:root being added to access control list
docker run --runtime nvidia -it --rm --network host --volume /tmp/argus_socket:/tmp/argus_socket --volume /etc/enctune.conf:/etc/enctune.conf --volume /etc/nv_tegra_release:/etc/nv_tegra_release --volume /tmp/nv_jetson_model:/tmp/nv_jetson_model --volume /var/run/dbus:/var/run/dbus --volume /var/run/avahi-daemon/socket:/var/run/avahi-daemon/socket --volume /var/run/docker.sock:/var/run/docker.sock --volume /home/lq/ai/code/jetson-containers/data:/data --device /dev/snd --device /dev/bus/usb -e DISPLAY=:0 -v /tmp/.X11-unix/:/tmp/.X11-unix -v /tmp/.docker.xauth:/tmp/.docker.xauth -e XAUTHORITY=/tmp/.docker.xauth dustynv/nano_llm:r35.4.1 python3 -m nano_llm.agents.video_query --api=mlc --model Efficient-Large-Model/VILA1.5-3b --max-context-len 256 --max-new-tokens 32 --video-input /dev/video0 --video-output webrtc://@:8554/output
warnings.warn(
warnings.warn(
Process Process-1:
self.run()
Hi @261142960, sorry for the delay - I would recommend using JetPack 6 for the latest (which is what I list on the Live Llava page for the supported JetPack version for that)
On JetPack 5, you would need to disable the use of the ProcessProxy in the VideoQuery agent. If you want to edit the NanoLLM source, you can do this easier by cloning it to your device, and then mounting it into the container over the /opt/NanoLLM location (then it will run your local source tree instead, and you can make edits from outside the container)
