Hi there Jetson Community,
I am trying to build an image from jetson-containers with the following command:
jetson-containers build --name=test_combo_image realsense nanoowl nanosam
During the testing phase of the build, I get the following error:
│ > TESTING test_combo_image:r36.4.tegra-aarch64-cu126-22.04-torch2trt │
docker run -t --rm --network=host --privileged --runtime=nvidia \
--volume /ssd/repos/jetson-containers/packages/pytorch/torch2trt:/test \
--volume /ssd/repos/jetson-containers/data:/data \
test_combo_image:r36.4.tegra-aarch64-cu126-22.04-torch2trt \
/bin/bash -c 'python3 /test/test.py
testing torch2trt...
/usr/local/lib/python3.10/dist-packages/torchvision/models/_utils.py:208: UserWarning: The parameter 'pretrained' is deprecated since 0.13 and may be removed in the future, please use 'weights' instead.
warnings.warn(
/usr/local/lib/python3.10/dist-packages/torchvision/models/_utils.py:223: UserWarning: Arguments other than a weight enum or `None` for 'weights' are deprecated since 0.13 and may be removed in the future. The current behavior is equivalent to passing `weights=AlexNet_Weights.IMAGENET1K_V1`. You can also use `weights=AlexNet_Weights.DEFAULT` to get the most up-to-date weights.
warnings.warn(msg)
File "/test/test.py", line 9, in <module>
model = alexnet(pretrained=True).eval().cuda()
File "/usr/local/lib/python3.10/dist-packages/torch/nn/modules/module.py", line 1082, in cuda
return self._apply(lambda t: t.cuda(device))
File "/usr/local/lib/python3.10/dist-packages/torch/nn/modules/module.py", line 928, in _apply
module._apply(fn)
module._apply(fn)
File "/usr/local/lib/python3.10/dist-packages/torch/nn/modules/module.py", line 955, in _apply
param_applied = fn(param)
File "/usr/local/lib/python3.10/dist-packages/torch/nn/modules/module.py", line 1082, in <lambda>
File "/usr/local/lib/python3.10/dist-packages/torch/cuda/__init__.py", line 412, in _lazy_init
torch._C._cuda_init()
RuntimeError: Unexpected error from cudaGetDeviceCount(). Did you run some cuda functions before calling NumCudaDevices() that might have already set an error? Error 34: CUDA driver is a stub library
[12:25:51] =====================================================================================
[12:25:51] 💣 `jetson-containers build` failed after 75.1 seconds (1.3 minutes)
[12:25:51] Error: Command 'docker run -t --rm --network=host --privileged --runtime=nvidia --volume /ssd/repos/jetson-containers/packages/pytorch/torch2trt:/test --volume /ssd/repos/jetson-containers/data:/data test_combo_image:r36.4.tegra-aarch64-cu126-22.04-torch2trt /bin/bash -c 'python3 /test/test.py' 2>&1 | tee /ssd/repos/jetson-containers/logs/20250906_122435/test/19-1_test_combo_image_r36.4.tegra-aarch64-cu126-22.04-torch2trt_test.py.txt; exit ${PIPESTATUS[0]}' returned non-zero exit status 1.
[12:25:51] Failed building: realsense, nanoowl, nanosam
File "/ssd/repos/jetson-containers/jetson_containers/build.py", line 129, in <module>
build_container(**vars(args))
File "/ssd/repos/jetson-containers/jetson_containers/container.py", line 246, in build_container
test_container(container_name, pkg, simulate, build_idx=idx)
File "/ssd/repos/jetson-containers/jetson_containers/container.py", line 456, in test_container
status = subprocess.run(cmd.replace(_NEWLINE_, ' '), executable='/bin/bash', shell=True, check=True)
File "/usr/lib/python3.10/subprocess.py", line 526, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command 'docker run -t --rm --network=host --privileged --runtime=nvidia --volume /ssd/repos/jetson-containers/packages/pytorch/torch2trt:/test --volume /ssd/repos/jetson-containers/data:/data test_combo_image:r36.4.tegra-aarch64-cu126-22.04-torch2trt /bin/bash -c 'python3 /test/test.py' 2>&1 | tee /ssd/repos/jetson-containers/logs/20250906_122435/test/19-1_test_combo_image_r36.4.tegra-aarch64-cu126-22.04-torch2trt_test.py.txt; exit ${PIPESTATUS[0]}' returned non-zero exit status 1
I suspect it is due to some driver/library mismatch. Can anyone help me out? Thanks!
