Jetson-containers local_llm not working with Jetson AGX Xavier
I cannot get jetson-container local_llm to work with Jetson AGX Xavier. I have it working with Orin, so I know that I am not running something incorrectly, and also found on other discussions that api=mlc might not work with Xavier. I tried other apis and none of them works. Only one that runs is hf, but the moment I feed a text input/prompt, it pops out embed_txt not implemented error:
File “/usr/lib/python3.8/threading.py”, line 932, in _bootstrap_inner
self.run()
File “/opt/local_llm/local_llm/plugin.py”, line 177, in run
self.dispatch(self.input_queue.get(block=False))
File “/opt/local_llm/local_llm/plugin.py”, line 190, in dispatch
outputs = self.process(input)
File “/opt/local_llm/local_llm/plugins/chat_query.py”, line 126, in process
embedding, position = chat_history.embed_chat()
File “/opt/local_llm/local_llm/history.py”, line 292, in embed_chat
entry[embed_key] = self.embed(entry[key], type=key, template=role_template)
File “/opt/local_llm/local_llm/history.py”, line 190, in embed
return self.embedding_functions[type].func(input, template)
File “/opt/local_llm/local_llm/history.py”, line 201, in embed_text
embedding = self.model.embed_text(text, use_cache=use_cache)
File “/opt/local_llm/local_llm/local_llm.py”, line 116, in embed_text
raise NotImplementedError(“embed_text() not implemented for this model”)
NotImplementedError: embed_text() not implemented for this model
Is there any way to make it work @dusty_nv ?
Thank you.
Hi @haechan.bong, sorry about that, yes the other APIs I need to update at some point (but they are significantly slower versus MLC, which is why I have not prioritized their upkeep). And the kernels used by MLC have a requirement for Ampere architecture and newer, so sadly Xavier is not supported in that one. Currently I would recommend to use llama.cpp on Xavier.
