Chat with Llava fails
I am trying this tutorial: LLaVA - NVIDIA Jetson AI Lab
Using a Xavier AGX.
Downloading the model works fine:
pit@pit-desktop:~/jetson-containers$ jetson-containers run --workdir=/opt/text-generation-webui $(autotag text-generation-webui) \
>   python3 download-model.py --output=/data/models/text-generation-webui \
>     TheBloke/llava-v1.5-13B-GPTQ
Namespace(disable=[''], output='/tmp/autotag', packages=['text-generation-webui'], prefer=['local', 'registry', 'build'], quiet=False, user='dustynv', verbose=False)
-- L4T_VERSION=35.6.0  JETPACK_VERSION=5.1  CUDA_VERSION=12.4
-- Finding compatible container image for ['text-generation-webui']
dustynv/text-generation-webui:r35.4.1-cp310
V4L2_DEVICES:
### DISPLAY environmental variable is already set: ":0"
localuser:root being added to access control list
+ sudo docker run --runtime nvidia -it --rm --network host --shm-size=8g --volume /tmp/argus_socket:/tmp/argus_socket --volume /etc/enctune.conf:/etc/enctune.conf --volume /etc/nv_tegra_release:/etc/nv_tegra_release --volume /tmp/nv_jetson_model:/tmp/nv_jetson_model --volume /var/run/dbus:/var/run/dbus --volume /var/run/avahi-daemon/socket:/var/run/avahi-daemon/socket --volume /var/run/docker.sock:/var/run/docker.sock --volume /home/pit/jetson-containers/data:/data -v /etc/localtime:/etc/localtime:ro -v /etc/timezone:/etc/timezone:ro --device /dev/snd -e PULSE_SERVER=unix:/run/user/1000/pulse/native -v /run/user/1000/pulse:/run/user/1000/pulse --device /dev/bus/usb -e DISPLAY=:0 -v /tmp/.X11-unix/:/tmp/.X11-unix -v /tmp/.docker.xauth:/tmp/.docker.xauth -e XAUTHORITY=/tmp/.docker.xauth --device /dev/i2c-0 --device /dev/i2c-1 --device /dev/i2c-2 --device /dev/i2c-3 --device /dev/i2c-4 --device /dev/i2c-5 --device /dev/i2c-6 --device /dev/i2c-7 --device /dev/i2c-8 -v /run/jtop.sock:/run/jtop.sock --name jetson_container_20250304_183126 --workdir=/opt/text-generation-webui dustynv/text-generation-webui:r35.4.1-cp310 python3 download-model.py --output=/data/models/text-generation-webui TheBloke/llava-v1.5-13B-GPTQ
Downloading the model to /data/models/text-generation-webui
### Start Web UI with Multimodal Extension
pit@pit-desktop:~/jetson-containers$ jetson-containers run --workdir=/opt/text-generation-webui $(autotag text-generation-webui)   python3 server.py --listen     --model-dir ~/data/models/text-generation-webui     --model TheBloke_llava-v1.5-13B-GPTQ     --multimodal-pipeline llava-v1.5-13b     --loader autogptq     --disable_exllama     --verbose
V4L2_DEVICES:
+ sudo docker run --runtime nvidia -it --rm --network host --shm-size=8g --volume /tmp/argus_socket:/tmp/argus_socket --volume /etc/enctune.conf:/etc/enctune.conf --volume /etc/nv_tegra_release:/etc/nv_tegra_release --volume /tmp/nv_jetson_model:/tmp/nv_jetson_model --volume /var/run/dbus:/var/run/dbus --volume /var/run/avahi-daemon/socket:/var/run/avahi-daemon/socket --volume /var/run/docker.sock:/var/run/docker.sock --volume /home/pit/jetson-containers/data:/data -v /etc/localtime:/etc/localtime:ro -v /etc/timezone:/etc/timezone:ro --device /dev/snd -e PULSE_SERVER=unix:/run/user/1000/pulse/native -v /run/user/1000/pulse:/run/user/1000/pulse --device /dev/bus/usb -e DISPLAY=:0 -v /tmp/.X11-unix/:/tmp/.X11-unix -v /tmp/.docker.xauth:/tmp/.docker.xauth -e XAUTHORITY=/tmp/.docker.xauth --device /dev/i2c-0 --device /dev/i2c-1 --device /dev/i2c-2 --device /dev/i2c-3 --device /dev/i2c-4 --device /dev/i2c-5 --device /dev/i2c-6 --device /dev/i2c-7 --device /dev/i2c-8 -v /run/jtop.sock:/run/jtop.sock --name jetson_container_20250304_183539 --workdir=/opt/text-generation-webui dustynv/text-generation-webui:r35.4.1-cp310 python3 server.py --listen --model-dir /home/pit/data/models/text-generation-webui --model TheBloke_llava-v1.5-13B-GPTQ --multimodal-pipeline llava-v1.5-13b --loader autogptq --disable_exllama --verbose
/usr/local/lib/python3.10/dist-packages/transformers/utils/hub.py:124: FutureWarning: Using `TRANSFORMERS_CACHE` is deprecated and will be removed in v5 of Transformers. Use `HF_HOME` instead.
  warnings.warn(
18:35:55-020871 INFO     Starting Text generation web UI
18:35:55-032096 WARNING
                         You are potentially exposing the web UI to the entire
                         internet without any access password.
                         You can create one with the "--gradio-auth" flag like
                         this:
                         --gradio-auth username:password
                         Make sure to replace username:password with your own.
18:35:55-039757 INFO     Loading settings from "settings.yaml"
NOW THE ERROR:
18:35:55-050759 INFO     Loading "TheBloke_llava-v1.5-13B-GPTQ"
18:35:55-145301 ERROR    The model could not be loaded because its checkpoint
                         file in .bin/.pt/.safetensors format could not be
                         located.
18:35:55-149351 INFO     Loading the extension "multimodal"
18:35:58-281075 INFO     LLaVA - Loading CLIP from
                         openai/clip-vit-large-patch14-336 as torch.float16 on
                         cuda:0...
18:36:02-952300 INFO     LLaVA - Loading projector from
                         liuhaotian/llava-v1.5-13b as torch.float16 on cuda:0...
18:36:03-332203 INFO     LLaVA supporting models loaded, took 5.05 seconds
18:36:03-336693 INFO     Multimodal: loaded pipeline llava-v1.5-13b from
                         pipelines/llava (LLaVA_v1_5_13B_Pipeline)
Running on local URL:  http://0.0.0.0:7860
There was a similar problem here:
dusty_nv
Moderator
Jul 24
Hi @michtw , I recall in the oobabooga webui, there is a “use safetensors” option in the model loader section, so it may need a similar flag if done from the command line. You do not need jp5 git branch of jetson-containers anymore, that was from long ago. Also the Multimodal Chat could still working with JetPack 5, I had recently rebuild the container for it on L4T R35.2.1.
But I can’t wrap my brain around “use safetensors”.
Any hint appreciated.
-Pete
As usual, I made it too complicated. -
Finally filling-in the huggingface URL for “TheBloke/Llama-2-7b-Chat-GGUF” did the trick.
I’ve seen a ‘one file solution’ with *.safetensors before and was running down the wrong path on docker file level.
BTW: Tutorial - text-generation-webui can be also marked as working for Jetson AGX Xavier (32GB)
Thanks @pitfo, glad to hear that you got that working - the VLM support in oogabooga can be hit or miss and it is not very feasible to keep that page up with all the latest across the APIs available. We have been working to get these updated on the site with the latest VLM support available from the likes of llama.cpp, MLC, vLLM, SGLang, ect.
What I would recommend in the meantime, is to use our containers of these libraries and refer to their specific upstream documentation. Continually reconciling the docs of all these other active projects has proven difficult to keep updated, so in the future we try to dynamically pull these resources in so you are naturally directed to the latest info.
Thanks for your note @dusty_nv,
It is unfair from my side, still creating problems with an old Xavier AGX. But there is light @the end of the tunnel, my new Orin AGX is onboard of a ship from Ireland and the whole tutorial site and finally Jetpack 6 opens a new world for me.
Containers: Is there a world without? J
Yes, that’s the way to get it managed and 98%, I’m in one of your Docker containers.
