How to run the default LLaVA demo?
Hi nv team,
Now I use agx orin product with jp5.1.1.
I want to run LLaVA demo for text-generation-webui.But there is always one error:
“no module named exllama”.
I already check the model is correct.
How to fix this issue?
thanks.
the reference wiki is:
the command is:
./run.sh $(./autotag text-generation-webui) /bin/bash -c
“cd /opt/text-generation-webui && python3 server.py --listen
–model-dir=/data/models/text-generation-webui
–model=liuhaotian_llava-llama-2-13b-chat-lightning-gptq
–multimodal-pipeline=llava-llama-2-13b
–extensions=multimodal
–chat
–verbose”
the full error log is:
lcfc@lcfc-desktop:~/jetson-containers$ ./run.sh $(./autotag text-generation-webui) /bin/bash -c \
–chat
–verbose”
Namespace(disable=[‘’], output=‘/tmp/autotag’, packages=[‘text-generation-webui’], prefer=[‘local’, ‘registry’, ‘build’], quiet=False, user=‘dustynv’, verbose=False)
– L4T_VERSION=35.3.1 JETPACK_VERSION=5.1.1 CUDA_VERSION=11.4.315
– Finding compatible container image for [‘text-generation-webui’]
dustynv/text-generation-webui:r35.2.1
localuser:root being added to access control list
  • sudo docker run --runtime nvidia -it --rm --network host --volume /tmp/argus_socket:/tmp/argus_socket --volume /etc/enctune.conf:/etc/enctune.conf --volume /etc/nv_tegra_release:/etc/nv_tegra_release --volume /tmp/nv_jetson_model:/tmp/nv_jetson_model --volume /home/lcfc/jetson-containers/data:/data --device /dev/snd --device /dev/bus/usb -e DISPLAY=:1 -v /tmp/.X11-unix/:/tmp/.X11-unix -v /tmp/.docker.xauth:/tmp/.docker.xauth -e XAUTHORITY=/tmp/.docker.xauth dustynv/text-generation-webui:r35.2.1 /bin/bash -c ‘cd /opt/text-generation-webui && python3 server.py --listen --model-dir=/data/models/text-generation-webui --model=liuhaotian_llava-llama-2-13b-chat-lightning-gptq --multimodal-pipeline=llava-llama-2-13b --extensions=multimodal --chat --verbose’
    2023-11-23 08:15:11 WARNING:The --chat flag has been deprecated and will be removed soon. Please remove that flag.
    You are potentially exposing the web UI to the entire internet without any access password.
    You can create one with the “–gradio-auth” flag like this:
–gradio-auth username:password
Make sure to replace username:password with your own.
bin /usr/local/lib/python3.8/dist-packages/bitsandbytes/libbitsandbytes_cuda114.so
2023-11-23 08:15:14 INFO:Loading settings from settings.json…
2023-11-23 08:15:14 INFO:Loading liuhaotian_llava-llama-2-13b-chat-lightning-gptq…
2023-11-23 08:15:14 WARNING:Exllama module failed to load. Will attempt to load from repositories.
2023-11-23 08:15:14 ERROR:Could not find repositories/exllama/. Make sure that exllama is cloned inside repositories/ and is up to date.
File “/opt/text-generation-webui/modules/exllama_hf.py”, line 14, in
from exllama.model import ExLlama, ExLlamaCache, ExLlamaConfig
ModuleNotFoundError: No module named ‘exllama’
During handling of the above exception, another exception occurred:
File “server.py”, line 223, in
shared.model, shared.tokenizer = load_model(model_name)
File “/opt/text-generation-webui/modules/models.py”, line 85, in load_model
output = load_func_maploader
File “/opt/text-generation-webui/modules/models.py”, line 348, in ExLlama_HF_loader
from modules.exllama_hf import ExllamaHF
File “/opt/text-generation-webui/modules/exllama_hf.py”, line 21, in
from model import ExLlama, ExLlamaCache, ExLlamaConfig
ModuleNotFoundError: No module named ‘model’
Hi @sam_yangli, sorry about that - I believe I have identified the cause of the issue. I will try it and rebuild the text-generation-webui containers here first.
ok,thanks for your reply.
once you fix this issue, please notify me in time.
OK, I pushed these updated containers with exllama v1 included again.
dustynv/text-generation-webui:r35.3.1
dustynv/text-generation-webui:r35.4.1
Please do sudo docker pull dustynv/text-generation-webui:r35.2.1 and try running the llava example again.
