Couldn't find a compatible container for text-generation-webui
Hello everyone,
While running the commands to setup text generation webui from LLaVA - NVIDIA Jetson AI Lab by @dusty_nv, I am getting the following error message.
Error: Couldn’t find a compatible container for text-generation-webui
I am attaching the configurations of the Jetson AGX Orin, that I am using. Could someone please help me out with this.
Thank you very much!
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
Could you share the complete log with us?
Suppose the script will start to build a container based on your environment information.
Sure, please find the command and its associated logs in the images below.
and this too!
Could you help to check the CUDA version in your environment?
$ ll /usr/local/cuda*
JetPack 6.1 should include CUDA 12.6 but it’s CUDA 12.1 detected in your environment.
Yes, I have manually linked the “/usr/local/cuda” to CUDA 12.1, since the model( haotian-liu/LLaVA: [NeurIPS’23 Oral] Visual Instruction Tuning (LLaVA) built towards GPT-4V level capabilities and beyond.) i am trying to run requires CUDA 12.1. I have linked it back to CUDA 12.6.
Now, while running the command:
jetson-containers run --workdir=/opt/text-generation-webui $(autotag text-generation-webui) *
** python3 download-model.py --output=/data/models/text-generation-webui *
** TheBloke/llava-v1.5-13B-GPTQ**
I am getting the following error:
Is there anything I can do?
Do you have custom Python version?
JetPack 6.1 should by default use Python 3.10.
But the error seems related to the Python3.6?
No, I am using Python version 3.10.
We test the container with the latest JetPack 6.2 and it can work as expected.
Please try if the below command can also work on your side:
$ jetson-containers build text-generation-webui
-- Done building container text-generation-webui:r36.4.3
$ sudo docker run -it --rm --runtime=nvidia --network=host --volume /home/nvidia/jetson-containers/packages/llm/auto_awq:/test --volume /home/nvidia/jetson-containers/data:/data --workdir /test text-generation-webui:r36.4.3
/usr/local/lib/python3.10/dist-packages/transformers/utils/hub.py:128: FutureWarning: Using `TRANSFORMERS_CACHE` is deprecated and will be removed in v5 of Transformers. Use `HF_HOME` instead.
  warnings.warn(
08:01:21-253741 INFO     Starting Text generation web UI
08:01:21-259695 WARNING  The --triton flag has been deprecated and will be removed soon. Please remove that flag.
08:01:21-261235 WARNING
                         You are potentially exposing the web UI to the entire internet without any access password.
                         You can create one with the "--gradio-auth" flag like this:
                         --gradio-auth username:password
                         Make sure to replace username:password with your own.
08:01:21-263644 INFO     Loading settings from "settings.yaml"
Running on local URL:  http://0.0.0.0:7860
The open the http://[IP]:7860 with a browser can see:
Thank you very much for the solution. I am able to run it now.
