I am trying to follow this tutorial to run text-generation-webui on a Jetson Orin Nano Developer kit, but when i run ./run.sh $(./autotag text-generation-webui) it shows the following output:
albert@albert-desktop:~/jetson-containers$ ./run.sh $(./autotag text-generation-webui)
Namespace(packages=['text-generation-webui'], prefer=['local', 'registry', 'build'], disable=[''], user='dustynv', output='/tmp/autotag', quiet=False, verbose=False)
-- L4T_VERSION=36.2.0 JETPACK_VERSION=6.0 CUDA_VERSION=12.2.140
-- Finding compatible container image for ['text-generation-webui']
dustynv/text-generation-webui:r36.2.0
localuser:root being added to access control list
xauth: unable to rename authority file /tmp/.docker.xauth, use /tmp/.docker.xauth-n
chmod: changing permissions of '/tmp/.docker.xauth': Operation not permitted
./run.sh: line 45: /tmp/nv_jetson_model: Permission denied
+ docker run --runtime nvidia -it --rm --network host --volume /tmp/argus_socket:/tmp/argus_socket --volume /etc/enctune.conf:/etc/enctune.conf --volume /etc/nv_tegra_release:/etc/nv_tegra_release --volume /tmp/nv_jetson_model:/tmp/nv_jetson_model --volume /home/albert/jetson-containers/data:/data --device /dev/snd --device /dev/bus/usb -e DISPLAY=:0 -v /tmp/.X11-unix/:/tmp/.X11-unix -v /tmp/.docker.xauth:/tmp/.docker.xauth -e XAUTHORITY=/tmp/.docker.xauth dustynv/text-generation-webui:r36.2.0
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as 'legacy'
NvRmMemInitNvmap failed with Permission denied
356: Memory Manager Not supported
****NvRmMemMgrInit failed**** error type: 196626
libnvrm_gpu.so: NvRmGpuLibOpen failed, error=196626
nvidia-container-cli: detection error: nvml error: unknown error: unknown.
I have tried running run.sh with sudo, but the error is roughly the same.
System info
albert@albert-desktop:~/jetson-containers$ docker info
Client: Docker Engine - Community
Version: 25.0.3
Context: default
Debug Mode: false
Plugins:
buildx: Docker Buildx (Docker Inc.)
Version: v0.12.1
Path: /usr/libexec/docker/cli-plugins/docker-buildx
compose: Docker Compose (Docker Inc.)
Version: v2.21.0
Path: /usr/local/lib/docker/cli-plugins/docker-compose
Server:
Containers: 0
Running: 0
Paused: 0
Stopped: 0
Images: 1
Server Version: 25.0.3
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Using metacopy: false
Native Overlay Diff: true
userxattr: false
Logging Driver: json-file
Cgroup Driver: systemd
Cgroup Version: 2
Plugins:
Volume: local
Network: bridge host ipvlan macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local splunk syslog
Swarm: inactive
Runtimes: io.containerd.runc.v2 nvidia runc
Default Runtime: nvidia
Init Binary: docker-init
containerd version: ae07eda36dd25f8a1b98dfbf587313b99c0190bb
runc version: v1.1.12-0-g51d5e94
init version: de40ad0
Security Options:
seccomp
Profile: builtin
cgroupns
Kernel Version: 5.15.122-tegra
Operating System: Ubuntu 22.04.3 LTS
OSType: linux
Architecture: aarch64
CPUs: 6
Total Memory: 7.442GiB
Docker Root Dir: /var/lib/docker
Debug Mode: false
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: false
albert@albert-desktop:~$ nvcc --version
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Tue_Aug_15_22:08:11_PDT_2023
Cuda compilation tools, release 12.2, V12.2.140
Build cuda_12.2.r12.2/compiler.33191640_0
albert@albert-desktop:~$ hostnamectl
Static hostname: albert-desktop
Icon name: computer
Machine ID: 5dbfb12414a3456d9014d88183e338b1
Boot ID: 09b7528436754432b0ef89b2132e5f56
Kernel: Linux 5.15.122-tegra
Architecture: arm64
Hardware Vendor: Unknown
Hardware Model: NVIDIA Jetson Orin Nano Developer Kit
