Issue with launching web server: Tutorial - text-generation-webui
Need troubleshooting assistance, please, with Tutorial - text-generation-webui.
Steps performed:
  1. Performed RAM Optimization:
    2. Disabled desktop GUI temporarily
    3. Have swap file on SSD (at boot)
  2. Ran jetson-containers as follows:
$ jetson-containers run $(autotag text-generation-webui)
Namespace(packages=['text-generation-webui'], prefer=['local', 'registry', 'build'], disable=[''], user='dustynv', output='/tmp/autotag', quiet=False, verbose=False)
-- L4T_VERSION=36.4.3  JETPACK_VERSION=6.2  CUDA_VERSION=12.6
-- Finding compatible container image for ['text-generation-webui']
text-generation-webui:r36.4.3-transformers
V4L2_DEVICES:  --device /dev/video0  --device /dev/video1
+ docker run --runtime nvidia -it --rm --network host --shm-size=8g --volume /tmp/argus_socket:/tmp/argus_socket --volume /etc/enctune.conf:/etc/enctune.conf --volume /etc/nv_tegra_release:/etc/nv_tegra_release --volume /tmp/nv_jetson_model:/tmp/nv_jetson_model --volume /var/run/dbus:/var/run/dbus --volume /var/run/avahi-daemon/socket:/var/run/avahi-daemon/socket --volume /var/run/docker.sock:/var/run/docker.sock --volume /ssd/projects/jetson-containers/data:/data -v /etc/localtime:/etc/localtime:ro -v /etc/timezone:/etc/timezone:ro --device /dev/snd -e PULSE_SERVER=unix:/run/user/1000/pulse/native -v /run/user/1000/pulse:/run/user/1000/pulse --device /dev/bus/usb --device /dev/video0 --device /dev/video1 --device /dev/i2c-0 --device /dev/i2c-1 --device /dev/i2c-2 --device /dev/i2c-4 --device /dev/i2c-5 --device /dev/i2c-7 --device /dev/i2c-9 --name jetson_container_20250318_091132 text-generation-webui:r36.4.3-transformers
root@jetson2:/#
  1. Ran web server launch as follows:
# cd /opt/text-generation-webui && python3 server.py \
  --model-dir=/data/models/text-generation-webui \
  --chat \
  --listen
bash: cd: /opt/text-generation-webui: No such file or directory
root@jetson2:/#
Since steps 4 & 5 were run with cut-paste operations from the referenced tutorial, I am assuming that I didn’t mess up any keystroke.
The /opt folder has only one sub-folder: nvidia which it self has only nsight-compute
Can get text-generation-webui up and running with the documentation at the official site but Chat is totally unresponsive even with the smaller models.
What should I change in step 5 to fix the issue with the web server using the Jetson tutorial instructions? Thanks.
Regards.
It looks like the image is not fully built.
The image name should be text-generation-webui:r36.4.3.
text-generation-webui:r36.4.3-transformers is one of the dependencies for building the text-generation-webui image.
Could you run the below command to build the container first?
$ jetson-containers build $(autotag text-generation-webui)
Here is the output from your suggested command line entry:
Namespace(packages=['text-generation-webui:r36.4.3-transformers'], name='', base='', multiple=False, build_flags='', build_args='', use_proxy=False, package_dirs=[''], list_packages=False, show_packages=False, skip_packages=[''], skip_errors=False, skip_tests=[''], test_only=[''], simulate=False, push='', logs='', verbose=False, no_github_api=False)
-- L4T_VERSION=36.4.3 JETPACK_VERSION=6.2 CUDA_VERSION=12.6 PYTHON_VERSION=3.10 LSB_RELEASE=22.04 (jammy)
-- jetson-containers text-generation-webui:r36.4.3-transformers
-- Copying /etc/nv_tegra_release to /ssd/projects/jetson-containers/packages/llm/ollama/nv_tegra_release
Failed to fetch version information. Status code: 404
  File "/usr/lib/python3.10/runpy.py", line 196, in _run_module_as_main
    return _run_code(code, main_globals, None,
  File "/usr/lib/python3.10/runpy.py", line 86, in _run_code
    exec(code, run_globals)
  File "/ssd/projects/jetson-containers/jetson_containers/build.py", line 120, in <module>
    build_container(args.name, args.packages, args.base, args.build_flags, args.build_args, args.simulate, args.skip_tests, args.test_only, args.push, args.no_github_api, args.skip_packages)
  File "/ssd/projects/jetson-containers/jetson_containers/container.py", line 70, in build_container
    packages = resolve_dependencies(packages, skip_packages=skip_packages)
  File "/ssd/projects/jetson-containers/jetson_containers/packages.py", line 346, in resolve_dependencies
    packages, changed = add_depends(packages)
  File "/ssd/projects/jetson-containers/jetson_containers/packages.py", line 317, in add_depends
    for dependency in find_package(package).get('depends', []):
  File "/ssd/projects/jetson-containers/jetson_containers/packages.py", line 201, in find_package
    raise KeyError(f"couldn't find package:  {package}")
KeyError: "couldn't find package:  text-generation-webui:r36.4.3-transformers"
There was an error displayed in the terminal window as shown above.
I cloned jetson-containers on Mar 10 and built it locally. I did a pull origin a few minutes ago and ran the install.sh script. Then I ran jetson-containers with the build option per your suggestion. The error remained. Awaiting your kind suggestions on what to do next. Thanks.
Regards.
It looks like jetson-container still picks up the text-generation-webui:r36.4.3-transformers image.
Could you try to remove the autotag to see if it helps?
$ jetson-containers build text-generation-webui
If the tool doesn’t start to build the following container, could you remove all the text-generation-webui:* images and try it again?
Thanks again.
The jetson-containers command without the autotag didn’t work:
KeyError: "couldn't find package:  llama_cpp"
So I tried your second suggestion with:
docker images | grep "text-generation-webui*" | awk '{print $3}'docker images | xargs docker rmi
A whole lot of the images were deleted but I couldn’t delete a few more owing to the following message:
Error response from daemon: conflict: unable to delete b298da4822a7 (cannot be forced) - image has dependent child images
So I used id b298da4822a7 as an example (there were more than a dozen similar entries, possibly owing to my attempts with the original command using jetson-containers with autotag) with the following command:
$ docker inspect --format='{{.Id}} {{.Parent}}' $(docker images -a -q) | grep b298da4822a7
sha256:f2ed955fb610991cfa529e5bb627094863d9417e3f70952f804439a65f1ed346
sha256:b298da4822a733aa94757b4a4fa41a9f84f0c28f084a2c9299b8d4170931fcee
sha256:1616b473caea1d8dcced3a1c3c4a520a055692ced8819bf62bd7bf5b59c877ba
How do I determine the image ID of the four child images from the four lines above? (sorry for a newbie question, but you can understand my level!)? Thanks.
Regards.
Hello @AastaLLL,
I did a brute force removal all Docker containers and then ran the jetson-containers command with build parameter and without autotag.
Two error messages (previously encountered too) cropped up:
and
  File "/ssd/projects/jetson-containers/jetson_containers/packages.py", line 210, in find_package
-- Error:  return code 1
Perhaps, I am running an incorrect version of the script? Thanks.
Regards.
Suppose you are using Orin Nano with JetPack 6.2, is that correct?
To make sure all the images are cleaned in your environment, could you try the below command:
(Please note that this will remove ALL the docker images on your system)
$ sudo docker rmi $(sudo docker image ls -aq)
Please also re-clone the jetson-container source and try it again:
$ git clone https://github.com/dusty-nv/jetson-containers
$ bash jetson-containers/install.sh
I have run into the same exact issue you were facing. To solve this, I made a slight edit to the config file for the llama_cpp package, and everything worked.
Here is the PR that fixes it:
