platform: Jetson Orin AGX
l4T: 36.4.0
Jetpack: 6.1
CUDA:12.6.68
Hello, Im trying to build a docker container using jetson-container and i keep getting an error when building a custom container.
when i try to build using jetson-containers build --name=amigo_detect/ ros:humble-ros-base nanoowl, The ros part builds but when building the nanoowl part i get this error:
-- Building container amigo_detect/nanoowl:r36.4.0-torch2trt
DOCKER_BUILDKIT=0 docker build --network=host --tag amigo_detect/nanoowl:r36.4.0-torch2trt \
--file /home/castej-jetson/jetson-containers/packages/pytorch/torch2trt/Dockerfile \
--build-arg BASE_IMAGE=amigo_detect/nanoowl:r36.4.0-torchvision \
/home/castej-jetson/jetson-containers/packages/pytorch/torch2trt \
2>&1 | tee /home/castej-jetson/jetson-containers/logs/20250120_183217/build/amigo_detect_nanoowl_r36.4.0-torch2trt.txt; exit ${PIPESTATUS[0]}
DEPRECATED: The legacy builder is deprecated and will be removed in a future release.
BuildKit is currently disabled; enable it by removing the DOCKER_BUILDKIT=0
environment-variable.
Sending build context to Docker daemon 15.36kB
Step 1/6 : ARG BASE_IMAGE
Step 2/6 : FROM ${BASE_IMAGE}
---> 882d0e2cf731
Step 3/6 : ADD https://api.github.com/repos/NVIDIA-AI-IOT/torch2trt/git/refs/heads/master /tmp/torch2trt_version.json
---> 433fbe242b68
Step 4/6 : COPY patches/ /tmp/patches/
---> 6dd6285cdde7
Step 5/6 : RUN cd /opt && git clone --depth=1 https://github.com/NVIDIA-AI-IOT/torch2trt && cd torch2trt && cp /tmp/patches/flattener.py torch2trt && pip3 install --verbose . && sed 's|^set(CUDA_ARCHITECTURES.*|#|g' -i CMakeLists.txt && sed 's|Catch2_FOUND|False|g' -i CMakeLists.txt && cmake -B build -DCUDA_ARCHITECTURES=${CUDA_ARCHITECTURES} . && cmake --build build --target install && ldconfig && pip3 install --no-cache-dir --verbose nvidia-pyindex && pip3 install --no-cache-dir --verbose onnx-graphsurgeon
---> Running in f0f57afeed4b
Cloning into 'torch2trt'...
Using pip 24.3.1 from /usr/local/lib/python3.10/dist-packages/pip (python 3.10)
Looking in indexes: https://pypi.jetson-ai-lab.dev/jp6/cu126
Processing /opt/torch2trt
Preparing metadata (setup.py): started
Running command python setup.py egg_info
File "<string>", line 2, in <module>
File "<pip-setuptools-caller>", line 34, in <module>
File "/opt/torch2trt/setup.py", line 2, in <module>
import tensorrt
File "/usr/local/lib/python3.10/dist-packages/tensorrt/__init__.py", line 75, in <module>
from .tensorrt import *
ImportError: libnvdla_compiler.so: cannot open shared object file: No such file or directory
error: subprocess-exited-with-error
× python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> See above for output.
note: This error originates from a subprocess, and is likely not a problem with pip.
full command: /usr/bin/python3.10 -c '
exec(compile('"'"''"'"''"'"'
# This is <pip-setuptools-caller> -- a caller that pip uses to run setup.py
# - It imports setuptools before invoking setup.py, to enable projects that directly
# import from `distutils.core` to work with newer packaging standards.
# - It provides a clear error message when setuptools is not installed.
# - It sets `sys.argv[0]` to the underlying `setup.py`, when invoking `setup.py` so
# setuptools doesn'"'"'t think the script is `-c`. This avoids the following warning:
# manifest_maker: standard file '"'"'-c'"'"' not found".
# - It generates a shim setup.py, for handling setup.cfg-only projects.
import os, sys, tokenize
try:
import setuptools
except ImportError as error:
print(
"ERROR: Can not execute `setup.py` since setuptools is not available in "
"the build environment.",
file=sys.stderr,
sys.exit(1)
__file__ = %r
sys.argv[0] = __file__
if os.path.exists(__file__):
filename = __file__
with tokenize.open(__file__) as f:
setup_py_code = f.read()
else:
filename = "<auto-generated setuptools caller>"
setup_py_code = "from setuptools import setup; setup()"
exec(compile(setup_py_code, filename, "exec"))
'"'"''"'"''"'"' % ('"'"'/opt/torch2trt/setup.py'"'"',), "<pip-setuptools-caller>", "exec"))' egg_info --egg-base /tmp/pip-pip-egg-info-0dvngrhj
cwd: /opt/torch2trt/
Preparing metadata (setup.py): finished with status 'error'
error: metadata-generation-failed
× Encountered error while generating package metadata.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
The command '/bin/bash -c cd /opt && git clone --depth=1 https://github.com/NVIDIA-AI-IOT/torch2trt && cd torch2trt && cp /tmp/patches/flattener.py torch2trt && pip3 install --verbose . && sed 's|^set(CUDA_ARCHITECTURES.*|#|g' -i CMakeLists.txt && sed 's|Catch2_FOUND|False|g' -i CMakeLists.txt && cmake -B build -DCUDA_ARCHITECTURES=${CUDA_ARCHITECTURES} . && cmake --build build --target install && ldconfig && pip3 install --no-cache-dir --verbose nvidia-pyindex && pip3 install --no-cache-dir --verbose onnx-graphsurgeon' returned a non-zero code: 1
File "/usr/lib/python3.10/runpy.py", line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/lib/python3.10/runpy.py", line 86, in _run_code
exec(code, run_globals)
File "/home/castej-jetson/jetson-containers/jetson_containers/build.py", line 112, in <module>
build_container(args.name, args.packages, args.base, args.build_flags, args.build_args, args.simulate, args.skip_tests, args.test_only, args.push, args.no_github_api, args.skip_packages)
File "/home/castej-jetson/jetson-containers/jetson_containers/container.py", line 147, in build_container
status = subprocess.run(cmd.replace(_NEWLINE_, ' '), executable='/bin/bash', shell=True, check=True)
File "/usr/lib/python3.10/subprocess.py", line 526, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command 'DOCKER_BUILDKIT=0 docker build --network=host --tag amigo_detect/nanoowl:r36.4.0-torch2trt --file /home/castej-jetson/jetson-containers/packages/pytorch/torch2trt/Dockerfile --build-arg BASE_IMAGE=amigo_detect/nanoowl:r36.4.0-torchvision /home/castej-jetson/jetson-containers/packages/pytorch/torch2trt 2>&1 | tee /home/castej-jetson/jetson-containers/logs/20250120_183217/build/amigo_detect_nanoowl_r36.4.0-torch2trt.txt; exit ${PIPESTATUS[0]}' returned non-zero exit status 1.
I definitely have libnvdla_compiler.so in /usr/lib/aarch64-linux-gnu/tegra/ so im not sure what is happening.
