in installed the solution exactly according
text-generation-webui - NVIDIA Jetson Generative AI Lab .
I can call the website but no model can be selected. where do i get the model from, hugging face ? or any error in the installation?
Image generation runs on Jetson Orin Nano 8GB nearly not, because of limited
RAM, any solution?
Thx
Do you use jetson-containers and open the http://<IP_ADDRESS>:7860?
If yes, could you share a screenshot to show the issue?
For the memory issue, have you tried the Pre-setup steps to add some swap memory?
yes im using http://<IP_ADDRESS>:7860 and yes we did pre setup.
will provide a screenshot later today, thx for your fast answer
Hi @alexander102 , yes you can download the models from HuggingFace, the text-generation-webui was compiled with GPU-accelerated loaders for many types of models (HF transformers, AutoGPTQ, exllama, llama.cpp, ect)
You can find more info about downloading models on this page (and the oobabooga github )
For Orin Nano, I would try using https://huggingface.co/TheBloke/Llama-2-7B-Chat-GGML (llama-2-7b-chat.ggmlv3.q4_0.bin is what I’ve tried)
system
Closed
September 27, 2023, 3:30am
8
