Jetson ffmpeg hardware acceleration usring nvdec but don't use GPU
Hi
I want to use hardware acceleration.
[Jetson Xavier]
[CUDA 10.2]
I met some problem but followed below the link and solved.
https://forums.developer.nvidia.com/t/jetson-tx2-and-ffmpeg-cant-initialize-nvrm-channel/165629/5
https://forums.developer.nvidia.com/t/hardware-accelerated-video-playback-with-l4t-ffmpeg/154019/7
And I used this command.
'ffmpeg -c:vh264_ntv4l2dec -i [input] [output]'
Run at ‘nvdec’ 700 MHz but do not use GPU.
So I looked into it (using GPU) and saw a post saying that Jetson Xavier doesn’t support hardware acceleration using GPU.
Summary
  1. difference between -hwaccel cuda option and nvdec.
  2. How can I use GPU to accelerate hardware if it’s true that it’s not supported and if it’s false.
Best regards.
On latest desktop GPUs and Jetson platforms, encoding/decoding tasks are done on individual NVENC/NVDEC engines. So that GPU is available for deep learning inference.
For capability of the hardware engines, please check
https://developer.nvidia.com/jetson-xavier-nx-data-sheet
Yes I checked data sheet.
NVDEC support 1080p60 10 stream but my video stumbles and is lagging.
My video
[ 1080p30 x1 ]
[ 720p35 x2 ]
I want to decrease CPU usage
Thanks for the reply.
For using ffmpeg there is additional buffer copy since it requires CPU buffer in the frameworks For optimal performance, we would suggest use jetson_multimedia_api or gstreamer. Please check developer guide and give it a try.
Okay, I will try.
Thank you.
