Hello!
I am working on xavier nx.
I found topic about fullscreen mode, but it doesn’t work:
I add code from link and change it but not work.
What’s wrong?
Thank for your help!
Hello!
What’s wrong?
Please check if jetson.utils.glDisplay(.)
can meet your reqirement.
For example:
display = jetson.utils.glDisplay()
while display.IsOpen():
display.RenderOnce(img, 1920, 1080)
Thanks, but i need only picture without titlebar
Hi @Polzovatel2351, I haven’t tried fullscreen mode so I can’t tell for sure, but can you also try commenting out these lines:
/*if( !mResizedToFeed || ((GetWidth() < width || GetHeight() < height) && (width < mScreenWidth && height < mScreenHeight)) )
SetSize(width, height);
mResizedToFeed = true;
My initial guess is that these lines (which resize the window once to match the size of the video stream being rendered) is resetting the fullscreen mode, but I don’t know that for sure. Also run the following after making any C++ code changes in the project:
cd jetson-inference/build
cmake ../
make
sudo make install
Hi @dusty_nv, thanks!
I tried it, but it not work. Nothing changes.
OK, I was able to get this working the same way, and then added functions to glDisplay in commit #aae77a
for toggling fullscreen mode:
So if you reclone/rebuild/reinstall the repo, you should be able to use these functions now. For example, here is a modified video-viewer.cpp that toggles fullscreen mode every 100 frames:
#include "videoSource.h"
#include "videoOutput.h"
#include "glDisplay.h"
#include "logging.h"
#include "commandLine.h"
#include <signal.h>
bool signal_recieved = false;
void sig_handler(int signo)
if( signo == SIGINT )
LogInfo("received SIGINT\n");
signal_recieved = true;
int usage()
printf("usage: video-viewer [--help] input_URI [output_URI]\n\n");
printf("View/output a video or image stream.\n");
printf("See below for additional arguments that may not be shown above.\n\n");
printf("positional arguments:\n");
printf(" input_URI resource URI of input stream (see videoSource below)\n");
printf(" output_URI resource URI of output stream (see videoOutput below)\n\n");
printf("%s", videoSource::Usage());
printf("%s", videoOutput::Usage());
printf("%s", Log::Usage());
return 0;
int main( int argc, char** argv )
* parse command line
commandLine cmdLine(argc, argv);
if( cmdLine.GetFlag("help") )
return usage();
* attach signal handler
if( signal(SIGINT, sig_handler) == SIG_ERR )
LogError("can't catch SIGINT\n");
* create input video stream
videoSource* inputStream = videoSource::Create(cmdLine, ARG_POSITION(0));
if( !inputStream )
LogError("video-viewer: failed to create input stream\n");
return 0;
* create output video stream
videoOutput* outputStream = videoOutput::Create(cmdLine, ARG_POSITION(1));
if( !outputStream )
LogError("video-viewer: failed to create output stream\n");
* capture/display loop
uint32_t numFrames = 0;
while( !signal_recieved )
uchar3* nextFrame = NULL;
if( !inputStream->Capture(&nextFrame, 1000) )
LogError("video-viewer: failed to capture video frame\n");
if( !inputStream->IsStreaming() )
continue;
LogInfo("video-viewer: captured %u frames (%u x %u)\n", ++numFrames, inputStream->GetWidth(), inputStream->GetHeight());
if( outputStream != NULL )
if( outputStream->IsType<glDisplay>() )
glDisplay* display = (glDisplay*)outputStream;
if( numFrames % 100 == 0 ) // toggle fullscreen every 100 frames
const bool fullscreen = display->IsFullscreen();
LogInfo("changing display window to %s mode\n", fullscreen ? "non-fullscreen" : "fullscreen");
display->SetFullscreen(!fullscreen);
LogInfo("display window is %s fullscreen\n", display->IsFullscreen() ? "" : "not");
outputStream->Render(nextFrame, inputStream->GetWidth(), inputStream->GetHeight());
// update status bar
char str[256];
sprintf(str, "Video Viewer (%ux%u) | %.1f FPS", inputStream->GetWidth(), inputStream->GetHeight(), outputStream->GetFrameRate());
outputStream->SetStatus(str);
// check if the user quit
if( !outputStream->IsStreaming() )
* destroy resources
printf("video-viewer: shutting down...\n");
SAFE_DELETE(inputStream);
SAFE_DELETE(outputStream);
printf("video-viewer: shutdown complete\n");
Big thanks for this!
But i have troubles with uses in python.
I download, build and install new repo. But python gives me this
My code:
import jetson.inference
import jetson.utilscamera = jetson.utils.gstCamera(1920, 1080, “/dev/video0”)
display.SetFullscreen(True)while display.IsOpen():
img, width, height = camera.CaptureRGBA()
display.RenderOnce(img, width, height)
I didn’t add the Python bindings for this yet. I’m not sure about it because jetson.utils.glDisplay() is deprecated in favor of jetson.utils.videoSource()
However if you want, you can add the binding to this file: jetson-utils/PyGL.cpp at aae77a0a97b25d7e3a9adb1e1c36947564958f68 · dusty-nv/jetson-utils · GitHub
Then re-run make
and sudo make install
Okay, thanks!
It occurred to me that an alternative to making the Python binding, is to just add a call to SetFullscreen(true)
at this line of code in glDisplay.cpp
Then it should always be fullscreen.
I try it and nothing changes
Did you re-run make
from your jetson-inference/build
directory?
Yes
Hmm ok, kinda strange as that works here. Regardless, I just added Python bindings to glDisplay in commit 480865
for the following functions:
glDisplay.IsMaximized() -> bool
glDisplay.IsFullscreen() -> bool
glDisplay.SetMaximized(bool)
glDisplay.SetFullscreen(bool)
So if you pull the latest code, recompile, and re-install, then you should be able to call these functions from Python. For a working example, see gl-display-test.py
If you are using glDisplay.RenderOnce(), yes it is normal because the default y-coordinate is 30px (this is normally so that the image isn’t obscured by the window’s title bar). There is also a default 5px border on the left (x-coordinate)
To change it, you can use display.RenderOnce(img, width, height, x=0, y=0)
instead
