Hello, i recently trained and exported an action-recognition model using TAO toolkit 5.0 (rgb_resnet18_3.onnx). I am using the jetson-inference container to be able to use actionnet and i get an error message.
here is my command:
actionnet --model=python/training/detection/ssd/models/action-recognition/rgb_resnet18_3.onnx --labels=python/training/detection/ssd/models/action-recognition/labels.txt csi://0
here is the output( ill only paste the error message at the end):
[TRT] Loaded 59 bytes of code generator cache.
[TRT] device GPU, building CUDA engine (this may take a few minutes the first time a network is loaded)
[TRT] 4: [network.cpp::validate::3062] Error Code 4: Internal Error (Network has dynamic or shape inputs, but no optimization profile has been defined.)
[TRT] device GPU, failed to build CUDA engine
[TRT] device GPU, failed to load python/training/detection/ssd/models/action-recognition/rgb_resnet18_3.onnx
[TRT] failed to load python/training/detection/ssd/models/action-recognition/rgb_resnet18_3.onnx
[TRT] actionNet -- failed to initialize.
actionnet: failed to initialize actionNet
is this an issue with TensoRT not being compatible with the ONNX file given? or am i missing an optimization profile that i have to build?
thank you
