I have my tensorflow model .pb (MobileNetV2) for classification and I want to use it with my Jetson Nano.
From jetson-inference samples I dint’t understand how to do it.
Can someone please help me?
Stefano
Stefano
Do you want to convert the .pb file into TensorRT engine, and inference it with pure TensorRT?
If yes, please check this tutorial for the steps in detail:
[url]https://github.com/AastaNV/TRT_object_detection[/url]
Yes, I trained a classificator based on MobilenetV2 with kersa, then converted it in tensorflow .pb file.
Now I want to do inference on my Jetson Nano in C/C++.
I have to do the same for a SSD MobilnetV2?
YES.
You can follow the GitHub shared in comment#2 directly.
Thanks, but I’m encountering some problem…
calling python3 main.py ./image1.jpg
I get:
2019-10-25 14:09:57.359005: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudart.so.10.0
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:516: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint8 = np.dtype([("qint8", np.int8, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:517: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_quint8 = np.dtype([("quint8", np.uint8, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:518: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint16 = np.dtype([("qint16", np.int16, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:519: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_quint16 = np.dtype([("quint16", np.uint16, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:520: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint32 = np.dtype([("qint32", np.int32, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:525: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
np_resource = np.dtype([("resource", np.ubyte, 1)])
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:541: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:542: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:543: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:544: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:545: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:550: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py:18: The name tf.GraphDef is deprecated. Please use tf.compat.v1.GraphDef instead.
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/graphsurgeon/_utils.py:2: The name tf.NodeDef is deprecated. Please use tf.compat.v1.NodeDef instead.
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/graphsurgeon/StaticGraph.py:125: The name tf.gfile.GFile is deprecated. Please use tf.io.gfile.GFile instead.
WARNING: To create TensorRT plugin nodes, please use the `create_plugin_node` function instead.
NOTE: UFF has been tested with TensorFlow 1.12.0. Other versions are not guaranteed to work
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
UFF Version 0.6.3
=== Automatically deduced input nodes ===
[name: "Input"
op: "Placeholder"
attr {
key: "shape"
value {
shape {
dim {
dim {
dim {
dim {
Using output node NMS
Converting to UFF graph
Warning: No conversion function registered for layer: NMS_TRT yet.
Converting NMS as custom op: NMS_TRT
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:179: The name tf.AttrValue is deprecated. Please use tf.compat.v1.AttrValue instead.
Warning: No conversion function registered for layer: GridAnchor_TRT yet.
Converting GridAnchor as custom op: GridAnchor_TRT
Warning: No conversion function registered for layer: FlattenConcat_TRT yet.
Converting concat_box_loc as custom op: FlattenConcat_TRT
File "main.py", line 31, in <module>
uff_model = uff.from_tensorflow(dynamic_graph.as_graph_def(), model.output_name, output_filename='tmp.uff')
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 181, in from_tensorflow
debug_mode=debug_mode)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 94, in convert_tf2uff_graph
uff_graph, input_replacements, debug_mode=debug_mode)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 79, in convert_tf2uff_node
op, name, tf_node, inputs, uff_graph, tf_nodes=tf_nodes, debug_mode=debug_mode)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 47, in convert_layer
return cls.registry_[op](name, tf_node, inputs, uff_graph, **kwargs)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter_functions.py", line 21, in convert_placeholder
dtype = tf2uff.convert_tf2numpy_dtype(tf_node.attr['dtype'].type)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 103, in convert_tf2numpy_dtype
return tf.as_dtype(dtype).as_numpy_dtype
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py", line 717, in as_dtype
(type_value,))
TypeError: Cannot convert value 0 to a TensorFlow DType.
both with MobilenetV1 and V2
Please remember to update the graphsurgeon converter which mentioned here:
[url]GitHub - AastaNV/TRT_object_detection: Python sample for referencing object detection model with TensorRT
Thanks. I solved [with coco ssd mnv1 and mnv2] updating graphsurgeon converter.
Now, with my SSD MobileNetV2 model I’m getting this error:
[TensorRT] INFO: Detected 1 input and 2 output network tensors.
python3: nmsPlugin.cpp:139: virtual void nvinfer1::plugin::DetectionOutput::configureWithFormat(const nvinfer1::Dims*, int, const nvinfer1::Dims*, int, nvinfer1::DataType, nvinfer1::PluginFormat, int): Assertion `numPriors * numLocClasses * 4 == inputDims[param.inputOrder[0]].d[0]' failed.
Aborted (core dumped)
In order to try to convert my model I created model_ssd_mobilenet_v2_custom.py (modifying model_ssd_mobilenet_v2_coco_2018_03_29.py) with:
dims = [1,150,150]
(I used 1 channel images for training)
PriorBox = gs.create_plugin_node(
name="GridAnchor",
op="GridAnchor_TRT",
minSize=0.1, ---> instead of 0.2
maxSize=0.95,
aspectRatios=[1.0, 2.0, 0.5, 3.0, 0.33],
variance=[0.1,0.1,0.2,0.2],
featureMapShapes=[19, 10, 5, 3, 2, 1],
numLayers=6
and, since I have 9 classes, I put 10 as numClasses
NMS = gs.create_plugin_node(
name="NMS",
op="NMS_TRT",
shareLocation=1,
varianceEncodedInTarget=0,
backgroundLabelId=0,
confidenceThreshold=1e-8,
nmsThreshold=0.6,
topK=100,
keepTopK=100,
numClasses=10,
inputOrder=[1, 0, 2],
confSigmoid=1,
isNormalized=1
The tmp.uff file is generated but I’m not able to use it.
I’ve uploaded here custom.zip - Google Drive my TF model and my modified scripts.
Can you please help me?
We are checking your model internally.
Will update information with you later.
Thank you very much
Sorry for keeping you waiting.
We recently found that the dimension of model output is beyond our expectation.
Not sure if this is related to a customized input dimension.
Your model
numPriors : 1917
loc_data : 2160 1 1
conf_data : 5400 1 1
prior_data: 2 7668 1
However, we expect the dimension follow this rule:
loc_data : [numPriors*numLocClasses*4, 1, 1]
conf_data : [numPriors*numClasses, 1, 1]
prior_data: [2, numPriors*4, 1]
Did you change the prior number or update other parameter?
Is this output dimension under your expectation?
